<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Online model generation using ruby]]></title><description><![CDATA[<p dir="auto">Just treading the water here.<br />
I know all of this is possible offline.<br />
I've been wondering if it would be possible to generate an image of a sketchup model using online input. Eg: A client wants to see what a box would look like if it was 2 meters long am 15 cm wide. Inserts data, clicks generate, bla bla bla, render appears.<br />
And i suppose this would require me to buy a copy of SketchUp Pro, for how much does one go around these days?<br />
I know there must be dozens of other options to do this, but i have next to no experience in web programming, i could easily do it in ruby.</p>
]]></description><link>https://community.sketchucation.com/topic/140438/online-model-generation-using-ruby</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 08:34:46 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/140438.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Mar 2013 10:51:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Online model generation using ruby on Sat, 23 Mar 2013 11:27:41 GMT]]></title><description><![CDATA[<p dir="auto">You wouldn't need the Pro version - free would work.</p>
<p dir="auto">The SketchUp/Ruby side of this won't be too hard. You could simply poll for changes in a file, read in the instructions, draw things, and export an image file from a SU plugin.</p>
<p dir="auto">As far as the server goes, if you do not have one setup you could try installing like <a href="http://www.wampserver.com/en/" target="_blank" rel="noopener noreferrer nofollow ugc">wamp</a> on your local machine for testing.</p>
]]></description><link>https://community.sketchucation.com/post/1384380</link><guid isPermaLink="true">https://community.sketchucation.com/post/1384380</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Sat, 23 Mar 2013 11:27:41 GMT</pubDate></item></channel></rss>
