<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Selecting BY objects and locking parts of objects]]></title><description><![CDATA[<p dir="auto">I'm sure the topic doesn't make much sense so I'll try and explain by way of example..</p>
<p dir="auto">I'm making a pond shape and this is what I was planning:<br />
Start with a flat sandbox grid (20x20m) 0.1m grids.<br />
Draw a complex shoreline on top (outside the group) using the freehand tool.<br />
Copy and paste in place the shoreline into the grid, so it is part of the mesh.</p>
<p dir="auto">Now... I want to select everything in the mesh that is outside of the shoreline object and delete it, and then lock the outside edges of the mesh (i.e. the shoreline) so that the x,y,z position of those vertices doesn't change. Then I can use smoove without fear of mucking up the shoreline elevation.</p>
<p dir="auto">Any pointers?</p>
<p dir="auto">thanks</p>
<ul>
<li>Mick</li>
</ul>
]]></description><link>https://community.sketchucation.com/topic/134540/selecting-by-objects-and-locking-parts-of-objects</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 01:39:37 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/134540.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Apr 2012 04:26:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Selecting BY objects and locking parts of objects on Thu, 19 Apr 2012 07:29:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pbacot" aria-label="Profile: pbacot">@<bdi>pbacot</bdi></a> said:</p>
<blockquote>
<p dir="auto">You can do this. Before pasting in the closed shape to the grid, soften the edges in the grid by selecting all of them and clicking soften coplanar in the smooth/soften window. After you paste in the shape, you'll be able to select the outside and erase it.</p>
</blockquote>
<p dir="auto">Ahhh.. yes of course, I have seen that before - my brain just didn't want to recognise the solution.</p>
<blockquote>
<p dir="auto">I don't know that you can lock the outside edges in this process. I guess you just have to avoid them. Anyone?...</p>
</blockquote>
<p dir="auto">Maybe... and probably not too hard to do but it would be good to know if there is a technique to lock the shoreline in place.</p>
<p dir="auto">Thanks</p>
<ul>
<li>Mick</li>
</ul>
]]></description><link>https://community.sketchucation.com/post/1322850</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322850</guid><dc:creator><![CDATA[sketchymick]]></dc:creator><pubDate>Thu, 19 Apr 2012 07:29:29 GMT</pubDate></item><item><title><![CDATA[Reply to Selecting BY objects and locking parts of objects on Thu, 19 Apr 2012 05:42:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser" aria-label="Profile: unknownuser">@<bdi>unknownuser</bdi></a> said:</p>
<blockquote>
<p dir="auto">... I want to select everything in the mesh that is outside of the shoreline object</p>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1322839</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322839</guid><dc:creator><![CDATA[pbacot]]></dc:creator><pubDate>Thu, 19 Apr 2012 05:42:14 GMT</pubDate></item></channel></rss>
