<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[crown Plugin Manager — The All-in-One SketchUp Extension Manager (Completely Free)]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">Screenshots<br />
夸克截图_2026-08-30_20-00-24<br />
夸克截图_2026-08-30_20-00-00<br />
夸克截图_2026-08-30_19-58-59<br />
夸克截图_2026-08-30_20-00-10<br />
夸克截图_2026-08-30_19-59-14<br />
The problem it solves<br />
The native Plugins folder turns into a junk drawer — you can’t tell which folder<br />
belongs to which plugin<br />
Extensions scatter toolbars across your screen; most icons you never use<br />
Finding one specific command means hunting through menus and toolbars<br />
No idea which plugin is slowing down your startup<br />
Renaming, disabling, or batch-launching plugins is painful<br />
What it does</p>
<ol>
<li>
<p dir="auto">One clean library, fully under your control<br />
Move all extensions into one custom folder (default xwzxwz/), or point it anywhere<br />
you like. Your native Plugins folder stays clean. Already installed plugins can be<br />
“adopted” into the library with one click.</p>
</li>
<li>
<p dir="auto">Groups, notes, and drag-and-drop ordering<br />
Organize plugins into custom groups, add notes, reorder by dragging.</p>
</li>
<li>
<p dir="auto">Bundles (launch sets)<br />
Group several plugins into a Bundle and launch them all at once — great for<br />
task-specific workflows (modeling / rendering / documentation).</p>
</li>
<li>
<p dir="auto">Auto-start management<br />
Prefix-based auto-start with batch on/off switching.</p>
</li>
<li>
<p dir="auto">HUD command pool — the part I’m proudest of<br />
The manager hooks UI::Command to capture every button your extensions register,<br />
building one searchable command pool. From there you can:</p>
</li>
</ol>
<p dir="auto">Deep-search any command by name, even if its toolbar is hidden<br />
Drag commands into your own native toolbars — mix buttons from different<br />
extensions into a single clean toolbar<br />
Marquee-select multiple commands at once<br />
6. Pinyin search<br />
Search by Chinese characters, pinyin initials, English, notes, or URLs.<br />
(Built for Chinese users — English search works great too.)</p>
<ol start="7">
<li>Three panel modes</li>
</ol>
<p dir="auto">Large panel — full management UI (groups, bundles, bookmarks, HUD builder)<br />
Compact panel — slim always-on sidebar, pinnable, 3 density presets<br />
Spotlight panel — press Ctrl+Shift+Space and a small search box appears right<br />
at your cursor. Type, Enter, done.<br />
8. Plugin health check<br />
Launch plugins one by one and diagnose them; anything that registers no toolbar and<br />
no extension gets flagged and can be moved to the recycle bin (undoable with Ctrl+Z).</p>
<ol start="9">
<li>
<p dir="auto">Startup profiler<br />
See exactly how long each plugin takes to load, ranked — find what’s killing your<br />
startup time.</p>
</li>
<li>
<p dir="auto">A real safety net</p>
</li>
</ol>
<p dir="auto">Recycle bin instead of hard delete<br />
Full undo/redo (Ctrl+Z / Ctrl+Y) for deletes, renames, and batch operations<br />
Atomic config writes + automatic backup before any config migration<br />
One broken plugin never takes the manager down — and never crashes SketchUp<br />
11. Import / export<br />
Install from .rbz / .zip / .xwz (drag &amp; drop), or pack your entire library into<br />
a single zip backup.</p>
<ol start="12">
<li>
<p dir="auto">Built-in bookmarks<br />
Keep 3D Warehouse, Extension Warehouse, tutorials — all inside the manager.</p>
</li>
<li>
<p dir="auto">Light/dark theme, and it’s translated<br />
Ships with Chinese and English. The i18n system is language-pack based: drop a<br />
lang/&lt;code&gt;.json file in and you have a new language. Translations very welcome!</p>
</li>
</ol>
<p dir="auto">Actually, I didn’t test it</p>
<p dir="auto">Download link: <a href="https://1650635.share.123pan.cn/123pan/EFqA-nRQCh" target="_blank" rel="noopener noreferrer nofollow ugc">https://1650635.share.123pan.cn/123pan/EFqA-nRQCh</a></p>
]]></description><link>https://community.sketchucation.com/topic/164991/crown-plugin-manager-the-all-in-one-sketchup-extension-manager-completely-free</link><generator>RSS for Node</generator><lastBuildDate>Mon, 31 Aug 2026 05:49:54 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164991.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 30 Aug 2026 12:18:02 GMT</pubDate><ttl>60</ttl></channel></rss>
