<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Waffle Slabs... any plugin to help doing those?]]></title><description><![CDATA[<p dir="auto">I once did a component and applied by hand below an entire floor... it was a pain to do it... keeping distances to walls and pillars, etc.</p>
<p dir="auto">Does anyone think there might be a plugin that could help me automatizing this job?</p>
<p dir="auto"><img src="http://constructionexchangegh.com/makeover/components/com_jshopping/files/img_products/full_skydome-index.jpg" alt="http://constructionexchangegh.com/makeover/components/com_jshopping/files/img_products/full_skydome-index.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://c1.staticflickr.com/9/8208/8156818002_49fdf968c9_b.jpg" alt="https://c1.staticflickr.com/9/8208/8156818002_49fdf968c9_b.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/150310/waffle-slabs-any-plugin-to-help-doing-those</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 10:47:52 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/150310.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jun 2015 20:40:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Thu, 08 Feb 2024 16:49:32 GMT]]></title><description><![CDATA[<p dir="auto">HI, I'm trying to model a waffle slab and have been reading through the post but I  cant find the plugin anywhere. can someone help me out, please?</p>
]]></description><link>https://community.sketchucation.com/post/1605392</link><guid isPermaLink="true">https://community.sketchucation.com/post/1605392</guid><dc:creator><![CDATA[jasra]]></dc:creator><pubDate>Thu, 08 Feb 2024 16:49:32 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Sat, 20 Jun 2015 06:56:59 GMT]]></title><description><![CDATA[<p dir="auto">Sdmitch's plugin look really promising.</p>
<p dir="auto">Just want to remind you that you can create 3d-geometry from 2dBoolean plugin, pushpulling or translating faces selected by materialnames. So you could create several basegrids and position them as you like and do a 2dboolean (extrusion mode).</p>
<p dir="auto">Not fully automatic, but can be useful when else fails. Or at least another method to try.</p>
<p dir="auto">All the best!</p>
]]></description><link>https://community.sketchucation.com/post/1485831</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485831</guid><dc:creator><![CDATA[jolran]]></dc:creator><pubDate>Sat, 20 Jun 2015 06:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Thu, 18 Jun 2015 16:04:54 GMT]]></title><description><![CDATA[<p dir="auto">Tell us when all will be fine because it's a very useful tool!  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60e.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--sunglasses" style="height:23px;width:auto;vertical-align:middle" title=":sunglasses:" alt="😎" /></p>
]]></description><link>https://community.sketchucation.com/post/1485648</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485648</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Thu, 18 Jun 2015 16:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Thu, 18 Jun 2015 14:27:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pilou" aria-label="Profile: pilou">@<bdi>pilou</bdi></a> said:</p>
<blockquote>
<p dir="auto">And SU4' to components by SuForYou?<br />
If you don't want deformation just draw equal surfaces<br />
Click the image for animation<br />
[attachment=0:1rak1dzq]&lt;!-- ia0 --&gt;su4.gif&lt;!-- ia0 --&gt;[/attachment:1rak1dzq]</p>
</blockquote>
<p dir="auto">Hi Pilou... this looks like an interesting plugin, but if I had to draw thousands of squares it would be even more work, right?</p>
<p dir="auto">SdMith sent me a PM some 2 days ago with a special version of his panelization plugin, to make waffles (in an alpha version)</p>
<hr />
<p dir="auto"><strong>I answered him with some tests and an idea which seems, to a non programmer like me, that it could make it MORE REALISTIC and EASIER to do! And also better to use (to replace components)</strong></p>
<p dir="auto">thanks SDMitch. It works... well, mostly flawlessly. I had an expiring timeline, so I ended up doing it by hand, but it was not the first waffle ceiling I was required to do and I know it won´t be the last, so I am sure I will have opportunity to use your plug.</p>
<p dir="auto">You are right that I can replace the component... HOWEVER (:() your plugin creates new instances of components where the shape is more complex, so in the end, to replace the component for a better one, one would need to replace hundreds of instances in a complicated ceiling, and edit them by hand to match the shapes...</p>
