<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing Guidepoints into Guidelines]]></title><description><![CDATA[<p dir="auto">I've been struggling to look for a plugin that can change a guide point into a guide line. Is there any plugin that I can use for this?</p>
]]></description><link>https://community.sketchucation.com/topic/164971/changing-guidepoints-into-guidelines</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 05:24:34 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164971.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Aug 2026 06:54:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing Guidepoints into Guidelines on Fri, 07 Aug 2026 12:05:11 GMT]]></title><description><![CDATA[<p dir="auto">How would this mythical Ruby code know the orientation of the guideline that you want it to draw ?<br />
There are an infinite number of lines passing through a guide-point.<br />
You can draw a new guideline using the Tape-Measure tool, that passes through a guide-point - but you need to give it some clues...<br />
So if you have two guide-points you can draw a guideline that passes between them,<br />
Of you have only one guide-point you need to pick a second point [e.g. on existing geometry] to give the guideline its orientation.<br />
Or you can pick an existing edge/line in the model to set the guidelines orientation and then pick the guide-point through which it should pass.<br />
None of this needs a script ??</p>
]]></description><link>https://community.sketchucation.com/post/1621531</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621531</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Fri, 07 Aug 2026 12:05:11 GMT</pubDate></item></channel></rss>
