<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there an easy way to slice a model for 3D printing?]]></title><description><![CDATA[<p dir="auto">Anybody know of an easy way to take a complex model, with multiple components, and slice it into the desired number of pieces for printing in 3D?  I am aware of the slicer ruby plugin, but it does not accomplish what I need.  The ideal would be to say slice a complex model into 2 parts (or more of my choosing of quantity and on which coordinate) and then slice and separate the model, and close the slices to reform a new solid. Thanks, Brian</p>
]]></description><link>https://community.sketchucation.com/topic/134329/is-there-an-easy-way-to-slice-a-model-for-3d-printing</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 21:31:49 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/134329.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 31 Mar 2012 21:31:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Tue, 03 Apr 2012 05:14:39 GMT]]></title><description><![CDATA[<p dir="auto">Great idea to break it by rooms.  I didn't think of that.  FYI, as 3D printing is getting larger, it would be great to have a plug-in that allows you to bind the model as a complete unit, then chop it up however you want.  Just a thought.  Thanks for your help.</p>
]]></description><link>https://community.sketchucation.com/post/1320681</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320681</guid><dc:creator><![CDATA[jbaflyer]]></dc:creator><pubDate>Tue, 03 Apr 2012 05:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Mon, 02 Apr 2012 10:41:29 GMT]]></title><description><![CDATA[<p dir="auto">Seems relatively easy to me.</p>
<p dir="auto">You really need to go around manually dividing the model into say 4 pieces using the wall-lines around rooms as the dividers - a single straight 'chop' will probably produce a messy result where they'd be a cut across the middle of floors.</p>
<p dir="auto">However, if you set up two section-planes, group everything and then use Zorro2 [on 4 <em>copies</em> of the model!] to chop each one twice at the two section-planes [reverse the section-plane[s] for some of these cuts!]... you'd then get the 4 simple 'quarters'...</p>
<p dir="auto">Perhaps treat the roofs differently as separate 'prints' ?</p>
]]></description><link>https://community.sketchucation.com/post/1320680</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320680</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Mon, 02 Apr 2012 10:41:29 GMT</pubDate></item><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Mon, 02 Apr 2012 06:16:13 GMT]]></title><description><![CDATA[<p dir="auto">Here is an attachment of what I was thinking.  You would basically have a floor with clear panes you would never go through, that way you could pull apart the model.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/bZgt_slices.JPG" alt="slices.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1320679</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320679</guid><dc:creator><![CDATA[jbaflyer]]></dc:creator><pubDate>Mon, 02 Apr 2012 06:16:13 GMT</pubDate></item><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Mon, 02 Apr 2012 06:01:52 GMT]]></title><description><![CDATA[<p dir="auto">I believe CADSpan does not work in .3ds which is what I need to export in.  What I am trying to accomplish is to take a finished Sketchup model and slice it into 2,3 or 4 parts for printing.  I have a Zcorp 450 printer and they have their own proprietary software, Zedit Pro, however it butchers the Sketchup model and does not work in .3ds I work in 3ds, because it preserves the Sketchup color.  I tried slicer but got the error.  I grouped all my components, however when I sliced see the error message that came up.  I may be missing something here.  I basically want to take what you see in the .jpg and break it into 4 equal parts.</p>
<p dir="auto">My Zprinter build tray is 10"x10"x8" and breaking it into 4 parts will allow me to create a larger model.  I need to print a 18"x18" model roughly, and in order to do this I need to break the model into pieces.  The only work around I can think of is to literally plan on the final build size and create stopping planes/boundaries so I do not say run a wall "through" its limit, to allow me 3 or 4 pieces.  It could get messy this way.</p>
<p dir="auto">I did build the roof element as a separate part in case you are wondering when you see the pictures.</p>
<p dir="auto">I appreciate your help.  Brian</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/FAMe_SlicerError.JPG" alt="Slicer Error.JPG" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/APQZ_photo11.JPG" alt="photo 1 (1).JPG" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/NrTA_photo21.JPG" alt="photo 2 (1).JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1320678</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320678</guid><dc:creator><![CDATA[jbaflyer]]></dc:creator><pubDate>Mon, 02 Apr 2012 06:01:52 GMT</pubDate></item><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Sun, 01 Apr 2012 10:25:17 GMT]]></title><description><![CDATA[<p dir="auto">I wonder if he's talking about the slices that 3D printers put down in order to produce a model? In which case there's no need to slice up the model at all as something like CADspan should do the trick.</p>
]]></description><link>https://community.sketchucation.com/post/1320677</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320677</guid><dc:creator><![CDATA[Hieru]]></dc:creator><pubDate>Sun, 01 Apr 2012 10:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to Is there an easy way to slice a model for 3D printing? on Sun, 01 Apr 2012 09:33:00 GMT]]></title><description><![CDATA[<p dir="auto">Why <em>won't</em> 'Slicer5' do what you want ?<br />
Group the components and it'll slice them.<br />
It's very flexible, making the slice_thickness=spacing leaves no 'gaps' etc...<br />
I don't fully understand what you've said...<br />
Do you want to cut a piece out of a model and close up the gap and 'heal' it ?<br />
With complex forms it will be weird... You could do it with Slicer...<br />
Erase a mid-slice and move the others up so they touch, and close the gap.<br />
Then edit the now touching pieces so that they have aligned vertices again [where possible].<br />
Then you can explode the slice-instances into a single new group.<br />
It won't be 'solid' because of the slice-inner-faces etc.<br />
You could edit each instance [before the explode] and erase these inner faces.<br />
The final group could be made solid using SolidSolver...</p>
]]></description><link>https://community.sketchucation.com/post/1320676</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320676</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Sun, 01 Apr 2012 09:33:00 GMT</pubDate></item></channel></rss>
