    Interior concept
    26 Posts 17 Posters 1.7k Views 17 Watching
    • marked001M Offline
      marked001
      wow....beautiful design and extremely beautiful render! im definitley in awe
      (and free agent, that bug in your sig freaked me out!)
      http://www.revision21vis.com
      instagram: revi21on
        dirkkkk
        thanks you all
        these are some new test renders C&C welcome πŸ˜„
        • DanielD Offline
          Daniel
          Fantabulastic!
          I'd hate to see the cooling bill in the summertime, though.
          My avatar is an anachronism.
            chango70
            Who needs 3DS Max 😍 .
              dirkkkk
              can someone advice me how to create an smooth animation form this model?? (in Vray)
              What settings are best to use and how can I create a smooth camera path in sketchup.
              ps.
              (foxar bedankt voor de tip)
                steelers05
                http://asgvis.com/index.php?option=com_smf&Itemid=90&topic=5121.0
                Try that. It worked for me (check out the youtube link to see the result). I wrote a tutorial of how I have did it and I have done a few other quick animations with the same method. All the things that are suggested by dalomar are accurate, but I have so far been able to successfully manage animations without having to do any IR calculating or anything like that. Im just telling you this, because the way I did was very simple and straight forward, but it may not be full proof. So I would resort to other suggestions if my method does not work. One other thing, I did all my animations on a single computer but a beast of one and with a lot of geometry in my scene (which seems to be the case for you here) it took about a week straight to get about a 18 second output (if you use a 30 sec frame rate). And laslty, im not too sure if you can get rid of the jerky transitions between scenes because of the way SU handles them. There may be ways that I am not aware of, but I have yet to see any real good solution (it would be great if someone told me im wrong because I wish that this could be fixed). Good luck and please post your results. Oh and I would also like to know where you got the plants if you dont mind sharing?
                • 2 / 2
