<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Follow me problems]]></title><description><![CDATA[<p dir="auto">Hi, I am trying to draw a metal dish plate that is pressed and has radiused corners.  I tried to draw this using a rectangular block, extruding and then using 'Round Corner' plug-in but the file ended up huge.</p>
<p dir="auto">So I tried 'follow me' after laying out the basic rectangle to follow plus the plate shape - with the aim to 'pencil' the inside to fill the bottom inside and back of the dish.</p>
<p dir="auto">However whilst it was almost successful, here's what happened - first pic shows the shape, the path to follow and the overall result<br />
<a href="http://imageshack.us/photo/my-images/23/dishtrial1.jpg/" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="http://img23.imageshack.us/img23/403/dishtrial1.jpg" alt="http://img23.imageshack.us/img23/403/dishtrial1.jpg" class=" img-fluid img-markdown" /><br />
</a></p>
<p dir="auto">The problem is obvious that in the corners there are gaps in the surfaces.  I used smooth edges and tride to fix it from there but to no avail.</p>
<p dir="auto"><a href="http://imageshack.us/photo/my-images/252/dishtrial3.jpg/" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="http://img252.imageshack.us/img252/5946/dishtrial3.jpg" alt="http://img252.imageshack.us/img252/5946/dishtrial3.jpg" class=" img-fluid img-markdown" /><br />
</a></p>
<p dir="auto"><a href="http://imageshack.us/photo/my-images/814/dishtrial2.jpg/" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="http://img814.imageshack.us/img814/7686/dishtrial2.jpg" alt="http://img814.imageshack.us/img814/7686/dishtrial2.jpg" class=" img-fluid img-markdown" /><br />
</a></p>
<p dir="auto">Any clues on what went wrong or how I get these surfaces repaired?  ( I tried the arc and pencil tool but ended up with problems )</p>
]]></description><link>https://community.sketchucation.com/topic/132805/follow-me-problems</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 19:55:35 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/132805.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Jan 2012 09:06:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Follow me problems on Mon, 23 Jan 2012 18:35:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gaieus" aria-label="Profile: gaieus">@<bdi>gaieus</bdi></a> said:</p>
<blockquote>
<p dir="auto">The general workaround is to scale the model up by 10 or even 100 temporarily, do the follow me (or other) operation then scale it back.....In any case, scaling is the trick.</p>
</blockquote>
<p dir="auto">Correct - that was successful   .  Thanks for your help</p>
<p dir="auto"><a href="http://imageshack.us/photo/my-images/543/penndishcorrected.jpg/" target="_blank" rel="noopener noreferrer nofollow ugc"><br />
<img src="http://img543.imageshack.us/img543/8805/penndishcorrected.jpg" alt="http://img543.imageshack.us/img543/8805/penndishcorrected.jpg" class=" img-fluid img-markdown" /><br />
</a></p>
]]></description><link>https://community.sketchucation.com/post/1305250</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305250</guid><dc:creator><![CDATA[HarleyDear]]></dc:creator><pubDate>Mon, 23 Jan 2012 18:35:41 GMT</pubDate></item><item><title><![CDATA[Reply to Follow me problems on Mon, 23 Jan 2012 09:29:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi Harley,</p>
<p dir="auto">I am not 100% certain but from the screenshots it seems that those faces would be very small. SketchUp has problems with creating faces whose edges would be around 1 mm / 1/16" (or smaller). The general workaround is to scale the model up by 10 or even 100 temporarily, do the follow me (or other) operation then scale it back.</p>
<p dir="auto">A nifty trick would be to make that part a component, insert (or copy) another instance, scale that up, do the follow me operation (it would be done in all copies) and at the end, delete the scaled copy.</p>
<p dir="auto">In any case, scaling is the trick.</p>
]]></description><link>https://community.sketchucation.com/post/1305137</link><guid isPermaLink="true">https://community.sketchucation.com/post/1305137</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Mon, 23 Jan 2012 09:29:05 GMT</pubDate></item></channel></rss>
