    Renders of Romanesque Monastery
    32 Posts 27 Posters 10.3k Views 27 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Google, or someone else could create time periods of virtual restored worlds with building that have been destroyed over time. How magnificent.
        Aerilius
        How do you read my mind? πŸ˜„
          we can hear the bells ringing ! 😎
            tomislavm
            Perfect work, this is something very nice!
              Roger
              Doesn't Google already do that?
              http://www.azcreative.com
                Roger
                Aerilius, what sort of reference documents were you working from to create the reconstruction?
                  Aerilius
                  Most of the reconstruction is based on plans by the architect W. Manchot (1892) who examined the ruin and created very many detailed plans (up to ~10cm). Since that time the reconstruction proposals have changed a bit, so I updated it to current state of science (two tower theory <-> central tower).
                  Actually I had not posted the original renders (which have much better resolution).
                  Here are some more panoramic renders:
                  http://www.you3dview.com/search/?search_id=limburg
                  [flash=550,360:1cqg0gwc]http://www.you3dview.com/viewer/viewer.swf?xml=http://www.you3dview.com/flvideo/228/viewer.xml[/flash:1cqg0gwc]
                    bogdank
                    Great job! πŸ˜„
                    Can you please tell me how did you do texture inside, with all arcs and stuff???
                    I am modeling some tunnels where one end is higher than the other, so I join these diferent size arcs with sandbox (from contur). With all triangles that I get, I can not apply texture nicely. I tried with QuadFace but its not working for me.
                    I see on these panoramic photos that you done them perfectly.
                      bogdank
                      I forgot to attach...
                      This is the problem.
                      • irwanwrI Offline
                        irwanwr
                        πŸ‘ that was done with Kerkythea?
                        can we find a tutorial about this one in either SketchUcation or Kerkythea forum?
                        • numbthumbN Offline
                          numbthumb
                          Try searching Kerkythea forums.
                          These images are combination of renderings in Kerkythea and post production in PaintShop Pro. See here: http://forums.sketchucation.com/viewtopic.php?f=81&t=24790
                          Comfortably numb...
                          • irwanwrI Offline
                            irwanwr
                            thank you for the suggestion
                            • 2 / 2
