    Color the DC conditioning on its attributes & values (MYSQL
    23 Posts 4 Posters 1.6k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @blue_orchid said:
      i am not at all experienced in any programming language and mysql. Ruby is my first programming language. I have gone through several ruby guide, but still i am having hard time learning it and working on it.
      Yes it shows. You will need to study and re-read the tutorials again and again, until it sinks into your brain.
      You should read the 'Pick-Axe' book cover to cover.
      http://www.phrogz.net/ProgrammingRuby/frameset.html
      I'm not here much anymore.
        blue_orchid
        UI.menu("Plugins").add_item('Assesment') { Jeny.color }
        require 'mysql'
        module Jeny
            def self.color
        dbh = Mysql.real_connect("localhost", "root", "orange", "test",3306)
        dbh.query("drop table if exists inspection")
        dbh.query("create table inspection(component varchar(20), ID int(4), rating int(1))")
        dbh.query("insert into inspection values('deck',2345,1),('Substructure',2349,2),('Superstructure',2353,3)")
        #printf "%d rows were inserted\n",dbh.affected_rows
        #res = dbh.query("SELECT rating, id FROM inspection")
        res = dbh.query("SELECT rating FROM inspection where id = '2345'")
        while row = res.fetch_row do
        xx = row[0]
        printf "%s\n", xx
        res1 = dbh.query("SELECT rating FROM inspection where id = '2349'")
        while row = res1.fetch_row do
        xy = row[0]
        printf "%s\n", xy
        res2 = dbh.query("SELECT rating FROM inspection where id = '2353'")
        while row = res2.fetch_row do
        yy = row[0]
        printf "%s\n", yy
        Sketchup.active_model.entities.to_a.each{|e|
        if e.get_attribute('dynamic_attributes','id','2345')
        e.set_attribute('dynamic_attributes','rating','xx')
        if e.get_attribute('dynamic_attributes','id','')== "2349"
        e.set_attribute('dynamic_attributes','rating','xy')
        if e.get_attribute('dynamic_attributes','id','') == "2353"
        e.set_attribute('dynamic_attributes','rating','yy')
        if e.get_attribute('dynamic_attributes','id','2345') && xx == "1"
             e.set_attribute( 'dynamic_attributes', 'material', 'red')
             e.set_attribute( 'dynamic_attributes', '_material_formula', '"red"')
             $dc_observers.get_latest_class.redraw_with_undo(e)
        elsif e.get_attribute('dynamic_attributes','id','2345') && xx == "2"
             e.set_attribute( 'dynamic_attributes', 'material', 'blue')
             e.set_attribute( 'dynamic_attributes', '_material_formula', '"blue"')
        elsif e.get_attribute('dynamic_attributes','id','2349') && xx == "3"
             e.set_attribute( 'dynamic_attributes', 'material', 'green')
             e.set_attribute( 'dynamic_attributes', '_material_formula', '"green"')
        if e.get_attribute('dynamic_attributes','id','2349') && xy == "1"
        elsif e.get_attribute('dynamic_attributes','id','2349') && xy == "2"
        elsif e.get_attribute('dynamic_attributes','id','2349') && xy == "3"
        if e.get_attribute('dynamic_attributes','id','2353') && yy == "1"
        elsif e.get_attribute('dynamic_attributes','id','2353') && yy == "2"
        elsif e.get_attribute('dynamic_attributes','id','2353') && yy == "3"
        %(#BF4000)[What I did here:
        I set attribute 'rating' for different objects with different names like xx, xy and yy.
        Then I made these attributes 'ratings' equal to result from query for each component/object.
        Finally i selected the color for each component and different values of ratings a color.
        But it still selects only last code i.e. objects color change to green . May be it could not identify the Db values.]
        Now what i want to do that if the rating for a component is 1 in database, then the attribute 'rating' for that component is changed to 1 using DB value. Is it possible?
          blue_orchid
          This code finally worked πŸ˜„
          UI.menu("Plugins").add_item('Assesment') { Inspection.color }
          require 'mysql'
          module Inspection
              def self.color
          		dbh = Mysql.real_connect("localhost", "root", "***", "test",3306)
          		dbh.query("insert into inspection values('deck',2345,2),('Substructure',2349,1),('Superstructure',2353,3)")
          		xx = row[0]
          		printf "%s\n", xx
          		xy = row[0]
          		printf "%s\n", xy
          		yy = row[0]
          		printf "%s\n", yy
          			if e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='1'
          			e.set_attribute('dynamic_attributes','rating','1')
          			elsif e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='2'
          			e.set_attribute('dynamic_attributes','rating','2')
          			elsif e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='3'
          			e.set_attribute('dynamic_attributes','rating','3')
          			if e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='1'
          			elsif e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='2'
          			elsif e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='3'
          			if e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='1'
          			elsif e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='2'
          			elsif e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='3'
          			if e.get_attribute('dynamic_attributes','rating','')=='1'
          			e.set_attribute( 'dynamic_attributes', 'material', 'black')
          			e.set_attribute( 'dynamic_attributes', '_material_formula', '"black"')
          			elsif e.get_attribute('dynamic_attributes','rating','')=='2'
          			elsif e.get_attribute('dynamic_attributes','rating','')=='3'
          Thanks to all.
          • 2 / 2
