    Upholstered furniture
    328 Posts 54 Posters 194.0k Views 54 Watching
    • alvisA Offline
      alvis
      Leather sofa. The same method with TerrainEroder plugin.
      • alvisA Offline
        alvis
        BLUM armchair
        • soloS Offline
          solo
          Alvis, these are amazing you are truly the furniture master.
          What is the "Fractal Terrain Eroder plugin"? I know of an Erode plugin by Eronoth, is it the same?
          http://www.solos-art.com
          • alvisA Offline
            alvis
            Thank you. I think this is the same plugin.
            • alvisA Offline
              alvis
              Pascal armchair
              [edg3d:3bgmjc20]IpobOyi9fOUn8o5[/edg3d:3bgmjc20]
              • jo-keJ Offline
                jo-ke
                thank you for sharing your workflow. It gets a little more transparent for me to follow.
                You are a real master. I wish I had your skills.
                http://www.zz7.de
                • alvisA Offline
                  alvis
                  Thank JOKE.
                  Next - Riverside Exposed Frame Chair
                  [edg3d:1cma5k7h]LhoMc8BcRMMqyat[/edg3d:1cma5k7h]
                  • K Offline
                    kagealita
                    Alvis,
                    Thank you so much for the step-step instructions & the quick response, your are my guru. Do you mind tell me the plug-in you had used for the above two chairs? I'm using Sketchup 2016.
                    Alita
                    • alvisA Offline
                      alvis
                      I think the main plugin is your brain.
                      All other things being just a tool that helps you. Besides the main Sketchup tools (Line, Arc, Intersect ...), I use a this plugins. They are the best for such a task.
                        Cool plugins indeed! 😎
                        @Alvis
                        Does the flag Blue, White, Red under your avatar is the French one
                        or it's other thing? πŸ˜„
                        • alvisA Offline
                          alvis
                          @Alvis
                          So it was a french motive of my solidarity. If seriously, what happening in other parts of the world (you know what I mean), my heart hurts is also.
                            @Alvis
                            Thx for the explanation and the solidarity! 😎
                            Have you try the Free Su TGI3D ?
                            Seems it's can be used for tortured furnitures! πŸ˜„
                            Manual
                            So crazzy things about Components! 😎
                            http://s6.postimg.org/rcdynmgpd/GIF_instanc.gif
                            • alvisA Offline
                              alvis
                              Chesterfield sofa.
                              chester segment.zip
                              • jo-keJ Offline
                                jo-ke
                                Thank you, makes things better to understand
                                http://www.zz7.de
                                • marked001M Offline
                                  marked001
                                  I love this thread. Even with the instructions, I still don't know how you do it.
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • alvisA Offline
                                    alvis
                                    Contuor sofa
                                    • alvisA Offline
                                      alvis
                                      Simple tufted lounge workflow
                                        Sems very cumfortable! 😎
                                        No armrests ?
                                        • alvisA Offline
                                          alvis
                                          Thanks Pilou. Yes, no armrest. And here final result
                                          • cottyC Offline
                                            cotty
                                            Perfect!
                                            (If you need an address to send an example realisation to someone let me know)
                                            my SketchUp gallery
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
