<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Urasik Viewport +]]></title><description><![CDATA[<p dir="auto">My extension to get fast captures in different projections and ability to visually cut model with a convenient  mini-map. There can by any additional viewports windows you need.</p>
<p dir="auto"><a href="/assets/uploads/files/1776676740948-urasik_viewport.rbz">urasik_viewport.rbz</a><br />
<a href="/assets/uploads/files/1776676933270-vertical-section.mp4">Vertical section.mp4</a><br />
<a href="/assets/uploads/files/1776676948537-horizontal-section.mp4">Horizontal section.mp4</a></p>
<p dir="auto">PURPOSE:<br />
Capture and render high-resolution viewports with history, custom resolutions, and clipping planes.</p>
<p dir="auto">HOW TO USE:</p>
<ol>
<li>Open the extension from the Extensions &gt; Urasik &gt; Viewport menu or the Viewport toolbar.</li>
<li>Select the desired projection (Top, Bottom, Front, Back, Left, Right, ISO, or Current).</li>
<li>Set the Gap percentage to adjust the framing of your selection.</li>
<li>Clipping Plane:
<ul>
<li>Check "Clip" to activate a global clipping plane.</li>
<li>Use the slider or input field to adjust the clipping distance.</li>
<li>Click "Map" to see a top-down preview of the clipping plane and camera position.</li>
</ul>
</li>
<li>Click "Update" to capture a high-resolution snapshot of your selection.</li>
<li>History:
<ul>
<li>Use the dropdown next to the Update button to access your capture history.</li>
<li>Click on any history item to reload that snapshot.</li>
</ul>
</li>
</ol>
<p dir="auto">FEATURES:</p>
<ul>
<li>Units &amp; Precision: All distance values (Gap, Clipping Distance) respect the units and precision settings defined in SketchUp's <strong>Model Info &gt; Units</strong>.</li>
<li>Section Plane Integration: The "Clip" feature creates a temporary global Section Plane. Its visibility and behavior reflect your current SketchUp <strong>Section Plane</strong> settings.</li>
<li>High-resolution capture: Set your desired resolution (e.g., 1200px, 2400px, etc.).</li>
<li>Global Clipping: The clipping plane cuts through all geometry, including nested groups and components.</li>
<li>Dynamic Minimap: The Map preview automatically switches to a side view for Top/Bottom projections (with selected object isolation) and a top view for all other projections. For Top/Bottom views, the clipping slider scale is optimized to the object's height for more precise control.</li>
<li>World-space framing: Correctly frames selected objects even within nested contexts.</li>
</ul>
<p dir="auto">RESULT:<br />
The extension will render a high-quality image of your selection and save it to your chosen directory.</p>
]]></description><link>https://community.sketchucation.com/topic/164830/urasik-viewport</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 12:52:30 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164830.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Apr 2026 09:21:10 GMT</pubDate><ttl>60</ttl></channel></rss>
