    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Vertex Normals... ?
    26 Posts 6 Posters 2.8k Views 6 Watching
    • O Offline
      oajfh
      Hiya all.
      Is there a cheap and easy way to get vertex normals from a mesh, or do I have to do some weighted averaging of the face normals manually ?
      If I'm not mistaken (I could be, but API doc is down for me atm), the PolygonMesh.normal_at method will return the normal of the face it was created from (if it was created from a mesh).
      I'm pretty sure I'm going to need to fiddle with vertex normals at some point, and I'm mildly surprised there isn't any direct way of accessing the vertex normals. Aren't they used internally ?
      Older posts seem to indicate that there isn't a way to access the vertex normals. Perhaps things have changed... ?
        Anton_S
        I'm no expert, but I don't think it would be logical for a vertex to have a normal. It's just a point connecting edges and faces. Of course, the vertex normal could be determined by probably adding the normals of the connected faces. You can start off by using the Sketchup::Vertex.#faces function, which returns all the connected faces.
        • tt_suT Offline
          tt_su
          PolygonMesh will in fact return vector normal. It depend on the edges connected are soft+smooth or note.
          However, not too long ago we followed up on a developer support request where it turned out that the internal vertex normal cache some times was invalid when the mesh was obtained - in which case the normals wasn't what you expected.
          I don't recall the exact detail right now.
          For Vertex Tools, I added a feature to visualize vertex normals, but I wrote my own method to calculate this. This is currently done in Ruby - which isn't the fastest way to compute things. If you need a bulk set of vertices to calculate normals for then a Ruby C extensions might be useful to get some better performance.
          Can you provide some info to what you want to use the vertex normals for and when you are trying to obtain them?
          • sdmitchS Offline
            sdmitch
            @oajfh said:
            Hiya all.
            This seems to work
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            sel.empty? ? ents=ent ; ents=sel
            vrt = []; vertex_and_normal = []
            ents.grep(Sketchup;;Face).each{|f| vrt<<f.vertices}
            vrt.flatten!;vrt.uniq!
            vrt.each{|v|
             nrm = Geom;;Vector3d.new(0,0,0)
             for f in v.faces
              nrm += f.normal
             vertex_and_normal << [v.position,nrm.normalize]
            vertex_and_normal.each{|van|
             ent.add_cline(van[0],van[0].offset(van[1],12))
            http://sdmitch.blogspot.com/
            • O Offline
              oajfh
              Thanks for the replies.
              I don't specifically need the vertex normals in Ruby itself (although visualising them in there would be useful, I suppose). It's for fiddling with stuff like Gouraud shading, amongst other things. But that's outside of Sketchup, so I can write it outside of the Ruby. I don't need them in Sketchup itself.
              It's just that I wouldn't have minded if I didn't need to rewrite such a method myself if it happened to be implemented somewhere already, being inherently lazy πŸ˜„
              Also, sdmitch, your code works fine but doesn't apply any weighting to the faces, which means subdividing a triangle your vertex is in (for example) changes the normal value, which isn't always ideal.
              • tt_suT Offline
                tt_su
                Yea - fully understand. I wish I could say that the PolygonMesh returned a reliable vertex normal, but as it is right now I think there are issues if you happen to query it after the cache is invalidated and generated. (This is a result of Geom::PolygonMesh tapping directly into the polygonmesh we use for triangulation and the vertex normal cache is controlled by SU when it needs it - which can leave the API in the dark... :/)
                • tt_suT Offline
                  tt_su
                  @sdmitch said:
                  This seems to work
                  Have a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=39625
                  • O Offline
                    oajfh
                    Thanks ThomThom, I had seen that thread but was wondering if things had changed.
                    In any case, I'll work on it outside of SU. I don't think there are many people who would need vertex normals while working in SU, since they are mostly used for lighting and rendering (as far as I know, anyway, but I don't know much).
                    However, perhaps a way to recover them in exporters could be useful, I dunno.
                    Also, just in case, could you clarify this statement :
                    "PolygonMesh will in fact return vector normal. It depend on the edges connected are soft+smooth or note."
                    So they do return vertex normals... ? I thought it was a normal linked to the surface. Sorry, I'm confused. I'm not sure I understood what you meant completely, could you possibly expand on it ?
                    [Edit] Never mind, I think I got it. I can recover vertex normals but they might not be reliable for now ?
                    In that case, I guess I will recover Face normals for now.
                    • tt_suT Offline
                      tt_su
                      Sorry - I think I confused polygon meshes normals vs the ones I made up in Vertex Tools (There the faces will contribute to a vertex normal only if the edge separating them is soft-smooth. So that the normal depend on the smoothing of the surface. but the PolygonMesh shouldn't do this.)
