<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[De-select edges Plugin?]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">I have been playing around with Door/Sill Plugin which is a very useful tool. The thing is you have to select the inner polygons to run the script on. Instead of selecting a polygons, then rotating around the model for the other polygon it would be alot simpler to select the polygon in plan view and then  run a quick script (preferably a button or shortcut at least) to de-select the edges to run the Door/Sill sript on the 2 faces.</p>
<p dir="auto">Hope this makes sense. Basically a tool to de-select the edges of a selection you have made.</p>
<p dir="auto">Many thanks in advance.</p>
]]></description><link>https://community.sketchucation.com/topic/110149/de-select-edges-plugin</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 17:58:53 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/110149.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Feb 2009 12:13:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to De-select edges Plugin? on Fri, 20 Feb 2009 23:19:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: chris">@<bdi>chris</bdi></a> fullmer said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j_forrester" aria-label="Profile: j_forrester">@<bdi>j_forrester</bdi></a> said:</p>
<blockquote>
<p dir="auto">Wow! Just had a look at this script. The most useful script for workflow I have seen. Great work!</p>
</blockquote>
<p dir="auto">Thats because Thomas is amazing!</p>
</blockquote>
<p dir="auto">Very kind words Chris. Thanks.</p>
]]></description><link>https://community.sketchucation.com/post/1069260</link><guid isPermaLink="true">https://community.sketchucation.com/post/1069260</guid><dc:creator><![CDATA[thomthom]]></dc:creator><pubDate>Fri, 20 Feb 2009 23:19:51 GMT</pubDate></item><item><title><![CDATA[Reply to De-select edges Plugin? on Fri, 20 Feb 2009 18:23:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j_forrester" aria-label="Profile: j_forrester">@<bdi>j_forrester</bdi></a> said:</p>
<blockquote>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1069189</link><guid isPermaLink="true">https://community.sketchucation.com/post/1069189</guid><dc:creator><![CDATA[Chris Fullmer]]></dc:creator><pubDate>Fri, 20 Feb 2009 18:23:16 GMT</pubDate></item><item><title><![CDATA[Reply to De-select edges Plugin? on Fri, 20 Feb 2009 12:45:31 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the quick reply, i'll give that a go when I get chance.</p>
]]></description><link>https://community.sketchucation.com/post/1069079</link><guid isPermaLink="true">https://community.sketchucation.com/post/1069079</guid><dc:creator><![CDATA[j_forrester]]></dc:creator><pubDate>Fri, 20 Feb 2009 12:45:31 GMT</pubDate></item><item><title><![CDATA[Reply to De-select edges Plugin? on Fri, 20 Feb 2009 12:37:35 GMT]]></title><description><![CDATA[<p dir="auto">You can do that with Selection Toys: <a href="http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&amp;t=14975" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&amp;t=14975</a></p>
<p dir="auto">Rightclick on a selection and choose Selection-&gt;Deselect Edges</p>
<p dir="auto">I've assigned various hotkeys which I use all the time to filter my selection:<br />
Ctrl+1 -&gt; Selection-&gt;Lines (Returns just the lines of the selection)<br />
Ctrl+2 -&gt; Selection-&gt;Faces<br />
Ctrl+3 -&gt; Selection-&gt;Groups<br />
Ctrl+4 -&gt; Selection-&gt;Components</p>
<p dir="auto">Ctrl+Shift+1 -&gt; Selection-&gt;Deselect Lines<br />
Ctrl+Shift+2 -&gt; Selection-&gt;Deselect Faces<br />
Ctrl+Shift+3 -&gt; Selection-&gt;Deselect Groups<br />
Ctrl+Shift+4 -&gt; Selection-&gt;Deselect Components</p>
<p dir="auto">The combination of those shortcuts are very quickly accessible to my left hand while I model.</p>
]]></description><link>https://community.sketchucation.com/post/1069077</link><guid isPermaLink="true">https://community.sketchucation.com/post/1069077</guid><dc:creator><![CDATA[thomthom]]></dc:creator><pubDate>Fri, 20 Feb 2009 12:37:35 GMT</pubDate></item></channel></rss>
