<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotate Texture on curved surface]]></title><description><![CDATA[<p dir="auto">Does anyone know how to rotate texture on a curved surface by 90 degrees.</p>
]]></description><link>https://community.sketchucation.com/topic/155137/rotate-texture-on-curved-surface</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 12:22:38 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/155137.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Apr 2017 17:33:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotate Texture on curved surface on Tue, 25 Apr 2017 18:24:14 GMT]]></title><description><![CDATA[<p dir="auto">It can be done without a plugin or extension. First, the material needs to be applied to the faces and not the group or component. Expose Hidden Geometry, right click on a single face and choose Texture&gt;Position. Rotate it as needed. Then turn off Hidden Geometry, use the Materials eye dropper to sample the material where you just rotate it and then immediately click the paint bucket on the surface to apply that material orientation.</p>
<p dir="auto">Alternatively, you can apply the material to another face in the model that would get the same orientation and sample that before applying it to the curved surface.</p>
<p dir="auto">I used these methods for the rush seat on the chairs and the legs on the table.<br />
<a href="https://flic.kr/p/ioSm3y" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="https://c1.staticflickr.com/4/3752/11416850996_695e552ea0_z.jpg" alt="https://c1.staticflickr.com/4/3752/11416850996_695e552ea0_z.jpg" class="img-markdown  img-fluid" /><br />
</a></p>
<p dir="auto">And on the curved surfaces on this post.<br />
<a href="https://flic.kr/p/dYa8g6" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="https://c1.staticflickr.com/9/8530/8511785423_9b3ca804d5_z.jpg" alt="https://c1.staticflickr.com/9/8530/8511785423_9b3ca804d5_z.jpg" class="img-markdown  img-fluid" /><br />
</a></p>
]]></description><link>https://community.sketchucation.com/post/1531229</link><guid isPermaLink="true">https://community.sketchucation.com/post/1531229</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Tue, 25 Apr 2017 18:24:14 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate Texture on curved surface on Tue, 25 Apr 2017 17:50:02 GMT]]></title><description><![CDATA[<p dir="auto">I know for three:<br />
Using SketchUV: Select surface, select SketchUV button, type 90 (for 90°).<br />
If ends up with mess of texture on surface, use built in mapping and again same to<br />
fit angle you need.<br />
<a href="http://extensions.sketchup.com/en/content/sketchuv" target="_blank" rel="noopener noreferrer nofollow ugc">http://extensions.sketchup.com/en/content/sketchuv</a></p>
<p dir="auto">Using FredoTools ThruPaint - <a href="https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552" target="_blank" rel="noopener noreferrer nofollow ugc">https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552</a></p>
<p dir="auto">Using WrapR: If it is quad model try WrapR plugin to make UV map and fit texture to your need.<br />
<a href="http://wrap-r.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://wrap-r.com/</a></p>
<p dir="auto">Or post your model here and ask for help...   <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=ef41b2b37c4" class="not-responsive emoji emoji-android emoji--smile" style="height:1.4em;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
]]></description><link>https://community.sketchucation.com/post/1531224</link><guid isPermaLink="true">https://community.sketchucation.com/post/1531224</guid><dc:creator><![CDATA[nlipovac]]></dc:creator><pubDate>Tue, 25 Apr 2017 17:50:02 GMT</pubDate></item></channel></rss>
