<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[{Req] Hide Solids]]></title><description><![CDATA[<p dir="auto">I have many components/files that were created before the solid tools in the new versions of Sketchup. I am going back to each file, with the intent of making all the parts solid. Which has turned out to be harder than I though it should be.</p>
<p dir="auto">So my request, is there a one line code that I can use, that if I select a group/component and if the selected group/component is a solid, it is hidden. Such that I can by using this one line, make selections, and after multiple selection, have only non solids left. And I can go to each remaining non-solid part and either try the repair solids plugins or remodel the part.</p>
<p dir="auto">I need all solids because I am going back to figure out the weight of each model.</p>
<p dir="auto">Thank you in advance for your help.</p>
<p dir="auto">Ken</p>
]]></description><link>https://community.sketchucation.com/topic/133663/req-hide-solids</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 07:59:21 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/133663.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Mar 2012 20:44:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to {Req] Hide Solids on Tue, 06 Mar 2012 19:46:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello Ken,<br />
thank you for the review and "approval" of the new feature of the SuSolid plugin.<br />
And most of all, thanks for the great idea.<br />
Now I have updated the <strong>free</strong> version of the plugin on my site <a href="http://www.SuSolid.com" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.SuSolid.com</a></p>
<p dir="auto">How to use the new "Hide Solids" feature:<br />
<a href="http://1.In" target="_blank" rel="noopener noreferrer nofollow ugc">1.In</a> "Settings" menu set the "Hide Solids" to "Yes".<br />
2.Now when you click the "Analise" tool (or any solid repair tool) you will still see the magenta colored solids,but when exit the tool or re-click it,the solids will hide.<br />
<a href="http://3.To" target="_blank" rel="noopener noreferrer nofollow ugc">3.To</a> unhide solids,just set the "Hide Solids" to "No" and the solids will unhide.</p>
]]></description><link>https://community.sketchucation.com/post/1314658</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314658</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Tue, 06 Mar 2012 19:46:29 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Tue, 06 Mar 2012 18:04:02 GMT]]></title><description><![CDATA[<p dir="auto">David</p>
<p dir="auto">Thank for updating your plugin. The new "hide solid" is great for taking apart old models component/group by component/group that were not made correctly (solid) when first modeled.</p>
<p dir="auto">Now I can cycle thought a project and make sure each and every part/component/group that should be a solid is solid. Not only does the plugin now hide parts that are solid, it give you and opportunity to correct each non solid.</p>
<p dir="auto">Again thank you for the fast reply.</p>
<p dir="auto">Hope everyone enjoys the new feature.</p>
]]></description><link>https://community.sketchucation.com/post/1314634</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314634</guid><dc:creator><![CDATA[ken]]></dc:creator><pubDate>Tue, 06 Mar 2012 18:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Mon, 05 Mar 2012 20:20:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello Ken,<br />
I have sent to your email the version with your "Hide Solids" feature.<br />
Please test it and if you confirm it, I will include it also in free version of SuSolid plugin, so everybody can benefit from your idea <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
<p dir="auto"><a href="http://p.s.it" target="_blank" rel="noopener noreferrer nofollow ugc">p.s.it</a> would be better if you rename this thread to something more specific.Suggestion:"Hide Solids" <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /><br />
Edit: done TIG <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f62e.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--open_mouth" style="height:23px;width:auto;vertical-align:middle" title=":open_mouth:" alt="😮" /></p>
]]></description><link>https://community.sketchucation.com/post/1314442</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314442</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Mon, 05 Mar 2012 20:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Mon, 05 Mar 2012 00:27:23 GMT]]></title><description><![CDATA[<p dir="auto">Darn, I am overwhelmed.</p>
<p dir="auto">Seems the solution is at hand.</p>
<p dir="auto">voljanko, thank you for your reply and plugins.</p>
<p dir="auto">TIG, thank you for your code. Every day a little bit more on the Sketchup ruby learning curve.</p>
