    SketchyPhysics 3.3 (Unofficial Release)
    43 Posts 17 Posters 28.0k Views 17 Watching
      Anton_S
      @RobiBlue According to your log, you have your name as 'UserName' but you should change it to your actual name. If you install SU2014 this path should be automatically created. SU2014 plugins are located in %appdata%
        RobiBue
        @Anton_S yeah, I changed the name when I posted the log. Assume that the UserName is correct.
        I just realized the following entries in the log:
        Error; #<RuntimeError; An error occurred while trying to load Ruby FFI!
        5; Access is denied.   - C;/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
        and therein lied the problem 😞 Norton AV has some weird "insight WS.Reputation.1" score, which quarantines files it thinks are not safe because not many users have reported it as safe, or the developer didn't submit it to their safe-list https://submit.symantec.com/dispute/insight/ which I have done now.
        Sometimes these AV are a PITA but more than that, they save one from a lot of trouble πŸ˜‰
        so far I got SP3.3 working now. πŸ˜„
        Thank you!
          Anton_S
          Very well, although you might want to transfer to SP3.4 : http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936
          • 3 / 3