<p dir="auto">first example: all the "full" waffles (80x80) were created upside down, while the ones that are smaller, cut, etc, were created correctly</p>
<p dir="auto"><img src="http://i.imgur.com/fmtBjjP.jpg" alt="http://i.imgur.com/fmtBjjP.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">now I created a half meter border around edges (which is how it really happens in real life). It mostly created a correct waffle ceiling. In red, places where for some reason it did not create the waffles (which is actually a good thing, as you will read below).</p>
<p dir="auto">Also, I replaced the standart waffle with mine... but as we can see, there are tons of different component instances which are not replaced.</p>
<p dir="auto"><img src="http://i.imgur.com/TOT6Zcr.jpg" alt="http://i.imgur.com/TOT6Zcr.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">the good news is that you shouldn´t break your head thinking how to make irregular shapes. Because waffle ceilings should NOT have irregular shapes.</p>
<p dir="auto">they are created with moulds and the moulds cannot have irregular shapes. At maximum, they can sometimes be rectangular, like 1/2 or 1/3 of the full size in one direction</p>
<p dir="auto"><img src="https://upload.wikimedia.org/wikipedia/commons/5/55/Forma_Atex,_Laje_Nervurada.jpg" alt="https://upload.wikimedia.org/wikipedia/commons/5/55/Forma_Atex,_Laje_Nervurada.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">look these images... in most of them, there is a single shape. Where there would be irregular shapes, there is a continuous flat ceiling instead of the "waffle" hole.</p>
<p dir="auto">round shape on the bottom left... they do not follow the shape...</p>
<p dir="auto"><img src="http://wwwo.metalica.com.br/images/stories/Id4292/projeto-lajes-02.jpg" alt="http://wwwo.metalica.com.br/images/stories/Id4292/projeto-lajes-02.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">in this image, on the left, a "half" one</p>
<p dir="auto"><img src="http://www.protenbras.com.br/wp-content/gallery/laje-nervurada-protendida/laje-nervurada-protendida-2_1.jpg" alt="http://www.protenbras.com.br/wp-content/gallery/laje-nervurada-protendida/laje-nervurada-protendida-2_1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">My suggestion, which would make the plugin perfect and also solve the problem of hundreds of different component instances which would make too difficult to replace them all:</p>
<p dir="auto">the plugin creates 3 or 4 sizes of waffles "moulds" (1, 3/4, 1/2, 1/3) based on the main size given by the user. (maybe user could check mark which sizes he would like to use, since in some buildings, a single size will be used)</p>
<p dir="auto">It then does a "best fit". Where none fits, the plugin create a face covering...</p>
<p dir="auto">here, graphically explained</p>
<p dir="auto">1 - the two molds on the right cannot be placed there<br />
2 - here, how the plugin should place the 1/1 molds... where the mould doesn´t fit, it´s empty<br />
3 - it tested the 3/4 mould, both up and sideways. Only left it where it fit entirely.<br />
4 - it tested the 1/2 mould<br />
5 - where no mould would fit (I actually didnt even test the 1/4 mould), it would cut the ceiling face and "push pull" it to the same level as the bottom of the mould... resulting in image 6.</p>
<p dir="auto"><img src="http://i.imgur.com/fdgBpjI.jpg" alt="http://i.imgur.com/fdgBpjI.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1485629</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485629</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Thu, 18 Jun 2015 14:27:12 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Thu, 18 Jun 2015 14:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pilou" aria-label="Profile: pilou">@<bdi>pilou</bdi></a> said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser" aria-label="Profile: unknownuser">@<bdi>unknownuser</bdi></a> said:</p>
<blockquote>
<p dir="auto">I have attached the Alpha version of the plugin</p>
</blockquote>
<p dir="auto">Where is it ?  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
</blockquote>
<p dir="auto">in my PM <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
<p dir="auto">rethinking it, I should not have posted his PM to me without his authorization. I will edit it and only include my part of the PM. <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
]]></description><link>https://community.sketchucation.com/post/1485636</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485636</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Thu, 18 Jun 2015 14:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Thu, 18 Jun 2015 13:55:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser" aria-label="Profile: unknownuser">@<bdi>unknownuser</bdi></a> said:</p>
