<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I drag a &quot;rake&quot; through a sandbox TIN?]]></title><description><![CDATA[<p dir="auto">I created a complex TIN with the From Contours tool.  Ironically, the TIN is meant to be sand.  Now I would like to texture the surface so that it looks like I dragged a garden rake through the "sand".  Are the built in sandbox tools able to do that?  If not, how should I create the desired effect?</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/SPr6_sandneedingarakeeffect.png" alt="What I have now" title="What I have now" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/115254/can-i-drag-a-quot-rake-quot-through-a-sandbox-tin</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 06:55:24 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/115254.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Oct 2009 12:11:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I drag a &quot;rake&quot; through a sandbox TIN? on Wed, 07 Oct 2009 12:29:49 GMT]]></title><description><![CDATA[<p dir="auto">if you want to render the image, just use a normal map (or bump map) with blurred black stripes on white background for your material. If you want more detalied effect, and your rendering engine allows it, you can use a displacement map.<br />
If you don't want to render the image, you can just make a texture with desired visuals... Trying to model that, will result in lots of polygons and SU might just not be able to handle.</p>
]]></description><link>https://community.sketchucation.com/post/1122845</link><guid isPermaLink="true">https://community.sketchucation.com/post/1122845</guid><dc:creator><![CDATA[NewOne]]></dc:creator><pubDate>Wed, 07 Oct 2009 12:29:49 GMT</pubDate></item></channel></rss>
