<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Style warning dialog box tick in Preferences not working]]></title><description><![CDATA[<p dir="auto">In Preferences &gt; General, at the bottom, there is a checkbox to "warn of style changes when creating scenes". If that is checked, a dialog should pop up every time you change the style to create new scene without affecting existing scenes.  I have checked this box and the warning does not appear.  Instead, a new scene is created and the dimension layer that is new to the scene is applied to existing scenes that have different dimension layers.  I have to go back into the existing scenes, turn off the new dimension layer and update each scene.  I removed sketchup and reinstalled with no luck.  I am using sketchup v8, free version, on XP.  Any thoughts?   Much appreciated....  Keith</p>
]]></description><link>https://community.sketchucation.com/topic/134315/style-warning-dialog-box-tick-in-preferences-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 07:20:43 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/134315.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Apr 2012 13:21:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Style warning dialog box tick in Preferences not working on Mon, 09 Apr 2012 17:36:25 GMT]]></title><description><![CDATA[<p dir="auto">I figured I was overlooking something.  In any event, thank you both for clearing up the issues and thanks for the script reference.  This is the best modeling software! <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://community.sketchucation.com/post/1320856</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320856</guid><dc:creator><![CDATA[KeithfDiaz]]></dc:creator><pubDate>Mon, 09 Apr 2012 17:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Style warning dialog box tick in Preferences not working on Mon, 09 Apr 2012 05:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Layer visibility is not a style setting so do not expect that dialog to pop up. Change something in the style (like turn hidden geometry on) and create a new scene to see it in action.</p>
]]></description><link>https://community.sketchucation.com/post/1320737</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320737</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Mon, 09 Apr 2012 05:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to Style warning dialog box tick in Preferences not working on Sun, 08 Apr 2012 18:05:09 GMT]]></title><description><![CDATA[<p dir="auto">When you make a new layer using the Layer Browser '+', then by default it is 'on' in all scenes.<br />
If you want to make a new layer that is 'on' in the current scene but 'off' in all others, use a script like this... <a href="http://forums.sketchucation.com/viewtopic.php?p=322291#p322291" target="_blank" rel="noopener noreferrer nofollow ugc">http://forums.sketchucation.com/viewtopic.php?p=322291#p322291</a><br />
As the new layer name matches the tab's it's easy to find and rename in the Layer Browser.<br />
You only need to update the current scene-tab...</p>
]]></description><link>https://community.sketchucation.com/post/1320645</link><guid isPermaLink="true">https://community.sketchucation.com/post/1320645</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Sun, 08 Apr 2012 18:05:09 GMT</pubDate></item></channel></rss>