<blockquote>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1485635</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485635</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Thu, 18 Jun 2015 13:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Tue, 16 Jun 2015 00:48:31 GMT]]></title><description><![CDATA[<p dir="auto">And SU4' to components by SuForYou?<br />
<img src="/uploads/imported_attachments/PVqW_su4.gif" alt="su4.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1485332</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485332</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Tue, 16 Jun 2015 00:48:31 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 22:50:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdmitch" aria-label="Profile: sdmitch">@<bdi>sdmitch</bdi></a> said:</p>
<blockquote>
<p dir="auto">Will take a look at Ceiling Generator.  Shouldn't be that difficult to make the panels components.</p>
</blockquote>
<p dir="auto">but not all panels are square or rectangular (i noticed it some hours ago).</p>
]]></description><link>https://community.sketchucation.com/post/1485328</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485328</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Mon, 15 Jun 2015 22:50:15 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 21:00:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aceshigh" aria-label="Profile: aceshigh">@<bdi>aceshigh</bdi></a> said:</p>
<blockquote>
<p dir="auto">Well, maybe using ThomThoms GROUPS TO COMPONENTS followed by COMPONENT DROPPER?</p>
<p dir="auto">EDIT: gee, its your own panelization plugin I was thinking about SDMith!</p>
<p dir="auto">Just need to figure out a way to correctly divide by ceiling single face into quads to place the components there...</p>
<p dir="auto">EDIT 2: tested the panelization plugin.</p>
<p dir="auto">first... instead of multiplying the component and resizing it, it created thousands of different components</p>
<p dir="auto">second... the results were totally unpredictable.</p>
</blockquote>
<p dir="auto">I'm not surprised about unpredictable results especially given varying quad cell sizes.</p>
]]></description><link>https://community.sketchucation.com/post/1485320</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485320</guid><dc:creator><![CDATA[sdmitch]]></dc:creator><pubDate>Mon, 15 Jun 2015 21:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 20:32:38 GMT]]></title><description><![CDATA[<p dir="auto">Well, maybe using ThomThoms GROUPS TO COMPONENTS followed by COMPONENT DROPPER?</p>
<p dir="auto"><img src="http://i.imgur.com/l2YA5jD.jpg" alt="http://i.imgur.com/l2YA5jD.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1485317</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485317</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Mon, 15 Jun 2015 20:32:38 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 19:48:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdmitch" aria-label="Profile: sdmitch">@<bdi>sdmitch</bdi></a> said:</p>
<blockquote>
<p dir="auto">My Ceiling Grid generator could be used as the basis of such a plugin.</p>
<p dir="auto">What are the dimensions of a standard "waffle"?</p>
</blockquote>
<p dir="auto">about 0,8 x 0,8 meters.</p>
<p dir="auto">but your plugin only has I think 3 measurement sizes right (all in Imperial Measurements).</p>
<p dir="auto">Plus, it doesn´t generate components. It would be awesome if those thousands of panels were components, so I could replace it with a "waffle" mold.</p>
<p dir="auto">I could use your 2x2... it´s about 60x60 cm and there are waffle molds that size.</p>
<p dir="auto">But I could swear there was a plugin like Chris Fulmers "Component Onto Faces", but that would resize the components so they would match the face size, wasn´t there? If there was, it could certainly be used to place my mould components unto the faces created by your plugin.</p>
]]></description><link>https://community.sketchucation.com/post/1485312</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485312</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Mon, 15 Jun 2015 19:48:49 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 14:22:52 GMT]]></title><description><![CDATA[<p dir="auto">My Ceiling Grid generator could be used as the basis of such a plugin.</p>
]]></description><link>https://community.sketchucation.com/post/1485291</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485291</guid><dc:creator><![CDATA[sdmitch]]></dc:creator><pubDate>Mon, 15 Jun 2015 14:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 10:26:26 GMT]]></title><description><![CDATA[<p dir="auto">You need fingers and a face to eat waffles. You're both right.</p>
