<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I don&#x27;t get how EEbyFaces works(?!)]]></title><description><![CDATA[<p dir="auto">I am looking for a curve that fits the one I got using EEbyFaces and I don't even understand the result. Flipping the rectangle on x doesn't change a thing. Changing the curve's direction not either. When I replace the curve with a straight line converted to a polyline things take more or less the same ugly way.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/ncWt_flipped.png" alt="flipped.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/132683/i-don-t-get-how-eebyfaces-works</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 18:50:55 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/132683.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jan 2012 08:01:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I don&#x27;t get how EEbyFaces works(?!) on Mon, 16 Jan 2012 16:25:45 GMT]]></title><description><![CDATA[<p dir="auto">In SU there is no curves ! Only edges! So each surface must be first closed by triangles!<br />
There is not inside the plug an option for erase coplanar edges ? <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=e9183c1a0df" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /> (if I good remember)   <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f612.png?v=e9183c1a0df" class="not-responsive emoji emoji-android emoji--unamused" style="height:23px;width:auto;vertical-align:middle" title=":unamused:" alt="😒" /></p>
]]></description><link>https://community.sketchucation.com/post/1303828</link><guid isPermaLink="true">https://community.sketchucation.com/post/1303828</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Mon, 16 Jan 2012 16:25:45 GMT</pubDate></item><item><title><![CDATA[Reply to I don&#x27;t get how EEbyFaces works(?!) on Mon, 16 Jan 2012 14:59:18 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the explanation. Works great.</p>
<p dir="auto">Although I have to admit that I think that the 2nd curve you get looks weird or at least unexpected to me.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/gRWv_Capture1.PNG" alt="Capture1.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1303810</link><guid isPermaLink="true">https://community.sketchucation.com/post/1303810</guid><dc:creator><![CDATA[NickGenerator]]></dc:creator><pubDate>Mon, 16 Jan 2012 14:59:18 GMT</pubDate></item><item><title><![CDATA[Reply to I don&#x27;t get how EEbyFaces works(?!) on Mon, 16 Jan 2012 09:58:14 GMT]]></title><description><![CDATA[<p dir="auto">The faces are twisted relative to each other, and face opposite ways too.<br />
EEbyFaces is not the tool needed to do what you want.<br />
It's a specialist tool with few applications that are,'t more easily done by other tools...<br />
Use EEbyRails !<br />
Place the 'paths' centrally on the faces edges<br />
Make the Profile and Melding-Profiles from the 3 sides of the loops of the two faces, each welded into a curve.<br />
Do this for the two sides of the faces as you will make the extrusion in two halves...<br />
Make the Rails from the two 'paths'.<br />
Weld the paths' edges into curves.<br />
If the straight path is a single line then use divide to make it into the same number of segments as in the wavy path, then weld that into a curve that just happens to be straight.<br />
Now use E<img src="/uploads/imported_attachments/Bqty_Capture.PNG" alt="Capture.PNG" class=" img-fluid img-markdown" /><img src="/uploads/imported_attachments/Hug8_Capture1.PNG" alt="Capture1.PNG" class=" img-fluid img-markdown" />EbyRails twice and combine the groups as needed...</p>
]]></description><link>https://community.sketchucation.com/post/1303765</link><guid isPermaLink="true">https://community.sketchucation.com/post/1303765</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Mon, 16 Jan 2012 09:58:14 GMT</pubDate></item></channel></rss>
