<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem layout windows hidden lines]]></title><description><![CDATA[<p dir="auto">how i can insert more one window in layout?<br />
i want display my view as hidden lines ------- i go into my sketchup model and set styles as hidden lines but i don't see in layout any change why?</p>
]]></description><link>https://community.sketchucation.com/topic/133624/problem-layout-windows-hidden-lines</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 00:02:58 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/133624.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Mar 2012 11:15:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem layout windows hidden lines on Sun, 04 Mar 2012 11:05:20 GMT]]></title><description><![CDATA[<p dir="auto">ok thnaks very much</p>
]]></description><link>https://community.sketchucation.com/post/1314145</link><guid isPermaLink="true">https://community.sketchucation.com/post/1314145</guid><dc:creator><![CDATA[jim78b]]></dc:creator><pubDate>Sun, 04 Mar 2012 11:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to Problem layout windows hidden lines on Fri, 02 Mar 2012 17:54:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jim78b" aria-label="Profile: jim78b">@<bdi>jim78b</bdi></a> said:</p>
<blockquote>
<p dir="auto">I DON'T UNDERSTAND why don't display me some hidden lines, so i explode model and set it dashed</p>
</blockquote>
<p dir="auto">As stated above, you need to save a scene with hidden lines shown, make sure the scene is updated to reflect the hidden lines, then save the SU file.  Then in layout update the reference, select the same scene and render.  It will show the hidden lines.  If the scene selection is set to "last saved", then it will not work.  Select the same scene from the SU model that you updated prior to the last save.</p>
]]></description><link>https://community.sketchucation.com/post/1313960</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313960</guid><dc:creator><![CDATA[sonder]]></dc:creator><pubDate>Fri, 02 Mar 2012 17:54:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem layout windows hidden lines on Fri, 02 Mar 2012 14:46:09 GMT]]></title><description><![CDATA[<p dir="auto">I DON'T UNDERSTAND why don't display me some hidden lines, so i explode model and set it dashed</p>
]]></description><link>https://community.sketchucation.com/post/1313918</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313918</guid><dc:creator><![CDATA[jim78b]]></dc:creator><pubDate>Fri, 02 Mar 2012 14:46:09 GMT</pubDate></item><item><title><![CDATA[Reply to Problem layout windows hidden lines on Fri, 02 Mar 2012 12:21:39 GMT]]></title><description><![CDATA[<p dir="auto">If you change the style (and hidden line is a face style setting), you need to update your style and scene before it takes effect in LO (in your style dialog, when you change a style, there will be two circular arrows which you need to press to update it).</p>
<p dir="auto">If you only want one scene (which will be one inserted viewport in LO) to have this style, make sure to have the corresponding (and updated) style assigned only to this scene (there can be several styles in your SU model)</p>
<p dir="auto">Then save our SU model, in LO, select the proper scene (not "last saved..."), right click on the model and "Update reference"</p>
]]></description><link>https://community.sketchucation.com/post/1313882</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313882</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Fri, 02 Mar 2012 12:21:39 GMT</pubDate></item></channel></rss>
