    Setting file types in the savepanel
    21 Posts 8 Posters 3.7k Views 8 Watching
    • T
      tvcasualty
      Sorry to drudge up old news, but this is an embarrassingly old issue, be nice to have a filter option in the API by now.
      Here was my solution because I didn't like the fact that it could possibly overwrite a file accidentally using TIGs approach (untitled != untitled.txt for example). Anyhow it can be a burden to hit save twice, but I'd rather do that 100x then accidentally save over something important.
      Where:
      EXT = "txt"
      default_dir = "c;\\temp\\"
      default_file = "untitled"
      The following while loop:
      name_valid = false
      while name_valid == false
       path_to_save_to = UI.savepanel("Save Code File", default_dir, default_file)
       #path_to_save_to = path_to_save_to.tr("\\","/") # This maybe required.
       fileext = File.extname(path_to_save_to) # filename with prefix stripped
       filebase = File.basename(path_to_save_to, ".#{EXT}")
       #puts fileext.inspect
       if fileext == "" || fileext == nil
        default_file = filebase + ".#{EXT}"
        UI.messagebox "Oops! Including the file extension '#{EXT}'\nThis is an embarrassing workaround...\nPlease hit save again."
        #puts default_file.inspect
       else
        filename = filebase + ".#{EXT}"
        path_to_save_to = File.dirname(path_to_save_to) + "\\" + filename
        name_valid = true
      • 2 / 2
