<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[PLUGIN] MBOS DEDUP2 v0.8.5 – Optimize your models by deduplicating geometry!]]></title><description><![CDATA[<p dir="auto">Hi everyone,<br />
We’ve all been there: you import a complex DWG or work on a large-scale project, and suddenly your file size explodes. Often, this is caused by hundreds of identical geometries existing as unique groups rather than instances of a single component.</p>
<p dir="auto">To solve this, I’m excited to share MBOS <strong>DEDUP2.</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1778570325826-icon.jpg" alt="icon.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>What is DEDUP2?</strong><br />
DEDUP2 is a specialized optimization tool that scans your model (or a specific selection) for "geometrical fingerprints." It identifies identical or highly similar geometries—even those buried deep within nested groups—and replaces them with instances of a single component definition.</p>
<p dir="auto"><strong>Key Features:</strong><br />
Recursive Deep Scan: It doesn't just look at the top level; it digs through nested hierarchies to find duplicates.</p>
<p dir="auto"><strong>Geometrical Profiling</strong>: The plugin analyzes faces, edges, and proportions to identify matches, regardless of the object's name.</p>
<p dir="auto">Hierarchy Preservation: Your model structure remains intact—only the efficiency is improved.</p>
<p dir="auto"><strong>"Safe Replace" Logic</strong>: Use the "Replace " button to swap objects where the match is 100% certain, minimizing risk.</p>
<p dir="auto">Modern UI: A clean HTML5 dialog window with a real-time execution log.</p>
<p dir="auto">Native Feel: Includes a dedicated toolbar for a seamless workflow.</p>
<p dir="auto"><strong>Quick Start Guide:</strong><br />
Select &amp; Scan: Select the "problem area" or the whole model and hit Scan Selection.</p>
<p dir="auto">Review: Check the dialog window to see how many duplicates and "geometrical fingerprints" were found.</p>
<p dir="auto">Optimize: Click Replace Safe to let the plugin work its magic and watch your file size shrink.</p>
<p dir="auto">Technical Details:<br />
Version: 0.8.5</p>
<p dir="auto">Compatibility: SketchUp 2019+</p>
<p dir="auto">I’d love to hear your feedback, bug reports, or feature requests! You can find the .rbz file attached below.</p>
<p dir="auto">Happy optimizing!<br />
<img src="/assets/uploads/files/1778570315356-screenshot1.jpg" alt="screenshot1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>DOWNLOAD:</strong><br />
<a href="/assets/uploads/files/1778570463464-mbos_dedup2_v0.8.5.rbz">MBOS_DEDUP2_v0.8.5.rbz</a></p>
]]></description><link>https://community.sketchucation.com/topic/164864/plugin-mbos-dedup2-v0.8.5-optimize-your-models-by-deduplicating-geometry</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 11:20:58 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164864.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 May 2026 07:21:24 GMT</pubDate><ttl>60</ttl></channel></rss>
