<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sherpa Render — AI rendering from your viewport (+ a free view straightener)]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I've released Sherpa Render on the Extension Warehouse and I'd rather<br />
explain it here honestly than let a store listing do it.</p>
<p dir="auto"><img src="https://sherpa-render.com/brand_assets/living03-warm-aug2026.webp" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">WHAT IT DOES<br />
You set your camera, hit render in the Sherpa panel, and a lit image of<br />
that view comes back into the dialog. No export step, no render engine<br />
installed. It works from your viewport geometry — it doesn't generate a<br />
building from a text prompt. What you drew stays where you drew it; what<br />
you left open is what it fills in.</p>
<p dir="auto">There's no prompt box. Light, time of day, colour temperature, artificial<br />
lights, whether people appear, styling level, and per-surface materials<br />
("floor: ceramic", "countertop: marble") are all set with controls. Leave a<br />
field blank and that surface stays as you modelled it.</p>
<p dir="auto">WHAT IT ISN'T<br />
It isn't photorealistic and it isn't a V-Ray or Enscape replacement. If<br />
you're producing a final photoreal image, use a real engine. This is for<br />
the stage before that — concepts, pitches, the first client conversation.<br />
I'd rather say that up front than have you find out on render three.</p>
<p dir="auto"><img src="https://sherpa-render.com/brand_assets/goodstart-living-styling.webp" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">THE FREE PART<br />
The package also installs a Straightener: level your verticals, square to<br />
the model or to a selected face, or re-aim and widen until your selection<br />
fits the frame. It moves the SketchUp camera itself, so what you see is<br />
what you get, and Undo restores your original viewpoint. It costs no<br />
credits and doesn't need a Sherpa account. Use it on its own if that's all<br />
you want from this.</p>
<p dir="auto">ONE FOR THE DEVS<br />
Worth passing on, because it cost me a fortune in time: doing socket I/O<br />
from a Ruby thread inside SketchUp isn't merely slow, it's broken. I<br />
measured the same upload running roughly 600x slower from a thread, right<br />
up to TCP timeouts. Sketchup::Http is now the default path for everything<br />
in the extension, with a HEAD check after upload to confirm byte<br />
integrity. If you're building anything that talks to a server, save<br />
yourself the week.</p>
<p dir="auto">THE HONEST COMMERCIAL BIT<br />
The extension is free; renders run on credits from a Sherpa account. A new<br />
account gets 5 renders free, no card. After that it's a subscription from<br />
EUR 49/month. Failed renders are refunded automatically. Your images are<br />
never used to train models, you keep ownership, and files are deleted<br />
after 30 days.</p>
<p dir="auto">REQUIREMENTS<br />
SketchUp 2021 or newer, Windows or Mac, plus an internet connection.<br />
SketchUp for Web won't work — no extensions there.</p>
<p dir="auto">Extension Warehouse:<br />
<a href="https://extensions.sketchup.com/extension/83e9cc43-5326-48ac-8f16-82a2b39d1d0c/sherpa-render-ai-rendering-for-architects" target="_blank" rel="noopener noreferrer nofollow ugc">https://extensions.sketchup.com/extension/83e9cc43-5326-48ac-8f16-82a2b39d1d0c/sherpa-render-ai-rendering-for-architects</a><br />
Setup and usage: <a href="https://sherpa-render.com/en/learn/sketchup-extension" target="_blank" rel="noopener noreferrer nofollow ugc">https://sherpa-render.com/en/learn/sketchup-extension</a></p>
<p dir="auto">Tear it apart — I'd genuinely rather hear where it falls over than where<br />
it works. I'll be in this thread.</p>
]]></description><link>https://community.sketchucation.com/topic/164982/sherpa-render-ai-rendering-from-your-viewport-a-free-view-straightener</link><generator>RSS for Node</generator><lastBuildDate>Thu, 20 Aug 2026 11:53:53 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164982.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Aug 2026 12:48:29 GMT</pubDate><ttl>60</ttl></channel></rss>