                      Yea - exporters do tend to have a need for this. I think they generally are able to use PolygonMesh for this. But I think there was issues for live render engines - which queried the polygonmesh in the middle of operations (at which point the cache might be invalid.) We should have an issue file for this to look into.
                      • O Offline
                        oajfh
                        Ok, thanks.
                        • tt_suT Offline
                          tt_su
                          By the way - what version of SU are you developing in?
                          In SU2015 the polygon_mesh should return correct vertex normal - as we make sure to rebuild the cache if it's invalid when the mesh is built.
                          http://www.sketchup.com/intl/en/developer/docs/releases
                          Fixed a bug where Geom::PolygonMesh.normal_at would not return correct vertex normal if the model was modified in the same processing loop as the script obtaining the PolygonMesh.
                          • O Offline
                            oajfh
                            I'm using SU 2015.
                            I was just confused mostly by the documentation, heh -I'm still a rather inexperienced Ruby and SU coder, and when I wanted to look it up and check the methods the SU doc site was down, so I thought I might as well ask here and learn a little more.
                            If vertex normals can be safely recovered, then perhaps I should use those.
                            Hmm. How would that fare performance-wise ? If I want to recover vertex normals, I probably end up checking vertexes multiple times and making sure I don't get a normal from the same vertex more than once, but on the other hand calculating face normals is faster than calculating weighted vertex normals.
                            • Dan RathbunD Offline
                              Dan Rathbun
                              Face.vertices and Edge.vertices both return an array.
                              You'll likely be concat'ing these returned arrays with a "master" array collection.
                              After stuffing the master array, you can use the Array#uniq! method to remove duplicates, before processing.
                              I'm not here much anymore.
                              • tt_suT Offline
                                tt_su
                                Yea - that's a good point. I don't think you can rely on 100% that the order of the points in PolygonMesh to match the face it came from.
                                If performance is critical I think you will get best results from calculating in C/C++ via A Ruby extension which then only iterates the vertices (though you need to collect that from edges or faces - but collecting that into an std::set or something shouldn't affect your performance too much.). You then do the calculations with native code.
                                • O Offline
                                  oajfh
                                  Thanks for the tips Dan.
                                  My code recovers points rather than vertices from a component (it's based off what Anton_S posted in my topic about PolygonMesh triangulation).
                                  ThomThom, doesn't the add_polygon method simply add any new points at the end of the point array ? That's the behaviour it's exhibited for me so far, so wouldn't applying what Dan said be alright ?
                                  On another note, the vertex normal seems to be local to the transformation the face's parent possesses. It complexifies the recursion somewhat to recover the transformation at that point in the iteration.
                                  I'll just post my code, it'll be clearer for you. Thanks again to the both of you and Anton_S, by the way.
                                  # Original credit ; Anton_S
                                  # Get group/component entities.
                                  # @param [Sketchup;;Group, Sketchup;;ComponentInstance] entity
                                  # @return [Sketchup;;Entities]
                                  def get_entities(entity)
                                  	if entity.is_a?(Sketchup;;ComponentInstance)
                                  		return entity.definition.entities
                                  	else
                                  		return entity.entities
                                  # Get triangular mesh of the group.
                                  # @param [Boolean] recursive Whether to include all the child groups and
                                  #   components.
                                  # @param [Boolean] transform Whether to give points in global coordinates.
                                  # @param [Integer] Keep face counter so as not to mess up normal exporting
                                  # @yield A procedure to determine whether particular child group/component
                                  #   should be considered a part of the collection.
                                  # @yieldparam [Sketchup;;Group, Sketchup;;ComponentInstance] entity
                                  # @yieldreturn [Boolean] Pass true to consider an entity as part of the
                                  #   collection. Pass false to not consider an entity as part of the
                                  #   collection.
                                  # @return [Geom;;PolygonMesh]
                                  def get_triangular_mesh(entity, recursive = true, transform = false,normal_array, &entity_validation)
                                    mesh = Geom;;PolygonMesh.new
                                    if( entity.is_a?(;;Sketchup;;Face)||entity.is_a?(;;Sketchup;;ComponentInstance)||entity.is_a?(;;Sketchup;;Group))
                                  	get_entities(entity).each { |e|
                                  		if e.is_a?(;;Sketchup;;Face)
                                  			e.mesh.polygons.each_index{ |i|
                                  			pts = e.mesh.polygon_points_at(i+1)
                                  			mesh_b = e.mesh 4
                                  			index = mesh.add_polygon(pts) # Note ; index not necessary here
                                  			normal_array << e.normal # add face normal
                                  			#puts "e"
                                  			for k in 1..mesh_b.count_points
                                  				#puts mesh_b.point_at(k) #Not global coordinates
                                  				#puts mesh_b.normal_at(k) #Not global coordinates... ?
