    Hospital Interiors (Maxwell Render)
    28 Posts 12 Posters 2.7k Views 12 Watching
    • brodieB Offline
      brodie
      Hey, haven't posted anything in awhile. These are a couple interior renderings of a nurse's station. The main objective was to portray the various finishes, which the client was having a hard time visualizing from floor plans and various product samples. About 16 hours of work aside from rendering time. Modeled in SU, rendered in Maxwell, and put together in Photoshop (with a minimal amount of color tweaking as well).
      http://dl.getdropbox.com/u/384281/Scene-1.jpg
      http://dl.getdropbox.com/u/384281/Scene-3.jpg
      -Brodie
      • artysmediaA Offline
        artysmedia
        I-N-C-R-E-D-I-B-L-E πŸ‘ 😍
        Maxwell is great!
        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
        Blog: Artysmedia
          d12dozr
          Nice work, Brodie!
          http://goo.gl/f7ooYh
          • boofredlayB Offline
            boofredlay
            Shazam that is great!
            • StinkieS Offline
              Stinkie
              I quite like these. I gotta ask, though: why don't you use Vray for interiors?
              • brodieB Offline
                brodie
                Well, to be honest; money, knowledge, and necessity.
                1. The company I work for would probably pay for it but it would take some convincing.
                2. I don't know Vray. I see a lot of great things coming out of it but it just hasn't been one of the programs I've learned (partly due to reason #1 above).
                3. And I haven't found a convincing reason to go with Vray over Maxwell for interiors. I suspect it's a lot faster (?) but speed isn't a huge issue for me. I'm quite content to get my renderings all set up and then let them run over night.
                And so a question to you, any compelling reason you think I should go to Vray?
                -Brodie
                • StinkieS Offline
                  Stinkie
                  lol. Considering speed isn't an issue for you ... no, I don't. πŸ˜„
                  You ever given Indigo a spin?
                  • brodieB Offline
                    brodie
                    I tried indigo for about a week or so while I was looking for rendering software initially. It seemed valuable but I was coming from zero rendering experience so I didn't understand much of the terminology and it was difficult (at that time at least) to find good documentation/tutorials with indigo. I found Kerky much easier to learn personally.
                    Ultimately I was very attracted to Maxwell because the tutorials were good but more importantly it doesn't use much "rendering lingo." Most of the input is real world physics. That has made it much easier to learn because when I want to find out what 'attenuation' or some such thing is there is plenty of information out there. It's much more difficult to find good info on something like 'ambient occlusion' or other more rendering specific language.
                    -Brodie
                    • marked001M Offline
                      marked001
                      maxwell is slow to render... but its soo so much easier to get a good lighting setup...i think that makes up for the slowness of the render..
                      great images, btw...
                      http://www.revision21vis.com
                      instagram: revi21on
                      • brodieB Offline
                        brodie
                        Agreed. Multilight (ability to adjust all light levels independently during or after a rendering is completed) is wonderful, especially for interiors.
                        Don't get me wrong, speed is important. But for me quality is more important. You can use just about any rendering software and produce brilliant images but some software takes a lot of know how to get to that level. The most obvious example would be just about any unbiased renderer. I've seen absolute photorealism from 3ds Max/Mental Ray for example, but there's a really steep learning curve to get there.
                        Hopefully Maxwell 2.0 will help with the speed issue, but I suspect my workflow will still be the same, I'll just get that much better images. My computer's just sitting here all night anyway, might as well put her to work πŸ˜„
                        -Brodie
                        • StinkieS Offline
                          Stinkie
                          Ease of use is indeed important. Which is why I mentioned Indigo. Far easier to use than Maxwell - thanks to Whaat's great exporter. While I never quite managed to wrap my head around MW's material system, I find making mats using SkIndigo extremely intuitive.
                          • brodieB Offline
                            brodie
                            One reason I simply wouldn't be able to use some programs at all is SU's poly support. I couldn't fit all the cars and trees I need to in a reasonable SU file (w/ my scale of buildings I will typically have 10-30 trees and 5-15 cars although I've had over 100 cars before and probably as many trees in the same scene). For that I use Maxwell's studio. I have a library of trees and cars that I've bought from Dosch and textured/exported to Maxwell using either SU or 3ds Max. I get them just right in Maxwell and save that tree/car file.
                            I do all of my building and site modeling in SU then export to Maxwell. Finally I open that Maxwell file with my building/site model and insert the trees/cars there rather than doing it in SU.
                            I'd be interested to know what those using other programs do when it comes to this issue.