]]></description><link>https://community.sketchucation.com/post/1314260</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314260</guid><dc:creator><![CDATA[ken]]></dc:creator><pubDate>Mon, 05 Mar 2012 00:27:23 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 22:48:53 GMT]]></title><description><![CDATA[<p dir="auto">The last code only works on 'active_entities', as you can already hide everything outside of the current edit context using view settings...<br />
BUT to hide/show absolutely everything 'solid' both in the model and nested inside groups and definitions use these two one-liners...</p>
<pre><code>m=Sketchup.active_model;m.entities.each{|e|e.hidden=true if e.respond_to?(;manifold?) and e.manifold?};m.definitions.each{|d|next if d.image?;d.entities.each{|e|e.hidden=true if e.respond_to?(;manifold?) and e.manifold?}}
</code></pre>
<p dir="auto">and</p>
<pre><code>m=Sketchup.active_model;m.entities.each{|e|e.hidden=false if e.respond_to?(;manifold?) and e.manifold?};m.definitions.each{|d|next if d.image?;d.entities.each{|e|e.hidden=false if e.respond_to?(;manifold?) and e.manifold?}}
</code></pre>
]]></description><link>https://community.sketchucation.com/post/1314247</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314247</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Sun, 04 Mar 2012 22:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 22:43:12 GMT]]></title><description><![CDATA[<p dir="auto">Hello Tig.<br />
What about nested solids?</p>
]]></description><link>https://community.sketchucation.com/post/1314245</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314245</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Sun, 04 Mar 2012 22:43:12 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 22:40:11 GMT]]></title><description><![CDATA[<p dir="auto">Two one-liners to copy/paste into the Ruby Console +&lt;enter&gt; to run them...<br />
To hide all active solids</p>
<pre><code>Sketchup.active_model.active_entities.each{|e|e.hidden=true if e.respond_to?(;manifold?) and e.manifold?}
</code></pre>
<p dir="auto">To show all active solids</p>
<pre><code>Sketchup.active_model.active_entities.each{|e|e.hidden=false if e.respond_to?(;manifold?) and e.manifold?}
</code></pre>
<p dir="auto"><img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f913.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--nerd_face" style="height:23px;width:auto;vertical-align:middle" title=":nerd_face:" alt="🤓" /></p>
]]></description><link>https://community.sketchucation.com/post/1314244</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314244</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Sun, 04 Mar 2012 22:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 22:34:46 GMT]]></title><description><![CDATA[<p dir="auto">I have made it and tested it a little and is a very useful feature.The only thing that I miss is a good "UNHIDE ALL" button.<br />
Tomorrow I will send you the version of SuSolid plugin with the "Hide Solids" option in Settings menu.</p>
]]></description><link>https://community.sketchucation.com/post/1314242</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314242</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Sun, 04 Mar 2012 22:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 21:34:25 GMT]]></title><description><![CDATA[<p dir="auto">Hmm,not a bad idea. <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=e3ff0b7518f" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://community.sketchucation.com/post/1314235</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314235</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Sun, 04 Mar 2012 21:34:25 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 21:26:55 GMT]]></title><description><![CDATA[<p dir="auto">Your plugin indicates there is a problem. However, with many parts nested, it is hard to tell just which part is not solid. I just wanted to drill down by selection and every time I hit a solid it disappears leaving me with just non solids. Now that I have a less complicated model, I can use the plugins designed to handle non-solids to make the required corrections.</p>
<p dir="auto">Thank you for your reply.</p>
]]></description><link>https://community.sketchucation.com/post/1314232</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314232</guid><dc:creator><![CDATA[ken]]></dc:creator><pubDate>Sun, 04 Mar 2012 21:26:55 GMT</pubDate></item><item><title><![CDATA[Reply to {Req] Hide Solids on Sun, 04 Mar 2012 21:14:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello Ken,<br />
do you have any difficulties to do this job with the SuSolid plugin?<br />
The only difference is that the solid is pink and not hidden.</p>
]]></description><link>https://community.sketchucation.com/post/1314231</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314231</guid><dc:creator><![CDATA[voljanko]]></dc:creator><pubDate>Sun, 04 Mar 2012 21:14:06 GMT</pubDate></item></channel></rss>
