<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Animated Update Rotation wrong way]]></title><description><![CDATA[<p dir="auto">I have an animation driven by AnimatedUpdate. If the model has a heading of 358 degrees and I do an animatedupdate to change the heading to 2 degrees, the model spins round anticlockwise by 356 degrees instead of rotating clockwise by 4 degrees. How do I change that behaviour please?</p>
]]></description><link>https://community.sketchucation.com/topic/132857/animated-update-rotation-wrong-way</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 11:39:13 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/132857.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Jan 2012 06:24:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Animated Update Rotation wrong way on Wed, 25 Jan 2012 11:04:46 GMT]]></title><description><![CDATA[<p dir="auto">I did find that I could overcome it by just getting bigger and bigger with the angles. ie. specifying 352 degrees say, then 380 degrees, then 420 degrees etc. It seems to work.</p>
<p dir="auto">But I actually used a suggestion Aerilius made, which was to get to 359, then do a change to 0 with a duration of 0 so it spun anticlockwise infinitely fast, then carried on with 20 degrees, 80 degrees etc. That also works.</p>
<p dir="auto">But it is all a fudge. Surely there is some way of forcing the rotation to the desired direction.</p>
]]></description><link>https://community.sketchucation.com/post/1305653</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305653</guid><dc:creator><![CDATA[pmolsen]]></dc:creator><pubDate>Wed, 25 Jan 2012 11:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to Animated Update Rotation wrong way on Wed, 25 Jan 2012 10:30:47 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried my suggestions for -ve angle values or &gt; +360 etc <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
]]></description><link>https://community.sketchucation.com/post/1305648</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305648</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Wed, 25 Jan 2012 10:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to Animated Update Rotation wrong way on Wed, 25 Jan 2012 10:15:14 GMT]]></title><description><![CDATA[<p dir="auto">See AnimatedUpdate, Change and Update at<br />
<a href="http://code.google.com/apis/kml/documentation/kmlreference.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://code.google.com/apis/kml/documentation/kmlreference.html</a></p>
<p dir="auto">(If you can figure it out from there good luck!)</p>
]]></description><link>https://community.sketchucation.com/post/1305643</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305643</guid><dc:creator><![CDATA[pmolsen]]></dc:creator><pubDate>Wed, 25 Jan 2012 10:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to Animated Update Rotation wrong way on Wed, 25 Jan 2012 09:21:47 GMT]]></title><description><![CDATA[<p dir="auto">I don't know the tool, but the standard rotation rule is +ve angles rotate anticlockwise about the axis of rotation.<br />
Entering +2 tells it to swing from 358 round to 2 anticlockwise !<br />
If you enter a value like -4 OR +362 degrees what happens, does the rotation reverse to clockwise ?<br />
Is there no a way to specify the required swept-angle rather than the absolute-angle  <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=6529dfcbe5e" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
]]></description><link>https://community.sketchucation.com/post/1305633</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305633</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Wed, 25 Jan 2012 09:21:47 GMT</pubDate></item></channel></rss>
