<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sketchup Wall Plugin - Muzwalls V2.0.2 Updates - Double walls grow up]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Small but meaningful update on the MUZWalls side: double (cavity) walls got a proper round of improvements this<br />
release, and the Quantities takeoff has been taught to keep up with them. If you do any masonry or cavity-wall<br />
detailing in SketchUp, this one's aimed squarely at you.</p>
<p dir="auto">The short version:</p>
<ul>
<li>Shared leaves now stay in sync across the whole model</li>
<li>Cavity fill (mortar / sand) is now a first-class layer</li>
<li>Insulation gets its own layer (rigid board or batt)</li>
<li>Both show up in Quantities, with window/door openings subtracted automatically</li>
<li>New double walls default to 110 mm per leaf, matching the regular wall default</li>
</ul>
<p dir="auto">A bit more on each:</p>
<p dir="auto">Shared leaves stay in sync<br />
If two double walls share the same leaf type — say both use an inner leaf called "Brick-02" , editing one now updates<br />
the others automatically. Change a thickness, swap a material, tweak a finish, and every double wall in the model<br />
using that leaf rebuilds to match. It just happens: edit one, the rest follow. No new button, nothing to toggle.</p>
<p dir="auto">Deleting a double wall now also cleans up its leaf groups properly, so you're not left with orphan geometry piling up<br />
as you iterate.</p>
<p dir="auto">Cavity fill<br />
A new layer between the two leaves, for mortar fill, sand fill, or any solid infill you want shown in the model and<br />
counted. You set it up in the Double Wall Settings dialog, and there's a new ready-to-use texture bundled in for it.</p>
<p dir="auto">Insulation<br />
A separate cavity layer, for when you want rigid board or batt insulation modelled distinctly from a structural fill.<br />
Also configurable in Double Wall Settings.</p>
<p dir="auto">The two are independent, enable one, both, or neither. With both on, the order runs outer leaf → cavity fill →<br />
insulation → inner leaf.</p>
<p dir="auto">They get counted, too<br />
Quantities picks up two new report modes, one for cavity fill and one for insulation. Volumes account for openings on<br />
their own, windows and doors are subtracted from the layer totals, so there's no fixing up the CSV/Excel export by<br />
hand.</p>
<p dir="auto">One default change<br />
New double walls now start at 110 mm per leaf (was 100 mm)  it matches the regular wall default and tends to be the<br />
more common starting point for cavity detailing. Existing projects aren't touched; only newly drawn double walls use<br />
the new starting value.</p>
<p dir="auto">Updating<br />
In SketchUp: Extensions → Extension Manager, uninstall the previous MUZWalls, then install the new .rbz from the<br />
download page. Your license activation carries over, so there's nothing to re-activate.</p>
<p dir="auto"><a href="https://muzwalls.com/downloads/muzwalls-v2.0.2.rbz" target="_blank" rel="noopener noreferrer nofollow ugc">https://muzwalls.com/downloads/muzwalls-v2.0.2.rbz</a></p>
<p dir="auto">Would love to hear how it lands for you, especially if you're detailing cavity walls day to day. I'll be around to<br />
answer questions in the thread, and if anything misbehaves, tell me and I'll dig in.</p>
<p dir="auto">Cheers,<br />
Morteza (MUZWalls)</p>
]]></description><link>https://community.sketchucation.com/topic/164885/sketchup-wall-plugin-muzwalls-v2.0.2-updates-double-walls-grow-up</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 18:35:07 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164885.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 May 2026 20:23:32 GMT</pubDate><ttl>60</ttl></channel></rss>
