<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sketchup Wall Plugin - Muzwalls V2.0.3 Update Release]]></title><description><![CDATA[<p dir="auto">Hey everyone,</p>
<p dir="auto">New update is out, hope you're enjoying the fast release pace. We'd love to hear your <strong>feedback.</strong></p>
<p dir="auto">Sharper opening snaps and steadier arched frames<br />
Placing openings now snaps cleanly to existing edges and walls, including geometry nested inside groups and components, so doors and windows line up on the first click. Semicircle frames are more stable, and louvers gain sensible limits.</p>
<p dir="auto">Openings snap to existing edges and wall segments while you place or move them<br />
Snapping now reaches geometry nested inside groups and components<br />
Semicircle frame-and-glass openings build with a cleaner, more stable seam<br />
Louver slat count capped at 32 to keep the model responsive<br />
Clear on-screen hints for louver slat limits and the -89° to 89° tilt range<br />
Openings that land where you mean<br />
Placing a door or window is now a snapping experience. As you move an opening along a wall, <a href="https://muzwalls.com/" target="_blank" rel="noopener noreferrer nofollow ugc">MUZWalls</a> picks up the edges and segments of geometry already in your model and pulls the opening to them — so a new window aligns to the head of the one beside it, or a door squares up to a return wall, without nudging by eye.</p>
<p dir="auto">Crucially, this now works through groups and components. Earlier, snapping only saw loose edges in the active context; if the geometry you wanted to align to lived inside a group — as most real models are organised — it was invisible to the tool. The snap engine now looks inside nested groups and components and transforms their edges into place, so the points you actually want to hit are the points you can snap to. Snapping stays responsive by favouring the candidates nearest your cursor.</p>
<p dir="auto">Steadier semicircle frames<br />
Arched openings with a frame-and-glass infill have been stabilised. The curved frame profile and the seam where it meets the glass panel now build consistently, smoothing out the small geometry glitches that could appear along the arc on semicircle openings.</p>
<p dir="auto">Sensible louver limits<br />
Louvers now cap at 32 slats. Very high slat counts could push SketchUp's geometry engine hard enough to become unstable, so the count is bounded — with an on-screen note explaining the limit. The louver tilt field also shows its valid range up front: any angle from -89° to 89°.</p>
<p dir="auto">How to update<br />
In SketchUp, open Extensions → Extension Manager, uninstall the previous MUZWalls, and install the new .rbz from the download page. Your existing license activation carries over.</p>
<p dir="auto"><a href="https://muzwalls.com/downloads/muzwalls-v2.0.3.rbz" target="_blank" rel="noopener noreferrer nofollow ugc">Download muzwalls-v2.0.3.rbz ↓</a></p>
]]></description><link>https://community.sketchucation.com/topic/164894/sketchup-wall-plugin-muzwalls-v2.0.3-update-release</link><generator>RSS for Node</generator><lastBuildDate>Sun, 31 May 2026 23:30:04 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164894.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 May 2026 17:07:16 GMT</pubDate><ttl>60</ttl></channel></rss>
