<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVE][SU8] Trouble spotlight pointlight with kerkythea]]></title><description><![CDATA[<p dir="auto">Hi everyone, I'm french user and English is not my speciality so sorry for mistake.</p>
<p dir="auto">My trouble deal with the render into Kerkythea of my scene including spotlight ; which are KT spotlight component.<br />
So as you can see in the picture below, the spot is lighting but not the hot point of the spot (where is the bulb).</p>
<p dir="auto">So how can I set it lighting like a real one ?</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/tqPz_troublesoptlight.jpg" alt="trouble sopt light.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/133194/solve-su8-trouble-spotlight-pointlight-with-kerkythea</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 21:08:08 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/133194.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Feb 2012 21:20:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Sun, 12 Feb 2012 09:33:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/toto85980" aria-label="Profile: toto85980">@<bdi>toto85980</bdi></a> said:</p>
<blockquote>
<p dir="auto">which I place into my spotlight component and behind the glass ; and I got the render I'm looking for, but the Kerkythea render take more time. I'll shared my skp component if you have any idea to perform my render ... I don't know how to set a fake emit light material on my object.</p>
<p dir="auto">[attachment=2:3tb4kf8q]&lt;!-- ia2 --&gt;spotlightsample.jpg&lt;!-- ia2 --&gt;[/attachment:3tb4kf8q]</p>
</blockquote>
<p dir="auto">If you put a light behind the glass, glass will turn light to caustic light, that will render quite lot slower. Please read trough Kerkythea tutorials at <a href="http://www.kerkythea.net/forum/viewtopic.php?f=16&amp;t=5720" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.kerkythea.net/forum/viewtopic.php?f=16&amp;t=5720</a> They will guide you trough the basics.</p>
]]></description><link>https://community.sketchucation.com/post/1309768</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309768</guid><dc:creator><![CDATA[notareal]]></dc:creator><pubDate>Sun, 12 Feb 2012 09:33:04 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Sat, 11 Feb 2012 23:49:32 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your help ... I finally set a fake emitter material.</p>
]]></description><link>https://community.sketchucation.com/post/1309737</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309737</guid><dc:creator><![CDATA[toto85980]]></dc:creator><pubDate>Sat, 11 Feb 2012 23:49:32 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Sat, 11 Feb 2012 07:31:01 GMT]]></title><description><![CDATA[<p dir="auto">I don't have SU8 so I can't open your files. Anyway here is the way for setting fake emitters.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/uJLZ_Cattura_1.JPG" alt="Cattura_1.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1309595</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309595</guid><dc:creator><![CDATA[massimo]]></dc:creator><pubDate>Sat, 11 Feb 2012 07:31:01 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Fri, 10 Feb 2012 23:42:52 GMT]]></title><description><![CDATA[<p dir="auto">thanks for your reply, but I'm using a self-made component which modelize a builting spotlight. So I can't cut the intersection beetwen the ceiling and the KT spotlight. I realy want to keep the KT spotlight into my component to easly change the position of the object.<br />
So I set a KT pointlight additionnaly of the KT spotlight, which I place into my spotlight component and behind the glass ; and I got the render I'm looking for, but the Kerkythea render take more time. I'll shared my skp component if you have any idea to perform my render ... I don't know how to set a fake emit light material on my object.</p>
<p dir="auto"><img src="/uploads/imported_attachments/dgRk_spotlightsample.jpg" alt="The render with pointlight inside spolight" title="The render with pointlight inside spolight" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><a href="/uploads/imported_attachments/qp10_Untitled.skp">My testing project</a></p>
<hr />
<p dir="auto"><a href="/uploads/imported_attachments/FCOE_SpotLight.skp">My spotlight component</a></p>
]]></description><link>https://community.sketchucation.com/post/1309554</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309554</guid><dc:creator><![CDATA[toto85980]]></dc:creator><pubDate>Fri, 10 Feb 2012 23:42:52 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Fri, 10 Feb 2012 04:46:13 GMT]]></title><description><![CDATA[<p dir="auto">i don't know if it's necessary to place the spotlight into the ceiling there.<br />
thank you for the info massimo</p>
<p dir="auto">i made this for a friend. put the spotlight components outside the lighting components.<br />
change the lighting component's surface with fake emitter.</p>
<p dir="auto"><img src="/uploads/imported_attachments/p2MA_201201C.jpg" alt="201201 C.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1309381</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309381</guid><dc:creator><![CDATA[irwanwr]]></dc:creator><pubDate>Fri, 10 Feb 2012 04:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Thu, 09 Feb 2012 22:35:45 GMT]]></title><description><![CDATA[<p dir="auto">I did not even think of the components not cutting the ceiling, sorry.</p>
<p dir="auto">Toto: have you placed them onto a grouped ceiling? They should go straight on a bare face (I think they are set to auto-cut a face)</p>
]]></description><link>https://community.sketchucation.com/post/1309332</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309332</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Thu, 09 Feb 2012 22:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Thu, 09 Feb 2012 22:33:52 GMT]]></title><description><![CDATA[<p dir="auto">I don't know exactly which component are you using. Anyway a first step you can do is this: select all the light components + select the ceiling--&gt;right click--&gt;intersect selected. Then erase the portions of the ceiling onto the components. Most KT's light components are made with a metal inside so it should render well (see the picture below). Gai's suggestion is maybe the next step. <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/51SW_lights.jpg" alt="lights.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1309330</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309330</guid><dc:creator><![CDATA[massimo]]></dc:creator><pubDate>Thu, 09 Feb 2012 22:33:52 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVE][SU8] Trouble spotlight pointlight with kerkythea on Thu, 09 Feb 2012 22:00:16 GMT]]></title><description><![CDATA[<p dir="auto">Light are actually only light sources, not really visible lights. You could turn those lights (the glass part) into a "fake emitter" and this way pretend as if they are emitting the light. Fake emitters only appear to be emitting light therefore they do not contribute too much in rendering time.</p>
]]></description><link>https://community.sketchucation.com/post/1309317</link><guid isPermaLink="true">https://community.sketchucation.com/post/1309317</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Thu, 09 Feb 2012 22:00:16 GMT</pubDate></item></channel></rss>
