    [Code] Sketchup.send_action() : Arguments to
    22 Posts 8 Posters 7.8k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @dan rathbun said:
      Has anyone found a cross-platform string to send the model to Layout ?
      On the PC only this works:
      Sketchup::send_action( 23051 )
      John confirmed that Sketchup::send_action("sendToLayOut:") works on Mac.
      So that gives us a cross-platform method
      <span class="syntaxdefault">def send_active_model_to_layout</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">  return nil unless Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_pro</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(;</span><span class="syntaxdefault">platform</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">platform </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">platform_win </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||<br /></span><span class="syntaxdefault">  RUBY_PLATFORM </span><span class="syntaxkeyword">!~</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">/(</span><span class="syntaxdefault">darwin</span><span class="syntaxkeyword">)/</span><span class="syntaxdefault">i<br />    Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 23051 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  else<br />    Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"sendToLayOut;"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end<br /></span>
      EDIT: inserted Pro only bailout statement to return nil if not SketchUp Pro.
      I'm not here much anymore.
        driven
        it's been a while and maybe everyone has lost interest, but I found a few more for the mac list...
        the big question is, how many of these run on a PC?
        single # denotes a Menu Title, ## Item Title, ### hard coded shortcut combo...
        # SketchUp
          Sketchup.send_action('showAboutBox;')  ## About SketchUp
          Sketchup.send_action('showSketchUpPreferences;')  ## Preferences...
          Sketchup.send_action('manageLicenses;')  ## License...
          Sketchup.send_action('checkWebUpdate;')  ## Check Web for Update...
          Sketchup.send_action('hide;')  ## Hide SketchUp  ### ⌘H
          Sketchup.send_action('hideOtherApplications;')  ## Hide Others  ### ⌘H
          Sketchup.send_action('unhideAllApplications;')  ## Show All
          Sketchup.send_action('terminate;')  ## Quit SketchUp  ### ⌘Q
        # File
          Sketchup.send_action('newDocument;')  ## New  ### ⌘N
          Sketchup.send_action('openDocument;')  ## Open...  ### ⌘O
          Sketchup.send_action('clearRecentDocuments;')  ## Clear Menu
          Sketchup.send_action('performClose;')  ## Close  ### ⌘W
          Sketchup.send_action('saveDocument;')  ## Save  ### ⌘S
          Sketchup.send_action('saveDocumentAs;')  ## Save As...  ### ⇧⌘S
          Sketchup.send_action('saveCopy;')  ## Save A Copy As...
          Sketchup.send_action('saveAsTemplate;')  ## Save As Template...
          Sketchup.send_action('revertDocumentToSaved;')  ## Revert
          Sketchup.send_action('sendToLayOut;')  ## Send to LayOut
          Sketchup.send_action('importFromGoogleEarth;')  ## Add Location...
          Sketchup.send_action('clearLocation;')  ## Clear Location
          Sketchup.send_action('toggleTerrain;')  ## Show Terrain
          Sketchup.send_action('browse3DWarehouse;')  ## Get Models...
          Sketchup.send_action('shareWithGoogleEarthCommunity;')  ## Share Model...
          Sketchup.send_action('runImporter;')  ## Import...
          Sketchup.send_action('runPageLayout;')  ## Page Setup...  ### ⇧⌘P
          Sketchup.send_action('runDocumentSetup;')  ## Document Setup...
          Sketchup.send_action('printDocument;')  ## Print...  ### ⌘P
        # Edit
          Sketchup.send_action('editUndo;')  ## Undo  ### ⌘Z
          Sketchup.send_action('editRedo;')  ## Redo  ### ⇧⌘Z
          Sketchup.send_action('cut;')  ## Cut  ### ⌘X
          Sketchup.send_action('copy;')  ## Copy  ### ⌘C
          Sketchup.send_action('paste;')  ## Paste  ### ⌘V
          Sketchup.send_action('pasteInPlace;')  ## Paste In Place
          Sketchup.send_action('editDelete;')  ## Delete
          Sketchup.send_action('eraseConstructionGeometry;')  ## Delete Guides
          Sketchup.send_action('selectAll;')  ## Select All  ### ⌘A
          Sketchup.send_action('deselectAll;')  ## Select None  ### ⇧⌘A
          Sketchup.send_action('editHide;')  ## Hide  ### ⌘E
          Sketchup.send_action('editUnhide;')  ## Selected
          Sketchup.send_action('editUnhideLast;')  ## Last
