    Width problems with select option in WebDialog
    23 Posts 6 Posters 1.5k Views 6 Watching
      maricanis
      I'm trying to make WebDialog with nice layout of elements. As one of elements in the dialog I use html element select.
      Since elements should be aligned well, my select controls are wider then text inside them and when user should select one of options, option drop-down looks narrower than select element.
      HTML file opened as WebDialog
      The same file opened in browser looks as expected- when drop-down is opened all options have the same width and selection control
      HTML file opened in Browser
      Here is simple test code
      file_loaded?(__FILE__) #create and show dialog @wd=UI::WebDialog.new("Selection", false, "",300, 190, 300,300, false ) f= File.join(File.dirname(__FILE__),"selection_example.html") if not File.file?(f) UI.messagebox(text,MB_OK,"Dialog definition file #{f} doesn't exist") else @wd.set_file(f) @wd.set_size(300,200) @wd.show() end
      And html code:
      ` <!DOCTYPE html>
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="MSThemeCompatible" content="Yes">
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      </head>
      <body>
      <div class="DL_selection">
      <select style="width:250px" name="season_select" id="season_select">
      <option value="year" id="year_season_select" >year</option>
      <option value="summer" id="summer_season_select">summer</option>
      <option value="autumn" id="autumn_season_select">autumn</option>
      <option value="winter" id="winter_season_select">winter</option>
      <option value="spring" id="spring_season_select">spring</option>
      </select>
      </div>
      </body>
      </html>`
      I've tried various styles changes both in HTML file and in external CSS, but nothing solved the problem.
      Have anyone found this problem before? I couldn't find any solution in old forum posts.
      Ideas for solution?
      Thanks in advance,
      Marija
      • tt_suT Offline
        tt_su
        I've seen that. Something odd with IE10 (maybe newer as well)
        I reported this to the Internet Explorer team, but it got closed as not reproducible. There was no question or any answers to my follow ups. ๐Ÿ˜•
        I gave full instructions with HTML examples, and explicitly said it happened in embedded IE in SketchUp, but alas.
        Try to file a bug yourself and see if you have more success.
          maricanis
          Thanks Thom,
          I'll try to send them bug info, maybe they'll do something this time.
          Any idea how to overcome the problem, maybe to use some custom combo box control or so?
            Aerilius
            <select> elements can appear differently in various browsers (especially if you would want to use CSS on the option elements). There is probably nothing wrong in your implementation, but in the specific browser used.
            Usually the operating system's native controls look native and have besides mouse support also good accessibility for keyboard navigation, screen readers, scroll wheel. They have the behavior that the user expects to work.
            I don't think it is worth the effort to "imitate" a <select> using <div>s for cosmetic reasons that only appear in a minority of browsers. Of course it's another case if you need to do something that is not possible with the native control (including images and small paragraphs in options, etc.).
              maricanis
              Hi Aerilius,
              My code works correctly, selection and everything related to it, only the appearance is not good.
              I tried changing default browser, but if I understood Thom well problem is in embedded IE which is used for WebDialogs internal implementation.
              Anyway, I'll keep it as it is now, since no better solution found.
              Thanks again.
              • tt_suT Offline
                tt_su
                Yes, the user's default browser has no connection to SketchUp's WebDialog. Currently we use the OS's built in framework which is IE under Windows and WebKit under OSX.
                I'd recommend you look at the WebDialog Wiki I compiled if you haven't read it yet:
                https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki/Doctype---Quirks-vs-Standard-vs-Superstandard
                Btw, I just checked on my Win8 machine with IE11 and it's fixed:
                This might just be an IE10 glitch. Annoying visually, but at least it's still fully functional.
                • jolranJ Offline
                  jolran
                   <option value='' disabled selected style='display;none;'>................Choose season.............</option>
                  Placeholder HACK ๐Ÿ˜„
                  You will have to do some testing in JS to eliminate this selected.
                  • tt_suT Offline
                    tt_su
                    That's a very fragile hack... and one that adds a different visual noise - and extra code.
                    Since it's working as it is I would just leave it. Padding with dummy characters with a dummy list item won't ever be able to accurately adjust the length.
                      Aerilius
                      Let's better not use pixel sizes to dimension anything that will contain text.
                      Every box that contains text is better dimensioned with em.
                      • jolranJ Offline
                        jolran
                        Ok.... you liked that hack dident you....How bout this one..