                                  			puts "j"
                                  		elsif recursive && (e.is_a?(;;Sketchup;;Group) || e.is_a?(;;Sketchup;;ComponentInstance)) && entity_validation.call(e)
                                  			new_array = []
                                  			mesh2 = get_triangular_mesh(e, true, true, new_array, &entity_validation)
                                  			mesh2.polygons.each_index { |i|
                                  			index = mesh.add_polygon(mesh2.polygon_points_at(i+1))
                                  			normal_array[index] = new_array[i] # Doesn't seem to be overriding previous values
                                  			#counter=counter+1
                                  			#puts counter
                                    mesh.transform!(entity.transformation) if transform
                                    return mesh
                                  group = Sketchup.active_model.selection[0] # Lazy component recovery
                                  #TODO begin end
                                  normal_array = [] # Contains the face normals.
                                  mesh = get_triangular_mesh(group, true, true,normal_array){ |e| true }
                                  puts mesh.points
                                  pt = Geom;;Point3d.new(100,0,0)
                                  mesh.transform!(pt) # Move triangles 100 units on xaxis from original component.
                                  Sketchup.active_model.entities.add_faces_from_mesh(mesh, 0)
                                  #puts mesh.points # translated mesh
                                  It isn't super fast though.
                                  Actually, perhaps the simplest would be to traverse the triangulation a second time ? The generated mesh is all in global coordinates, so the normals would be as well.
                                  I could probably do that as a temporary solution, until performance becomes too critical and I have to do stuff out of Ruby. I'm still prototyping, so I just need a reliable way of recovering the normals for the moment.
                                  • tt_suT Offline
                                    tt_su
                                    PolygonMesh.add_point will add a new point only if there isn't an existing point for the same location (within tolerance). This means it looks up the existing points (which unfortunately is a linear look up.)
                                    PolygonMesh.add_polygon will internally call this same function.
                                    The linear nature of add_point I assume is because internally this class is for use with individual faces - so you're not going to have that many points nor duplicates.
                                    To get max performance when building a PolygonMesh you add all the points first - collecting the indices you get in return. Then add polygons using indices instead of points - this reduce the number of linear lookups.
                                    I usually use a Hash to build a source => polygon_point_index lookup. This can be vertex => index for instance.
                                    • tt_suT Offline
                                      tt_su
                                      Btw - if you build your own PolygonMesh from scratch the vertex normals won't be correct I believe...
                                      • O Offline
                                        oajfh
                                        I'm building it from an existing component, so I'd simply be copying existing normals. Why would the vertex normals be incorrect ?
                                        Also, are you sure about the point to point comparison ? If you create different groups within a component, won't it duplicate the points ? I was getting different results after exploding groups and creating the mesh after making a component out of the exploded ex-groups. So the comparison might not only be coordinate-based.
                                        Thanks for the tip on performance, too. Will come in handy.
                                        • tt_suT Offline
                                          tt_su
                                          If you query mesh.normal_at(i) on a mesh you created yourself (Geom::PolygonMesh.new) vs face.mesh the normals won't be computed for you.
                                          You can observer this in action by inspecting the indices and point count:
                                          <span class="syntaxdefault"><br />mesh&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">PolygonMesh</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxcomment">#<Geom;;PolygonMesh;0x0000000936e850><br /><br /></span><span class="syntaxdefault">index1&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_point</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">1<br /><br />index2&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_point</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">1<br /><br />index3&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_point</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3.5</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">2<br /><br />mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_points<br />2<br /></span>
                                          Or by adding polygons using 3d points:
                                          <span class="syntaxdefault"><br />mesh&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">PolygonMesh</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxcomment">#<Geom;;PolygonMesh;0x0000000a70ec48><br /><br /></span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_polygon</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">),&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">),&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">1<br /><br />mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_polygon</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">),&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">),&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Point3d</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">2<br /><br />mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_polygons<br />2<br /><br />mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_points<br />4<br /></span>
                                          • tt_suT Offline
                                            tt_su
                                            When you explode the coordinates of the vertices are transformed to it's parents - so you will see different values then before they they where local to the component definition.
                                            (Also, entities in model.active_entities) are transformed into global coordinates.)
                                            • 1 / 2