                            -Brodie
                            • StinkieS Offline
                              Stinkie
                              Ah yes, good point. MW's Studio does come in handy when one has to add cars, trees and such. NL needs to do serious work on the Studio, though. As it stands now, it's far too buggy and clumsy. Shame, 'cause in essence the Studio's a great idea.
                              Like you, I'm looking forward to MW 2. A plugin for Modo ... yum! I'm hoping Indigo will have one too, one day.
                              • honoluludesktopH Offline
                                honoluludesktop
                                Hi Brodie, Nice working renders. Do you have any problems with clients being able to understand a 3d plan? I have stopped doing them because I find that for many, it is confusing, and some clients have problems visualizing a 3d plan, but don't want to say so in front of others. They all can however, understand a floor plan as a map. Your plan view is a viewing angle that I have not tried before, perhaps that makes all the difference.
                                • brodieB Offline
                                  brodie
                                  honolulu,
                                  To be honest this is the first time I've had the opportunity to try this approach. This is only the second interior I've really done 'formally' (I've done some stuff on my own, but don't get much opportunity to do it for work). I hope that will change though between this and the other rendering which I think have both been successful.
                                  I guess you're talking primarily about 3d renderings taken from directly above? My experience in general is that the closer you get to how people see things in real life, the smaller the leap is our brain has to take, and therefore the easier it is to visualize. I'd put 2d plans at the bottom of that list. They're great to build from but no one ever experiences life without perspective, much less 2d. I think this is why typically a GPS device you see in a car doesn't show you in plan view, but rather tilts the perspective down a bit so it's more 3 dimensional. For people who are used to looking at plans this general rule may not apply so much.
                                  I don't have any personal experience with clients looking at 3d plans, so that's interesting to hear your comments. I would have expected a bit of complication but not as much as it sounds like you've noticed. After all, this solves the 2d issue but it only touches on the perspective issue. A 1 point perspective still leaves a fairly large gap for the brain. Even worse it's from an angle we never see in real life making it extremely difficult to fool the brain.
                                  My hope is that the view I picked out improves on this (not that I'm the first to do it of course). Sort of like taking the GPS route and combining it with the 3d plan idea. It's 3d with a 3 point perspective which is helpful. The only hurdle is that it's still from a point of view you'll never see a camera take, however it's still an improvement and you can still see the overall plan all at once. This is particularly helpful in these renderings because the two views left out one detail in the finishes which is that the square floor pattern alternates colors between blue and green as it goes down the hallway.
                                  -Brodie
                                  • brodieB Offline
                                    brodie
                                    It looks like, from the previews, that Studio has gotten a bit of love. I can't imagine they spend a great deal of time on it as it seems few people use it though. Have you seen the v2.0 page? There are some images there of the new studio.
                                    It took me awhile to understand what's going on in studio but I'm pretty comfortable with it now. There are a couple bugs, with cloning objects, for example, but mostly they have easy workarounds. Instancing is funny to, but since instancing is essentially broken as far as I'm concerned, I don't use it much anyhow.
                                    -Brodie
                                      honoluludesktop
                                      Hi Brodie, Hmmm..... Perhaps now that 3d is becoming more popular, a lay person can be expected to see a 3d plan. I have drawn blank stares by company presidents with 3d plans (they really do not know what they were looking at). If you attend presentation to lay-persons with a larger 3d floor plan, please let us know how it goes.
                                      Don't know how others do it, but in conjunction with modeling the space, the interior elevations are viewed in 2d in order to visually study the location, and proportions of the wall elements. Many times I do this outside SU, with my production Cad because by then I am moving into production drawings. Guess that I'm just a old f**t, unable to shed the way I learned how to design. When that happens, I rarely go back to amend the model..
                                      • RichardR Offline
                                        Richard
                                        Wow REALLY nice work again brodes!!!
                                        Mate i'd probably have used an MXI emitter for the ceiling diffusers, that way you could get the flouro's showing through look. The lights as they are just lack that bit of oumf!
                                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                        • brodieB Offline
                                          brodie
                                          Richard,
                                          Always good to get your input.
                                          Yeah, that's a great idea about using mxi's for the lights. I'll definately have to try that next time. That raises my mxi complaint though which is that there doesn't seem to be a way to adjust the power of the emitter within the material itself 😞 Always have to do it in multilight even for quick test renderings.
                                          -Brodie
                                          • EarthMoverE Offline
                                            EarthMover
                                            Really great stuff Brodie...as usual. I could smell hospital just by looking at the renders. The floor is suburb. In the 3D plan views, I think removing the near wall to expose the main hallway would not make them feel so boxed in. Other than that, I'm amazed.
                                            Content Creator at Skapeup
                                            • 2 / 2
