    Clone PolygonMesh
    23 Posts 4 Posters 2.4k Views 4 Watching
    • jolranJ
      jolran
      The data has to be stored somewhere. At least for Vray, the properties are stored as an XML structure in the material's attributes.
      Allright!
      Can't say I havent thought about the idea to include this functionality into the plugin,
      to be honest.
      But the risk of feature freenzy and bloat is to big, so I probably stick to only a design/modeling tool.
      Well I think I would be. I mean, this king of UI without zooming is kind of cumbersome, don't you think?
      Yeah, I guess you are right. Come to think of it, you might be even more dependent of "special-nodes", displaying textures and stuff.
      • tt_suT
        tt_su
        For fastest performance of "copying" a PolygonMesh use the number of points and polygons in the new argument. Then populate the points and finally add the polygons with indices.
        I agree that it'd be nice to have .dup and .clone make a fresh copy.
        • jolranJ
          jolran
          Yes, Thanks. I used that and noticed some increase in performance.
          But I have kind of abandoned the PolygonMesh for now. At least during the previewing state.
          I experimented building my own meshclass with indexing of points. Instead of using PolygonMesh class as a Point container.
          Keep arrays of indexes and a Hash containing Points. And the Transformation only deals with the uniq points(Hash) then. Quite a lot of speed improvements!
          The advantage here is that I can reuse the objects somewhat, while I can't purge/clear(?) a PolygonMesh. So the GC should work a little less.
          I'm sure you guys have/are doing something similar or more advanced...
          • 2 / 2