          Sketchup.send_action('editUnhideAll;')  ## All  ### ⇧⌘E
          Sketchup.send_action('editLock;')  ## Lock
          Sketchup.send_action('editUnlockSelected;')  ## Selected
          Sketchup.send_action('editUnlockAll;')  ## All
          Sketchup.send_action('makeComponent;')  ## Make Component...  ### ⇧⌘G
          Sketchup.send_action('makeGroup;')  ## Make Group  ### ⌘G
          Sketchup.send_action('closeGroupOrComponent;')  ## Close Group/Component  ### ⇧⌘G
          Sketchup.send_action('intersectWithModel;')  ## With Model
          Sketchup.send_action('intersectSelected;')  ## With Selection
          Sketchup.send_action('intersectWithContext;')  ## With Context
        # View
          Sketchup.send_action('toggleToolPalette;')  ## Large Tool Set
          Sketchup.send_action('toggleSolidModelToolPalette;')  ## Solid Tools
          Sketchup.send_action('toggleGoogleToolPalette;')  ## Location
          Sketchup.send_action('toggleWarehouseToolPalette;')  ## Warehouse
          Sketchup.send_action('togglePageTabsDsiplay;')  ## Scene Tabs
          Sketchup.send_action('viewShowHidden;')  ## Hidden Geometry
          Sketchup.send_action('sectionToggleDisplay;')  ## Section Planes
          Sketchup.send_action('sectionToggleActivation;')  ## Section Cuts
          Sketchup.send_action('viewShowAxes;')  ## Axes
          Sketchup.send_action('viewShowGuides;')  ## Guides
          Sketchup.send_action('toggleShadows;')  ## Shadows
          Sketchup.send_action('toggleFog;')  ## Fog
          Sketchup.send_action('toggleDisplayEdges;')  ## Edges
          Sketchup.send_action('toggleDisplayBackEdges;')  ## Back Edges
          Sketchup.send_action('toggleProfiles;')  ## Profiles
          Sketchup.send_action('toggleDepthQue;')  ## Depth Cue
          Sketchup.send_action('toggleExtensions;')  ## Extension
          Sketchup.send_action('toggleGlobalTransparency;')  ## X-ray
          Sketchup.send_action('renderWireframe;')  ## Wireframe
          Sketchup.send_action('renderHiddenLine;')  ## Hidden Line
          Sketchup.send_action('renderShaded;')  ## Shaded
          Sketchup.send_action('renderTextures;')  ## Shaded With Textures
          Sketchup.send_action('renderMonochrome&#058;')  ## Monochrome
          Sketchup.send_action('toggleHideRestOfModel;')  ## Hide Rest of Model
          Sketchup.send_action('toggleHideSimilarComponents;')  ## Hide Similar Components
          Sketchup.send_action('pageAdd;')  ## Add Scene
          Sketchup.send_action('pageUpdate;')  ## Update Scene
          Sketchup.send_action('pageDelete;')  ## Delete Scene
          Sketchup.send_action('pagePrevious;')  ## Previous Scene
          Sketchup.send_action('pageNext;')  ## Next Scene
          Sketchup.send_action('slideshowStart;')  ## Play
          Sketchup.send_action('pageOptions;')  ## Settings
          Sketchup.send_action('toggleToolbarShown;')  ## Hide Toolbar
          Sketchup.send_action('runToolbarCustomizationPalette;')  ## Customize Toolbar ...
        # Draw
          Sketchup.send_action('selectLineTool;')  ## Line  ### ⌘L
          Sketchup.send_action('selectFreehandTool;')  ## Freehand  ### ⌘F
          Sketchup.send_action('selectArc3PointTool;')  ## Arc  ### ⌘J
          Sketchup.send_action('selectArcTool;')  ## 2 Point Arc
          Sketchup.send_action('select3PointFitArcTool;')  ## 3 Point Arc
          Sketchup.send_action('selectArcPieTool;')  ## Pie
          Sketchup.send_action('selectRectangleTool;')  ## Rectangle  ### ⌘K
          Sketchup.send_action('selectRectangle3PointTool;')  ## Rotated Rectangle
          Sketchup.send_action('selectCircleTool;')  ## Circle
          Sketchup.send_action('selectPolygonTool;')  ## Polygon
        # Camera
          Sketchup.send_action('viewUndo;')  ## Previous
          Sketchup.send_action('viewRedo;')  ## Next
          Sketchup.send_action('viewTop;')  ## Top  ### ⌘1
          Sketchup.send_action('viewBottom;')  ## Bottom  ### ⌘2
          Sketchup.send_action('viewFront;')  ## Front  ### ⌘3
          Sketchup.send_action('viewBack;')  ## Back  ### ⌘4
          Sketchup.send_action('viewLeft;')  ## Left  ### ⌘5
          Sketchup.send_action('viewRight;')  ## Right  ### ⌘6
          Sketchup.send_action('viewIso;')  ## Iso  ### ⌘7
          Sketchup.send_action('viewParallelProjection;')  ## Parallel Projection
          Sketchup.send_action('viewPerspective;')  ## Perspective
          Sketchup.send_action('viewTwoPointPerspective;')  ## Two-Point Perspective
          Sketchup.send_action('cameraMatchNewPhoto;')  ## Match New Photo...
