<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Vray bug! HELP]]></title><description><![CDATA[<p dir="auto">Hello, I am very new here. I have been using VRAY+sketchup for a while, recently I encounter one issue. That i could only render my model with local GI or daylight, if I add some artificial lights such as rectangular lights or spot lights to enhance the shadow effect, VRAY simply just won't render the scene. My model usually is about 60mb to 100mb. I have tried with smily geometry it worked. But with complicated texture and modelling it is just not working. Once I turn off all my artificial light it will render. I also tried save it as Vrayimage, EXR, but it won't render at all. Even I have turned BFV off to use no memory. I am working on this job which is due next thursday, please help. I am using SU 8pro in Mac OS (Lion or snow leopard) for modelling, then win 7 for SU 8pro (not latest version) plus latest version VRAY to add lights and adjust settings with latest iMac.</p>
]]></description><link>https://community.sketchucation.com/topic/134190/vray-bug-help</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 15:16:36 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/134190.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 31 Mar 2012 15:42:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Vray bug! HELP on Mon, 02 Apr 2012 13:58:38 GMT]]></title><description><![CDATA[<p dir="auto">Computer Specs? VR version? SU version? How many/what kind of lights? You should be able to render a 60MB file.</p>
]]></description><link>https://community.sketchucation.com/post/1319533</link><guid isPermaLink="true">https://community.sketchucation.com/post/1319533</guid><dc:creator><![CDATA[valerostudio]]></dc:creator><pubDate>Mon, 02 Apr 2012 13:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to Vray bug! HELP on Mon, 02 Apr 2012 01:17:08 GMT]]></title><description><![CDATA[<p dir="auto">sounds like you are running out of memory. That's just a limitation, not particularly a bug. Try to reduce the complexity of your model if you can, and also make sure your textures are not too high resolution (like anything over 2000px wide) - as that eats away at memory significantly.</p>
]]></description><link>https://community.sketchucation.com/post/1319458</link><guid isPermaLink="true">https://community.sketchucation.com/post/1319458</guid><dc:creator><![CDATA[andybot]]></dc:creator><pubDate>Mon, 02 Apr 2012 01:17:08 GMT</pubDate></item></channel></rss>