]]></description><link>https://community.sketchucation.com/post/1485266</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485266</guid><dc:creator><![CDATA[Rich O Brien]]></dc:creator><pubDate>Mon, 15 Jun 2015 10:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 10:10:24 GMT]]></title><description><![CDATA[<p dir="auto">LMAO... I just saw how that read...</p>
]]></description><link>https://community.sketchucation.com/post/1485262</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485262</guid><dc:creator><![CDATA[Krisidious]]></dc:creator><pubDate>Mon, 15 Jun 2015 10:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 08:54:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/krisidious" aria-label="Profile: krisidious">@<bdi>krisidious</bdi></a> said:</p>
<blockquote>
<p dir="auto">...you'll have to do a little math on your face.</p>
</blockquote>
<p dir="auto">Could I use my fingers instead? <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
]]></description><link>https://community.sketchucation.com/post/1485258</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485258</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Mon, 15 Jun 2015 08:54:50 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 07:33:47 GMT]]></title><description><![CDATA[<p dir="auto">1001bit tools pro will do it. Although, you'll have to do a little math on your face.</p>
<p dir="auto"><img src="/uploads/imported_attachments/GMY3_1001.JPG" alt="1001.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1485249</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485249</guid><dc:creator><![CDATA[Krisidious]]></dc:creator><pubDate>Mon, 15 Jun 2015 07:33:47 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 02:30:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cotty" aria-label="Profile: cotty">@<bdi>cotty</bdi></a> said:</p>
<blockquote>
<p dir="auto">What's wrong with a component and the array copy function?</p>
<p dir="auto">[attachment=0:1uf4y65z]&lt;!-- ia0 --&gt;comparray.gif&lt;!-- ia0 --&gt;[/attachment:1uf4y65z]</p>
</blockquote>
<p dir="auto">it´s appropriate for simple ceilings... but when you have lots of walls and posts, etc, with borders around, it starts getting complicated to place all components in the correct place. I thought of something more like drawing the shape of the place where you want the components and a plugin to place all the components inside that boundary?</p>
]]></description><link>https://community.sketchucation.com/post/1485247</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485247</guid><dc:creator><![CDATA[AcesHigh]]></dc:creator><pubDate>Mon, 15 Jun 2015 02:30:59 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Mon, 15 Jun 2015 00:16:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pilou" aria-label="Profile: pilou">@<bdi>pilou</bdi></a> said:</p>
<blockquote>
<p dir="auto"><a href="http://sdmitch.blogspot.fr/" target="_blank" rel="noopener noreferrer nofollow ugc">Panelization</a> by Sdmitch ?  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
</blockquote>
<p dir="auto">No, only works on surfaces and not very well.</p>
<p dir="auto">Component Array perhaps.</p>
]]></description><link>https://community.sketchucation.com/post/1485244</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485244</guid><dc:creator><![CDATA[sdmitch]]></dc:creator><pubDate>Mon, 15 Jun 2015 00:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Sun, 14 Jun 2015 21:26:48 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://sdmitch.blogspot.fr/" target="_blank" rel="noopener noreferrer nofollow ugc">Panelization</a> by Sdmitch ?  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=1787be8a233" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
]]></description><link>https://community.sketchucation.com/post/1485241</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485241</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Sun, 14 Jun 2015 21:26:48 GMT</pubDate></item><item><title><![CDATA[Reply to Waffle Slabs... any plugin to help doing those? on Sun, 14 Jun 2015 20:56:06 GMT]]></title><description><![CDATA[<p dir="auto">What's wrong with a component and the array copy function?</p>
<p dir="auto"><img src="/uploads/imported_attachments/ymJq_comparray.gif" alt="comparray.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1485239</link><guid isPermaLink="true">https://community.sketchucation.com/post/1485239</guid><dc:creator><![CDATA[cotty]]></dc:creator><pubDate>Sun, 14 Jun 2015 20:56:06 GMT</pubDate></item></channel></rss>
