<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wanted: Stretch tool]]></title><description><![CDATA[<p dir="auto">Su is a great modeler for leveling and shaping. But when you need to make a design leap, its often necessary to start from scratch.</p>
<p dir="auto">My CAD program provides a stretch tool that I find essential in the early stages of design. Say I am in plan (top) view. I can window a set of entities that can be stretched in any x, and y direction by a specified amount. From any other view the stretch would affect the corresponding axis. My CAD window can be a polygon.</p>
<p dir="auto">In Su terms, something like selecting a set of faces and push/pull them all at once without distortion to the model.</p>
<p dir="auto">An anyone point me to any rubies that address this?</p>
]]></description><link>https://community.sketchucation.com/topic/114728/wanted-stretch-tool</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 14:53:27 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/114728.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Sep 2009 21:26:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wanted: Stretch tool on Thu, 17 Sep 2009 13:00:24 GMT]]></title><description><![CDATA[<p dir="auto">wow. how you guys write these rubies is beyond me completely. am always in awe of your skills!</p>
<p dir="auto">thanks for replies</p>
]]></description><link>https://community.sketchucation.com/post/1118137</link><guid isPermaLink="true">https://community.sketchucation.com/post/1118137</guid><dc:creator><![CDATA[olishea]]></dc:creator><pubDate>Thu, 17 Sep 2009 13:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 22:57:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olishea" aria-label="Profile: olishea">@<bdi>olishea</bdi></a> said:</p>
<blockquote>
<p dir="auto">fredo, what does Divider do?</p>
</blockquote>
<p dir="auto">Watch the Video at time 2:50 in the top message of the FredoScale Thread, at <a href="http://forums.sketchucation.com/viewtopic.php?f=180&amp;t=17948#p144180" target="_blank" rel="noopener noreferrer nofollow ugc">http://forums.sketchucation.com/viewtopic.php?f=180&amp;t=17948#p144180</a>.<br />
The divider is a virtual plane which you can move graphically to indicate where is your pivot origin for stretching.</p>
<p dir="auto">Fredo</p>
]]></description><link>https://community.sketchucation.com/post/1118004</link><guid isPermaLink="true">https://community.sketchucation.com/post/1118004</guid><dc:creator><![CDATA[fredo6]]></dc:creator><pubDate>Wed, 16 Sep 2009 22:57:33 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 19:22:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olishea" aria-label="Profile: olishea">@<bdi>olishea</bdi></a> said:</p>
<blockquote>
</blockquote>
<p dir="auto">Oli the divider allows you to choose the point you stretch from.<br />
As default it stretches from centre, but you can visibly move this point to anywhere you wish and stretch from this new point.</p>
]]></description><link>https://community.sketchucation.com/post/1117960</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117960</guid><dc:creator><![CDATA[dylan]]></dc:creator><pubDate>Wed, 16 Sep 2009 19:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 19:12:42 GMT]]></title><description><![CDATA[<p dir="auto">When using Fredo's FredoScale tool, make sure you use the "Stretch" mode, not the "Scale" mode.  It should do exactly what you want, even stretching a component without exploding or editing it first.  CB.</p>
]]></description><link>https://community.sketchucation.com/post/1117956</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117956</guid><dc:creator><![CDATA[daiku]]></dc:creator><pubDate>Wed, 16 Sep 2009 19:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 18:03:49 GMT]]></title><description><![CDATA[<p dir="auto">Yea, that was what I meant when I suggest the Move tool. If you can select just the part of the plan or whatever that needs to change its position in space, the Move tool ought to do the trick for you.</p>
]]></description><link>https://community.sketchucation.com/post/1117930</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117930</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 16 Sep 2009 18:03:49 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 17:34:35 GMT]]></title><description><![CDATA[<p dir="auto">I actually think that for what you want to do you do not need any Ruby. You simply need to select teh elements you want to stretch, and move them, all connected geometry will stretch when you move them.Of course if elements where turned into components/groups this won't work.</p>
]]></description><link>https://community.sketchucation.com/post/1117920</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117920</guid><dc:creator><![CDATA[CADAddict]]></dc:creator><pubDate>Wed, 16 Sep 2009 17:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 11:18:07 GMT]]></title><description><![CDATA[<p dir="auto">honolulu, sometimes it doesnt work properly in 3d space. with 2d line drawings then yeah, sketchup can stretch it but its a lot trickier getting the selection right with a 3D model.</p>
