<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Messy Hatch in Layout]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/imported_attachments/weh2_image001.jpg" alt="image001.jpg" class=" img-fluid img-markdown" />I have been trying to draft some interior elevation for a residential flat. When I was trying to apply a pattern to an area, it appears fine. But when it is linked to Layout, the pattern become messy. Does anyone know why? I have been trying to use different method to fix this but no luck...</p>
]]></description><link>https://community.sketchucation.com/topic/149386/messy-hatch-in-layout</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 16:00:11 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/149386.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Mar 2015 14:35:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Messy Hatch in Layout on Sat, 14 Mar 2015 12:32:42 GMT]]></title><description><![CDATA[<p dir="auto">Oh ya, my content is quite far from the origin. I did not purposely do it but just randomly develop this drawings from some old drawing. Thanks for giving me the advice.</p>
<p dir="auto">I have the 2014 package with me, but when I model in Sketchup I prefer using Sketchup 8 as it is more handy and I have less plugin with it, which can make my computer faster.</p>
<p dir="auto">Thank you very much!</p>
]]></description><link>https://community.sketchucation.com/post/1476159</link><guid isPermaLink="true">https://community.sketchucation.com/post/1476159</guid><dc:creator><![CDATA[auchifai]]></dc:creator><pubDate>Sat, 14 Mar 2015 12:32:42 GMT</pubDate></item><item><title><![CDATA[Reply to Messy Hatch in Layout on Sat, 14 Mar 2015 11:34:04 GMT]]></title><description><![CDATA[<p dir="auto">I received your PM with the LO file. This could be good for others coming along so I'm replying here.</p>
<p dir="auto">Apparently you made changes before sending it because not only was the wood grain hatch not displayed, there was no face to apply it to in the model.</p>
<p dir="auto">I found in the SketchUp file that all those 2D views are over 42.5 kilometers away from the origin. That distance can cause display problems. You should keep the drawing close to the origin.</p>
<p dir="auto">I applied the wood grain hatching from the In Model materials library again and I saw it looks like this:<br />
<img src="/uploads/imported_attachments/mxdG_Materialatdistance.png" alt="With model over 42 Km from origin" title="With model over 42 Km from origin" class=" img-fluid img-markdown" /></p>
<p dir="auto">I moved the drawing to near the origin and the material looks like this:<br />
<img src="/uploads/imported_attachments/21D1_Materialnearorigin.png" alt="Model moved to origin" title="Model moved to origin" class=" img-fluid img-markdown" /></p>
<p dir="auto">And in LayOut after updating the reference and rendering in Hybrid:<br />
<img src="/uploads/imported_attachments/uNpY_InLOaftermove.png" alt="In LO Hybrid render" title="In LO Hybrid render" class=" img-fluid img-markdown" /></p>
<p dir="auto">I'm curious, how did the model get positioned more than 26 miles from the origin to begin with? Also, why is your SketchUp model in V8 and the LO file is version 2014?</p>
]]></description><link>https://community.sketchucation.com/post/1476153</link><guid isPermaLink="true">https://community.sketchucation.com/post/1476153</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Sat, 14 Mar 2015 11:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Messy Hatch in Layout on Wed, 11 Mar 2015 23:07:03 GMT]]></title><description><![CDATA[<p dir="auto">Could you share the LayOut file?</p>
]]></description><link>https://community.sketchucation.com/post/1475842</link><guid isPermaLink="true">https://community.sketchucation.com/post/1475842</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 11 Mar 2015 23:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Messy Hatch in Layout on Wed, 11 Mar 2015 23:04:38 GMT]]></title><description><![CDATA[<p dir="auto">I tried to delete this surface and form a new one but even with this I still fail.  i found some other similar problem in the same file too.  I will try other method to aolve this.  Thanks.</p>
]]></description><link>https://community.sketchucation.com/post/1475841</link><guid isPermaLink="true">https://community.sketchucation.com/post/1475841</guid><dc:creator><![CDATA[auchifai]]></dc:creator><pubDate>Wed, 11 Mar 2015 23:04:38 GMT</pubDate></item><item><title><![CDATA[Reply to Messy Hatch in Layout on Wed, 11 Mar 2015 20:11:28 GMT]]></title><description><![CDATA[<p dir="auto">it's hard to tell exactly from your image but I think Peter is on the right track with multiple faces Z-fighting.</p>
]]></description><link>https://community.sketchucation.com/post/1475815</link><guid isPermaLink="true">https://community.sketchucation.com/post/1475815</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 11 Mar 2015 20:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to Messy Hatch in Layout on Wed, 11 Mar 2015 14:55:04 GMT]]></title><description><![CDATA[<p dir="auto">Is it possible you have two surfaces in that same plane--or a surface right behind it? What rendering setting is  used in LO? Interesting that in general it looks worse in LO.</p>
]]></description><link>https://community.sketchucation.com/post/1475766</link><guid isPermaLink="true">https://community.sketchucation.com/post/1475766</guid><dc:creator><![CDATA[pbacot]]></dc:creator><pubDate>Wed, 11 Mar 2015 14:55:04 GMT</pubDate></item></channel></rss>
