<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue Changing Color of Tag]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">We are having an issue with our Layout all of a sudden. We have our Sketchup Tags organized under two groups : "Existing" and "Reference" and the rest of the tags are free floating in the list.</p>
<p dir="auto">For tags free floating, we can easily change the color, line, and line weight.</p>
<p dir="auto">For the tags listed under the two groups (Existing and Reference) we are not able to change the color, line, and weight.</p>
<p dir="auto">We have been using this tag structure for a year and have never run into this issue. Our Layout is updated.</p>
<p dir="auto">File is attached. Thank you! <a href="/assets/uploads/files/1782163784646-layout-tag-issue.layout">Layout Tag Issue.layout</a></p>
]]></description><link>https://community.sketchucation.com/topic/164919/issue-changing-color-of-tag</link><generator>RSS for Node</generator><lastBuildDate>Wed, 24 Jun 2026 20:32:06 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164919.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jun 2026 21:29:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue Changing Color of Tag on Tue, 23 Jun 2026 00:45:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/adrienneverdefinegardens0131" aria-label="Profile: adrienneverdefinegardens0131">@<bdi>adrienneverdefinegardens0131</bdi></a> I presume when you refer to groups in your post you are talking about Tag Folders. There have been a few reports of other users not being able to edit the color or dash style for tags in tag folders in SketchUp/LayOut 2026. I've been doing some testing and I'm not having any difficulty, though. Even in your file I can change the color and other parameters for dashes in LO. Here's an example in which I changed the color and scale of the EX TREELINE tag.<br />
<img src="/assets/uploads/files/1782175118231-screenshot-6_22_2026-7_38_22-pm.png" alt="Screenshot - 6_22_2026 , 7_38_22 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I see incorrect tag usage in your model. ALL edges and faces should be created and remain untagged. Tagging the geometry can create a number of problems including adjusting the dash styles as well as colors. This is the result of correcting the tag usage.<br />
<img src="/assets/uploads/files/1782175371185-screenshot-6_22_2026-7_29_25-pm.png" alt="Screenshot - 6_22_2026 , 7_29_25 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Purging unused content in the model.<br />
<img src="/assets/uploads/files/1782175402593-screenshot-6_22_2026-7_29_43-pm.png" alt="Screenshot - 6_22_2026 , 7_29_43 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Although not related to the dash and color thing, I notice you've overridden the Camera properties for the viewport. This can be a problem especially in cases where you've added labels and dimensions linked to the viewport.</p>
]]></description><link>https://community.sketchucation.com/post/1621096</link><guid isPermaLink="true">https://community.sketchucation.com/post/1621096</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Tue, 23 Jun 2026 00:45:50 GMT</pubDate></item></channel></rss>
