<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with engine]]></title><description><![CDATA[<p dir="auto"><img src="http://i40.servimg.com/u/f40/13/60/48/01/captur11.png" alt="http://i40.servimg.com/u/f40/13/60/48/01/captur11.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">hello,I build a quadrotor.</p>
<p dir="auto">I would like my black propeller changes orientation ((front, rear) and (left, right) with two servo controls. When I made ​​the motor does not work.</p>
<p dir="auto">How to solve this problem? thank you for your help</p>
]]></description><link>https://community.sketchucation.com/topic/128940/problem-with-engine</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 14:42:16 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/128940.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Jul 2011 15:01:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with engine on Thu, 07 Jul 2011 11:57:17 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your help. I wonder if having two different angles are not going to have a conséquance the control. I'll test it. Thank you very much for your quick help.</p>
]]></description><link>https://community.sketchucation.com/post/1266231</link><guid isPermaLink="true">https://community.sketchucation.com/post/1266231</guid><dc:creator><![CDATA[madmax52]]></dc:creator><pubDate>Thu, 07 Jul 2011 11:57:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with engine on Thu, 07 Jul 2011 10:49:19 GMT]]></title><description><![CDATA[<p dir="auto">Ah the problem is you connected the servos to the same group, so they are each trying pull it in their direction while the other one holds them back.</p>
<p dir="auto">Best rule of thumb is have one movable group for each joint, added the fixed example.</p>
<hr />
<p dir="auto"><a href="/uploads/imported_attachments/leNN_uav.skp">uav.skp</a></p>
]]></description><link>https://community.sketchucation.com/post/1266215</link><guid isPermaLink="true">https://community.sketchucation.com/post/1266215</guid><dc:creator><![CDATA[Mr.K.1]]></dc:creator><pubDate>Thu, 07 Jul 2011 10:49:19 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with engine on Thu, 07 Jul 2011 10:07:08 GMT]]></title><description><![CDATA[<p dir="auto">here is my project file: <a href="https://skydrive.live.com/embedicon.aspx/.Public/uav.skp?cid=d6ea2d2b4eca3159&amp;sc" target="_blank" rel="noopener noreferrer nofollow ugc">https://skydrive.live.com/embedicon.aspx/.Public/uav.skp?cid=d6ea2d2b4eca3159&amp;sc</a></p>
]]></description><link>https://community.sketchucation.com/post/1266206</link><guid isPermaLink="true">https://community.sketchucation.com/post/1266206</guid><dc:creator><![CDATA[madmax52]]></dc:creator><pubDate>Thu, 07 Jul 2011 10:07:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with engine on Thu, 07 Jul 2011 09:08:55 GMT]]></title><description><![CDATA[<p dir="auto">Very hard to tell without the actual model, so try to upload that and we can have a look how your joint connections are set up.</p>
]]></description><link>https://community.sketchucation.com/post/1266191</link><guid isPermaLink="true">https://community.sketchucation.com/post/1266191</guid><dc:creator><![CDATA[Mr.K.1]]></dc:creator><pubDate>Thu, 07 Jul 2011 09:08:55 GMT</pubDate></item></channel></rss>
