<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Inference for Rectangle tool]]></title><description><![CDATA[<p dir="auto">Hello everybody</p>
<p dir="auto">It might be a dumb question - But I thought that I might well ask.</p>
<p dir="auto">When you open a new file, want to draw a rectangle with the rectangle tool in<br />
vertical direction the inferencing does not work. One has to always have a reference<br />
cube object or some object so that referring the vertical plane of that object<br />
you can then draw the rectangle vertically.</p>
<p dir="auto">Is there a way to straight away draw the rectangle vertically up? Also for a horizontal<br />
plane to get rotated vertically (without having any other reference object) the compass<br />
cannot be turned vertically. This also needs a reference object. Is this normal in SU?</p>
<p dir="auto">So I always draw a reference cube as soon as open a new file. If there is any other<br />
method please tell me.</p>
<p dir="auto">Thanks in advance<br />
PRSS</p>
]]></description><link>https://community.sketchucation.com/topic/106995/inference-for-rectangle-tool</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 14:36:03 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/106995.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Oct 2008 14:04:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Inference for Rectangle tool on Thu, 19 Apr 2012 03:46:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brooksl" aria-label="Profile: brooksl">@<bdi>brooksl</bdi></a> said:</p>
<blockquote>
<p dir="auto">I don't understand why the Rectangle and Rotate tools should not respond to the arrow keys being used to force an inference similar to how they do for the Line tool, Move tool, or Tape Measure tool:</p>
<p dir="auto">Locking an inference  <a href="http://support.google.com/sketchup/bin/answer.py?hl=en&amp;answer=70142" target="_blank" rel="noopener noreferrer nofollow ugc">http://support.google.com/sketchup/bin/answer.py?hl=en&amp;answer=70142</a></p>
<p dir="auto">...I think the Rectange tool and Rotate tool <em>SHOULD</em> respond similarly to the arrow keys by settign the inferred plane</p>
</blockquote>
<p dir="auto">Perhaps the reason the rectangle tool doesn't work with the standard inferences is that it requires two directions rather than just one, so any single inference is not enough. They work for a line (an edge), as it may be defined in one direction, not so a face (a rectangle) which has two dimensions and thus two directions.</p>
]]></description><link>https://community.sketchucation.com/post/1322831</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322831</guid><dc:creator><![CDATA[brookefox]]></dc:creator><pubDate>Thu, 19 Apr 2012 03:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Wed, 18 Apr 2012 19:12:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi folks.</p>
<p dir="auto">The Rotate Tool can be made to rotate along any edge.</p>
<p dir="auto">See this from SU's help:</p>
<p dir="auto"></p><div class="card col-md-9 col-lg-6 position-relative link-preview p-0">
<div class="card-body">
<h5 class="card-title">
<a class="text-decoration-none" href="http://142.251.32.174/sketchup/bin/answer.py?hl=en&amp;answer=94897">
Error 404 (Not Found)!!1
</a>
</h5>
<p class="card-text line-clamp-3"></p>
</div>
<a href="http://142.251.32.174/sketchup/bin/answer.py?hl=en&amp;answer=94897" class="card-footer text-body-secondary small d-flex gap-2 align-items-center lh-2">
<img src="http://142.251.32.174/favicon.ico" alt="favicon" class="not-responsive overflow-hiddden" style="max-width:21px;max-height:21px" />
<p class="d-inline-block text-truncate mb-0"> <span class="text-secondary">(support.google.com)</span></p>
</a>
</div><p></p>
<p dir="auto">Just ideas.</p>
]]></description><link>https://community.sketchucation.com/post/1322788</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322788</guid><dc:creator><![CDATA[Jean Lemire]]></dc:creator><pubDate>Wed, 18 Apr 2012 19:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Wed, 18 Apr 2012 13:34:56 GMT]]></title><description><![CDATA[<p dir="auto">A cool trick is also to use the <a href="http://forums.sketchucation.com/viewtopic.php?t" target="_blank" rel="noopener noreferrer nofollow ugc">Fredo Scale</a>!<br />
With it you have always the in any position orientation in the 3D Space!<br />
For any operations Scale, Rotate  etc...<br />
So Draw any rectangle and speedy adapt it to your whish <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=0d0fb5b5d39" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
<p dir="auto"><img src="/uploads/imported_attachments/Qfak_fredo6.jpg" alt="fredo6.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/post/1322727</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322727</guid><dc:creator><![CDATA[pilou]]></dc:creator><pubDate>Wed, 18 Apr 2012 13:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Wed, 18 Apr 2012 13:17:55 GMT]]></title><description><![CDATA[<p dir="auto">The best option for drawing the rectangle with the desired orientation is to orbit to make inferencing set things up as you want. You could also set up guidelines if needed. This can be useful especially when working off axis.</p>