                        <!DOCTYPE html>
                        		<head>
                        		<style>
                        			.DL_selection select {
                        				width;250px;
                        			.op;after { content;"                                       ";}
                        		</style>
                        		</head>
                        		<body>
                        			<select name="season_select" id="season_select">
                        				<option class="op" value="year" id="year_season_select" >year</option>
                        				<option class="op" value="summer" id="summer_season_select">summer</option>
                        				<option class="op" value="autumn" id="autumn_season_select">autumn</option>
                        				<option class="op" value="winter" id="winter_season_select">winter</option>
                        				<option class="op" value="spring" id="spring_season_select">spring</option>
                        			</select>
                        			</div>
                        			</body>
                        		</html>
                        Now since he is using style 250 px for the select element I naturally assumed he wanted that size. Spaces are acurate enough for that.. Wont work dynamically, has to be tested and nudged to liking, so in that sence not accurate..
                        Don't know the output from the select though. Pseudo element should not affect the value...
                        • jolranJ Offline
                          jolran
                          Even SVG text element ?
                          • tt_suT Offline
                            tt_su
                            hmm.... does an explicit 100% width also work?
                            • Dan RathbunD Offline
                              Dan Rathbun
                              FYI using an inline STYLE attribute, kills the META "MSThemeCompatible" feature that is set in the HEAD section.
                              IE:
                              <select ***style="width:250px"*** name="season_select" id="season_select">
                              causes the select control to render like it is in old Windows 3.x.
                              The example above that shows using an inline stylesheet with a class to control width, is a much better way to go.
                              I think that inline STYLE attributes are considered obsolete now.
                              I'm not here much anymore.
                              • jolranJ Offline
                                jolran
                                Really ? ๐Ÿ˜ฎ Did not know that. Yet another reason to avoid inline styling.
                                Dumb question: Do you know if it kills the META just for that particular element or just by using inline style once in the document everything is ruined, if you understand my question.
                                I mainly use classes because it's easier to switch styling just by toggling class on/off..
                                It's difficult to overide that if using inline style or ID selectors.
                                  maricanis
                                  I would avoid any spaces based alignment, because GUI is translated in few languages, and with spaces I can't predict how long it will be in each language.
                                  For styling classes are much better solution, but in example I just wanted to point out that I need some predefined width.
                                  Thanks Dan, I didn't know that inline styles render controls differently than is style is defined in CSS class.
                                  I'm also interested if it kills META for the whole document or just that one control.
                                  Thom, I've just read your link Doctype---Quirks-vs-Standard-vs-Superstandard and it made me completely puzzled. When I include:
                                  <meta http-equiv="X-UA-Compatible" content="IE=8"/>
                                  it renders my GUI completely different then before, and all dialog alignments look crazy.
                                  Must look little bit more into this rendering mode thing.
                                  Is it conflicting in any way with meta tag Dan proposed in one post?
                                  • jolranJ Offline
                                    jolran
                                    Fine, then.
                                    I would stick to IE=edge in the META. Or set specific version of IE.
                                    I use D3.js and it wont launch otherwise since using CSS3 selectors/HTML5.. If you don't. Then you will have to include Sizzle or Html5 Shiv since any library dependent of CSS3 selectors need IE9(?) and up. For Mac don't know..
                                    • tt_suT Offline
                                      tt_su
                                      Are you familiar with the different document modes rendering engines use depending whether the HTML is valid or not? That specific section describes that the IE engine, when embedded is much more conservative and will keep on using an older document mode even if you have a newer IE engine installed. This differ from how the browser version of IE picks the render mode.
                                        maricanis
                                        Frankly, no experience and knowledge about document modes, I've just used the default ones till now.
                                        Any suggested readings on this?
                                        Especially related to embedded vs. browser mode?
                                        Thanks again!
                                          Dan Rathbun
                                          You guys might have to search the Microsoft websites for details.
                                          I think changing certain style attributes of control elements will cancel the OS theme styling for that particular element. And then changing other attributes is OK.
                                          You'll just need to experiment.
                                          Some 3rd party wiki blogs seem to indicate that changing background and border at the document level might cancel the theme styling for the entire document, but I have never had a problem setting the WebDialog background color to match the system dialog background color, and still having controls rendered in the OS theme.
                                          • eneroth3E Offline
                                            eneroth3
                                            Another solution would be to stop using IE and use a real web browser for dialogs for a future SU version. Perhaps pack Gecko or something similar. This would also solve some of the the problems with web dialogs being platform dependent.
                                            My website: http://julia-christina-eneroth.se/
                                            • 1 / 2
