<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DC2 following curved path]]></title><description><![CDATA[<p dir="auto">Attached file is about an example of two DC's in RG plane.<br />
DC1 follows a curved path while DC2 follows a straigth line.<br />
(change some values and experiment / have fun)</p>
<p dir="auto">Wo3Dan</p>
<hr />
<p dir="auto"><a href="/uploads/imported_attachments/XFWa_Curved_path_DC.skp">Curved_path_DC.skp</a></p>
]]></description><link>https://community.sketchucation.com/topic/108093/dc2-following-curved-path</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 06:38:43 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/108093.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Nov 2008 20:43:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DC2 following curved path on Tue, 25 Nov 2008 22:10:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Chris, I'm just experimenting to make movements less static (=follow different matematical<br />
rules other than straight lines). Along the way I should get more familiar with DC_syntax.<br />
The included dimensions aren't DC-features. Each of the four dimensions work with their own virtual intersection points on the axes. I posted about this weird behaviour (in SU6) way back, see:<br />
<a href="http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&amp;t=8315&amp;p=49280&amp;hilit=+virtual+intersection+#p49280" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&amp;t=8315&amp;p=49280&amp;hilit=+virtual+intersection+#p49280</a><br />
Fixing semy associated dimensions (so they will update again) was also in SU6. Probably already in SU5. Here they come in handy to see what (some of) the DC-values are doing.</p>
<p dir="auto">Looking forward to see what you come up with next!<br />
Wo3Dan</p>
]]></description><link>https://community.sketchucation.com/post/1047996</link><guid isPermaLink="true">https://community.sketchucation.com/post/1047996</guid><dc:creator><![CDATA[Wo3Dan]]></dc:creator><pubDate>Tue, 25 Nov 2008 22:10:54 GMT</pubDate></item><item><title><![CDATA[Reply to DC2 following curved path on Tue, 25 Nov 2008 21:16:36 GMT]]></title><description><![CDATA[<p dir="auto">That's very cool Dan.  I wish there was a way to get the DC to actually follow the path, so one could change the path and the DC would automatically follow it.  I have some ideas for how to accomplish something like this using nodes.  But I think I have found that I need to have all nodes be separate pre-made components.  They can't be created dynamically because there is no way to get the X,Y coordinates of a dynamic copy at this point.  Or maybe there is.  I'll post the question and maybe Scott Will answer.  At any rate, very cool!  I liked the dimensions being updated throughout the animation.</p>
<p dir="auto">Chris</p>
]]></description><link>https://community.sketchucation.com/post/1047972</link><guid isPermaLink="true">https://community.sketchucation.com/post/1047972</guid><dc:creator><![CDATA[Chris Fullmer]]></dc:creator><pubDate>Tue, 25 Nov 2008 21:16:36 GMT</pubDate></item></channel></rss>
