<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Remove inside faces?]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/imported_attachments/ld6q_SketchUpSnapz001.jpeg" alt="SketchUpSnapz001.jpeg" class=" img-fluid img-markdown" />hi, i had ask this for a long time ago.</p>
<p dir="auto">how i can remove inside faces via plugin?</p>
<p dir="auto">all red face i would delete.</p>
<p dir="auto">the outershell tool isn´t the right tool for this.</p>
<p dir="auto">thank you</p>
<p dir="auto">dean</p>
]]></description><link>https://community.sketchucation.com/topic/133364/remove-inside-faces</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 05:40:14 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/133364.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Feb 2012 06:35:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Remove inside faces? on Fri, 02 Mar 2012 16:35:23 GMT]]></title><description><![CDATA[<p dir="auto">I'm thinking that perhaps he's not combining the parts - which then renders it all but impossible to remove the 'internal elements' as the parts aren't even solid to start with...<br />
If it is one group and some simple preliminary erasing is done using Xray Mode, tools like SolidSolver WILL fix it and make it 'solid'...<img src="/uploads/imported_attachments/07Q3_Capture.PNG" alt="Capture.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1313939</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313939</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Fri, 02 Mar 2012 16:35:23 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Fri, 02 Mar 2012 13:20:56 GMT]]></title><description><![CDATA[<p dir="auto">TIG. My guess what Deaneau want's to do is removing "inside faces"(red faces on pic) on non-solid geometry. Am I Wrong?</p>
<p dir="auto">Which can be a difficult feat..</p>
]]></description><link>https://community.sketchucation.com/post/1313898</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313898</guid><dc:creator><![CDATA[jolran]]></dc:creator><pubDate>Fri, 02 Mar 2012 13:20:56 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Fri, 02 Mar 2012 10:49:01 GMT]]></title><description><![CDATA[<p dir="auto">Can you post the SKP...<br />
I'm unsure about what is is you are seeking to do, to what objects...<br />
<img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
]]></description><link>https://community.sketchucation.com/post/1313855</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313855</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Fri, 02 Mar 2012 10:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Fri, 02 Mar 2012 00:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tig" aria-label="Profile: tig">@<bdi>tig</bdi></a> said:</p>
<blockquote>
<p dir="auto">The big red 'Plugins Index' button just above where you are reading this  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /> , then use your Browser's search-facilities [typically Ctrl_F] on the page to find say 'solid'...</p>
</blockquote>
<p dir="auto">thank you TIG to guide me, however the plugins above will not doing this. what i doing wrong?</p>
]]></description><link>https://community.sketchucation.com/post/1313790</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313790</guid><dc:creator><![CDATA[deaneau]]></dc:creator><pubDate>Fri, 02 Mar 2012 00:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Thu, 01 Mar 2012 15:11:58 GMT]]></title><description><![CDATA[<p dir="auto">The big red 'Plugins Index' button just above where you are reading this  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /> , then use your Browser's search-facilities [typically Ctrl_F] on the page to find say 'solid'...</p>
]]></description><link>https://community.sketchucation.com/post/1313669</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313669</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Thu, 01 Mar 2012 15:11:58 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Thu, 01 Mar 2012 14:43:04 GMT]]></title><description><![CDATA[<p dir="auto">hello could you guide me to the downloads?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/orangutan" aria-label="Profile: orangutan">@<bdi>orangutan</bdi></a> said:</p>
<blockquote>
<p dir="auto">Try to use remove_inner_faces, fixsolid or solidsolver or all of them  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /> . These are very good tools but sometimes is better to do it manually. In this case use solidinspector and pickit, these are very helpful. But all these great tools can't do it in one click for you. Sorry for my English.</p>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1313661</link><guid isPermaLink="true">https://community.sketchucation.com/post/1313661</guid><dc:creator><![CDATA[deaneau]]></dc:creator><pubDate>Thu, 01 Mar 2012 14:43:04 GMT</pubDate></item><item><title><![CDATA[Reply to Remove inside faces? on Sat, 18 Feb 2012 09:46:53 GMT]]></title><description><![CDATA[<p dir="auto">Try to use remove_inner_faces, fixsolid or solidsolver or all of them  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /> . These are very good tools but sometimes is better to do it manually. In this case use solidinspector and pickit, these are very helpful. But all these great tools can't do it in one click for you. Sorry for my English.</p>
]]></description><link>https://community.sketchucation.com/post/1311179</link><guid isPermaLink="true">https://community.sketchucation.com/post/1311179</guid><dc:creator><![CDATA[Orangutan]]></dc:creator><pubDate>Sat, 18 Feb 2012 09:46:53 GMT</pubDate></item></channel></rss>
