<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can't use fredo plugins]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am using a computer that i don't have admin position on the server. Before one of the latest windows update there was no problem, but after that i can't use fredo plugins that depends on libfredo. I can use fredo tools for example. When admin opens sketchup they works but i can't. How can i solve the problem?<br />
Thanks..</p>
]]></description><link>https://community.sketchucation.com/topic/164948/can-t-use-fredo-plugins</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Jul 2026 21:32:15 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164948.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Jul 2026 10:51:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can't use fredo plugins on Wed, 22 Jul 2026 23:40:05 GMT]]></title><description><![CDATA[<p dir="auto">PS: Also make sure you have the latest versions of Fredo's extensions, LibFredo6 and the SketchUcation toolset installed - there have been changes to the licensing setup...</p>
]]></description><link>https://community.sketchucation.com/post/1621360</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621360</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Wed, 22 Jul 2026 23:40:05 GMT</pubDate></item><item><title><![CDATA[Reply to Can't use fredo plugins on Wed, 22 Jul 2026 13:09:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kenancakir" aria-label="Profile: kenancakir">@<bdi>kenancakir</bdi></a> <a href="/post/1621356">said</a>:</p>
<p dir="auto">While double clicking to install a setup file</p>
</blockquote>
<p dir="auto">Correct installation requires <strong>right clicking</strong> on the SketchUp installer and selecting Run as administrator as TIG wrote not double clicking.</p>
<p dir="auto">If IT won't give you temporary privileges to install SketchUp correctly, they should be able to use your sign in credentials with admin status to install or repair the installation.</p>
<p dir="auto">My previous employer's IT department had an arrangement so I could request admin status under my login so I could install required software. That status would be granted temporarily for a period of one hour. That worked fine for doing things like installing SketchUp. Maybe your IT department can do the same for you.</p>
]]></description><link>https://community.sketchucation.com/post/1621357</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621357</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 22 Jul 2026 13:09:29 GMT</pubDate></item><item><title><![CDATA[Reply to Can't use fredo plugins on Wed, 22 Jul 2026 12:25:44 GMT]]></title><description><![CDATA[<p dir="auto">Thank you TIG. I don't have permission to install programs, when i need a program, IT came and install it. While double clicking to install a setup file, it asks to log in as administrator. That was not a problem before windows uptade. I asked them to give permission needed and they did it but it seems we need permission for some other folders. I will ask them.</p>
]]></description><link>https://community.sketchucation.com/post/1621356</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621356</guid><dc:creator><![CDATA[kenancakir]]></dc:creator><pubDate>Wed, 22 Jul 2026 12:25:44 GMT</pubDate></item><item><title><![CDATA[Reply to Can't use fredo plugins on Wed, 22 Jul 2026 23:37:34 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like SketchUp was not installed properly.<br />
This can cause issues with permissions and the saving/reading of preferences/setting/licenses etc.<br />
I'll set out the way to fix it - if you have sufficient rights on your computer...<br />
Log in as you normal user-account.<br />
Close SketchUp.<br />
Find its installer exe file [usually in your Downloads].<br />
Select its icon, right-click &gt; context-menu &gt; 'Run as administrator'<br />
Answer the prompts and when offered 'Repair' choose that.<br />
This fixes permissions etc. When SketchUp restarts it should work.<br />
However, if you installed it 'as admin' rather than as your usual user-account login.<br />
this might cause issues.<br />
Running apps like SketchUp 'as admin' breaks some features too -<br />
like drag-n-drop - because a lower level app like Windows-Explorer can't affect a higher one like SketchUp [as admin]</p>
<p dir="auto">If SketchUp was installed by 'IT' then they need to set up all of your user's permissions to FULL  to let it work properly.<br />
If permissions for some folders in the AppData tree for your user are also skewed these need fixing too -<br />
some specific folders/files would be ../Local/SCF used for SketchUcation logins, 'set' saving etc, ../Local/LIBFREDO6_DATA_Dir for Fredo's data, ../Local/Temp/Fredo6_LibFredo6_TemporaryFiles and C:\Users\Public\SCF Licenses where the licenses are now stored...</p>
]]></description><link>https://community.sketchucation.com/post/1621355</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621355</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Wed, 22 Jul 2026 23:37:34 GMT</pubDate></item></channel></rss>