<p dir="auto">I think there is a better way. If you want to rotate your rectangle about one edge.</p>
<p dir="auto">Select the rectangle.<br />
Get the Rotate tool.<br />
Click on the edge about which you want to rotate the rectangle.<br />
Hold the left mouse button and drag along the edge. This will orient the tool correctly.<br />
Release the button.<br />
Click again to start the rotation and drag round to the desired angle or type the desired angle and hit enter.</p>
]]></description><link>https://community.sketchucation.com/post/1322720</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322720</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 18 Apr 2012 13:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Tue, 17 Apr 2012 21:39:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Jean for that tip... I was having quite a frustrating time trying to get a rectangle to draw on the desired plane</p>
<p dir="auto">-- and then if I couldn't get it to draw on the desired plane, I had yet MORE difficultly rotating it to the desired orientation because the Rotate tool seems to behave in the same way - the protractor tends to stick to the plane most parallel to the screen.</p>
<p dir="auto">I see this as a novel and sometimes convenient way of determing the active drawing or tool plane, but really I don't understand why the Rectangle and Rotate tools should not respond to the arrow keys being used to force an inference similar to how they do for the Line tool, Move tool, or Tape Measure tool:</p>
<p dir="auto">...I think the Rectange tool and Rotate tool <em>SHOULD</em> respond similarly to the arrow keys by settign the inferred plane because there are often times when the desired drawing location is not easily viewed from an angle that will cause the inference engine to select the desired plane.</p>
<p dir="auto">Please let me know if there's a better way or work around.</p>
]]></description><link>https://community.sketchucation.com/post/1322561</link><guid isPermaLink="true">https://community.sketchucation.com/post/1322561</guid><dc:creator><![CDATA[BrooksL]]></dc:creator><pubDate>Tue, 17 Apr 2012 21:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Fri, 03 Oct 2008 18:17:12 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Jean Lemire</p>
<p dir="auto">This is really useful for me.</p>
<p dir="auto">With best regards<br />
PRSS</p>
]]></description><link>https://community.sketchucation.com/post/1037214</link><guid isPermaLink="true">https://community.sketchucation.com/post/1037214</guid><dc:creator><![CDATA[PRSS]]></dc:creator><pubDate>Fri, 03 Oct 2008 18:17:12 GMT</pubDate></item><item><title><![CDATA[Reply to Inference for Rectangle tool on Thu, 02 Oct 2008 14:20:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi Prss, hi folks.</p>
<p dir="auto">Yes it can be done.</p>
<p dir="auto">Orbit untill you are mostly facing a vertical plane.  Better yet, choose any of the standard views that show a vertical plane (Face or Back or Right or Left).</p>
<p dir="auto">Try this to get acquainted with SU behavior pertaining to drawing rectangles:</p>
<p dir="auto">Select the Iso view.  This will most than certainly force the Rectangle Tool to draw an horizontal rectangle.</p>
<p dir="auto">Begin drawing the rectangle.  The rectangle will draw on the horizontal plane.  Do not finish it yet.</p>
<p dir="auto">Orbit so you get a view that is presenting more of any vertical plane and, of course, less of the horizontal plane.  Yes, you can orbit, pan, zoom, change viewing mode, change scenes, etc, even in the middle of an operation, be it drawing, moving, rotating, scaling, etc.  This is one very powerfull aspect of SU and probably one of the less known to beginners.  If you watch the video tutorials, you will see it being used quite often.</p>
<p dir="auto">Back to the rectangle in progress.  You will probably notice that, when you reach some viewing angle, the rectangle now wants to be drawn on a vertical plane.  even better, if you orbit so the red/blue plane is mostly facing you, the rectangle will align itself to be parallel with this plane.  If you orbit so that the green/blue plane is mostly facing you, the rectangle will align itself to be parallel with this plane.</p>
<p dir="auto">And, if you are not satisfied with the position or orientation of the rectangle, you can always move it to where you want it and rotate it so it faces the way you want.</p>
]]></description><link>https://community.sketchucation.com/post/1036899</link><guid isPermaLink="true">https://community.sketchucation.com/post/1036899</guid><dc:creator><![CDATA[Jean Lemire]]></dc:creator><pubDate>Thu, 02 Oct 2008 14:20:25 GMT</pubDate></item></channel></rss>