          Sketchup.send_action('editPhotoMatch;')  ## Edit Matched Photo
          Sketchup.send_action('selectOrbitTool;')  ## Orbit  ### ⌘B
          Sketchup.send_action('selectDollyTool;')  ## Pan  ### ⌘R
          Sketchup.send_action('selectZoomTool;')  ## Zoom
          Sketchup.send_action('selectFieldOfViewTool;')  ## Field of View
          Sketchup.send_action('selectZoomWindowTool;')  ## Zoom Window
          Sketchup.send_action('viewZoomExtents;')  ## Zoom Extents
          Sketchup.send_action('viewZoomToSelection;')
          Sketchup.send_action('viewZoomImage;')  ## Zoom to Photo
          Sketchup.send_action('selectPositionCameraTool;')  ## Position Camera
          Sketchup.send_action('selectWalkTool;')  ## Walk
          Sketchup.send_action('selectTurnTool;')  ## Look Around
          Sketchup.send_action('selectImageIglooTool;')  ## Image Igloo
        # Tools
          Sketchup.send_action('selectSelectionTool;')  ## Select
          Sketchup.send_action('selectEraseTool;')  ## Eraser
          Sketchup.send_action('selectPaintTool;')  ## Paint Bucket
          Sketchup.send_action('selectMoveTool;')  ## Move  ### ⌘0
          Sketchup.send_action('selectRotateTool;')  ## Rotate  ### ⌘8
          Sketchup.send_action('selectScaleTool;')  ## Scale  ### ⌘9
          Sketchup.send_action('selectPushPullTool;')  ## Push/Pull
          Sketchup.send_action('selectExtrudeTool;')  ## Follow Me
          Sketchup.send_action('selectOffsetTool;')  ## Offset
          Sketchup.send_action('selectOuterShellTool;')  ## Outer Shell
          Sketchup.send_action('selectUnionTool;')  ## Union
          Sketchup.send_action('selectDifferenceTool;')  ## Subtract
          Sketchup.send_action('selectDifferenceNDTool;')  ## Trim
          Sketchup.send_action('selectIntersectTool;')  ## Intersect
          Sketchup.send_action('selectBooleanSplitTool;')  ## Split
          Sketchup.send_action('showSolidModelToolsMenu;')  ## Split
          Sketchup.send_action('selectMeasureTool;')  ## Tape Measure  ### ⌘D
          Sketchup.send_action('selectProtractorTool;')  ## Protractor
          Sketchup.send_action('selectAxisTool;')  ## Axes  ### ⌘F
          Sketchup.send_action('selectDimensionTool;')  ## Dimensions
          Sketchup.send_action('selectTextTool;')  ## Text
          Sketchup.send_action('doThreeDText;')  ## 3D Text
          Sketchup.send_action('selectSectionPlaneTool;')  ## Section Plane  ### ⌘Y
        # Window
          Sketchup.send_action('performMiniaturize;')  ## Minimize  ### ⌘M
          Sketchup.send_action('performZoom;')  ## Zoom
          Sketchup.send_action('showModelPropertiesPanel;')  ## Model Info  ### ⇧⌘I
          Sketchup.send_action('entityProperties;')  ## Entity Info  ### ⌘I
          Sketchup.send_action('orderFrontColorPanel;')  ## Materials  ### ⇧⌘C
          Sketchup.send_action('showComponentBrowser;')  ## Components
          Sketchup.send_action('showStyleBrowser;')  ## Styles
          Sketchup.send_action('showLayerPanel;')  ## Layers
          Sketchup.send_action('showOutliner;')  ## Outliner
          Sketchup.send_action('showPagePanel;')  ## Scenes
          Sketchup.send_action('orderFrontFontPanel;')  ## Show Fonts  ### ⌘T
          Sketchup.send_action('showRubyConsole;')  ## Ruby Console
          Sketchup.send_action('showShadowsPanel;')  ## Shadows
          Sketchup.send_action('showFogSettingsPanel;')  ## Fog
          Sketchup.send_action('showPhotoMatchPanel;')  ## Match Photo
          Sketchup.send_action('showSoftenEdgesPanel;')  ## Soften Edges
          Sketchup.send_action('showInstructor;')  ## Instructor
          Sketchup.send_action('browse3DWarehouse;')  ## 3D Warehouse
          Sketchup.send_action('browseExtensionStore;')  ## Extension Warehouse
          Sketchup.send_action('toggleInspectors;')  ## Hide Dialogs
          Sketchup.send_action('getPhotoTexture;')  ## Photo Textures !!!!!!!!!!!! not working
          Sketchup.send_action('arrangeInFront;')  ## Bring All to Front
        # Help
          Sketchup.send_action('showWelcomePanel;')  ## Welcome To SketchUp…
          Sketchup.send_action('showOnlineHelpCenter;')  ## Knowledge Center
          Sketchup.send_action('contactUs;')  ## Contact Us
        # Orphans
          Sketchup.send_action('fixNonPlanarFaces;') ## Model Info >> Statistics >> Fix Problems
        I may have missed some...
        john
        • 2 / 2