]]></description><link>https://community.sketchucation.com/post/1117847</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117847</guid><dc:creator><![CDATA[olishea]]></dc:creator><pubDate>Wed, 16 Sep 2009 11:18:07 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 11:09:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/honoluludesktop" aria-label="Profile: honoluludesktop">@<bdi>honoluludesktop</bdi></a> said:</p>
<blockquote>
<p dir="auto">"Fredo's scale tool" and "move" are not what I am looking for. If I have a building model of rooms, I would like to stretch (say) 2 rooms within the plan only affecting the selected walls.</p>
</blockquote>
<p dir="auto">Did you try with positioning the Divider in the right place (press F4 to display it). By default, it is positioned in the center of the selection, but this can be changed.</p>
]]></description><link>https://community.sketchucation.com/post/1117843</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117843</guid><dc:creator><![CDATA[fredo6]]></dc:creator><pubDate>Wed, 16 Sep 2009 11:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 10:07:51 GMT]]></title><description><![CDATA[<p dir="auto">Frenchy, Thanks for pointing me in the right direction with the image. Must be what Dave meant with his post. Thanks Takesh, even works with 3d shapes. Boy do I feel s****d :-). Am I the only one here that didn't know this?</p>
]]></description><link>https://community.sketchucation.com/post/1117834</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117834</guid><dc:creator><![CDATA[honoluludesktop]]></dc:creator><pubDate>Wed, 16 Sep 2009 10:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 09:41:23 GMT]]></title><description><![CDATA[<p dir="auto">seems if you intersect all then move that works <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0d0fb5b5d39" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/caor_stretcht.jpg" alt="stretcht.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1117823</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117823</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Wed, 16 Sep 2009 09:41:23 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 09:19:35 GMT]]></title><description><![CDATA[<p dir="auto">honoluludesktop,<br />
What you described in the last two ACAD screen captures can be done (of course in 3D) with native MOVE tool of SU with appropriate selection.<br />
If it's windows you want to change dimensions, Rick's Windowizer has little-known inheriting and editing functions.<br />
It's not stretching, I should rather call it "re-creating" that window.  But it will take the same amount of time and do the job.<br />
Windowizer 4 makes double-sided (3D) windows.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/8fSZ_windowizerN.skp-0.gif" alt="windowizerN.skp-0.gif" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/8y1I_windowizerN.skp-3.gif" alt="windowizerN.skp-3.gif" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/YuVK_windowizerN.skp-2.gif" alt="windowizerN.skp-2.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1117825</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117825</guid><dc:creator><![CDATA[takesh h]]></dc:creator><pubDate>Wed, 16 Sep 2009 09:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Wed, 16 Sep 2009 08:50:20 GMT]]></title><description><![CDATA[<p dir="auto">I was going to request this! Stretch is my favourite tool!!</p>
]]></description><link>https://community.sketchucation.com/post/1117820</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117820</guid><dc:creator><![CDATA[olishea]]></dc:creator><pubDate>Wed, 16 Sep 2009 08:50:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Tue, 15 Sep 2009 21:41:03 GMT]]></title><description><![CDATA[<p dir="auto">"Fredo's scale tool" and "move" are not what I am looking for. If I have a building model of rooms, I would like to stretch (say) 2 rooms within the plan only affecting the selected walls.</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/5s4q_temp04.jpg" alt="The model in 3d view" title="The model in 3d view" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/S88u_temp02.jpg" alt="The model in top view, windowed section indicated" title="The model in top view, windowed section indicated" class=" img-fluid img-markdown" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/5Ho5_temp03.jpg" alt="Windowed portion of model stretched on y axies" title="Windowed portion of model stretched on y axies" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1117745</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117745</guid><dc:creator><![CDATA[honoluludesktop]]></dc:creator><pubDate>Tue, 15 Sep 2009 21:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to Wanted: Stretch tool on Tue, 15 Sep 2009 21:35:05 GMT]]></title><description><![CDATA[<p dir="auto">Does it have to be Push/Pull? Could you use Fredo's FredoScale plugin? Or could you use the Move tool to move a selection?</p>
]]></description><link>https://community.sketchucation.com/post/1117743</link><guid isPermaLink="true">https://community.sketchucation.com/post/1117743</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Tue, 15 Sep 2009 21:35:05 GMT</pubDate></item></channel></rss>
