    Rogue Renders!
    44 Posts 12 Posters 6.4k Views 12 Watching
    • Roguer1R Offline
      Roguer1
      I have just started using the Kerkythea app and it's great. I found it very simple and fast compared to others and have done my first quick render with it and my second only render. Its the Rogue Falcon Coupe, simple but nice. Its quite low texture detail. I'll upload some Ford Edge / Rogue Revolution Renders once I get them done..
      Find all my models on the 3D Warehouse
        remus
        Really good renders, although i tihnk some of the materials could do with some bump mapping (tyres, headlights etc.)
        • Roguer1R Offline
          Roguer1
          Well here they are:
          Render time about 20min each
          Tell me what you think....
          All my renders can be found on my website: http://rogueautomotivedesign.webs.com/index.htm
            ScottPara
            The lack of door seams looks weird. Makes the vehicle look quite flat.
            Scott
            Love the fact that some HATE my avatar.....
            • Roguer1R Offline
              Roguer1
              Well, I dont really think low poly sketchup models need the seems as the lines function in SketchUp compensates for that. Although it doesn't allow for very real renders, I dont mind. I'm not gonna spend any more time on doing stuff like that, modeling a car takes too long as it is.
              Thanks all for the comments here are some more renders
              • Roguer1R Offline
                Roguer1
                Ok...here are some more:
                • FrederikF Offline
                  Frederik
                  What render preset have you been using for these..??
                  Cheers
                  Kim Frederik
                  • Roguer1R Offline
                    Roguer1
                    If in preset you mean setup I have been using the default..
                    • FrederikF Offline
                      Frederik
                      By render preset, I mean the various render presets available in KT... πŸ˜‰
                      Reason for asking is that your renders look very CG-ish to me... 😐
                      I suggest that you start try using one of the PM presets (no. 3 - 😎 and I'm sure you'll notice a big difference... πŸ˜‰
                      Cheers
                      Kim Frederik
                      • RayOchoaR Offline
                        RayOchoa
                        nice renders rogue which ones up there are made by you?
                        CaR DeSiGnS bY mE
                        http://ray-ochoa.com
                        • Roguer1R Offline
                          Roguer1
                          [attachment=0:17ueor9i]<!-- ia0 -->KT-presets.jpg<!-- ia0 -->[/attachment:17ueor9i]
                          I have it set to custom settings but the only thing i have changed is the sky...so its still on the normal settings/setup. Thnaks for the advice, I'll try it asap
                          If you mean renders I made all of them, if you mean models you can find that information on my website:
                            Whatever render preset you choose and then change anything in the render settings, it will become a "custom" setting.
                            So to choose a preset and then modify it, do the following
                            1. choose as preset (any of the Photonmap ones Kim is suggesting - they're still fast)
                            2. don't start the render but press "Apply" then exit the render window
                            3. make any changes in the render setting you wish
                            4. go to the render window again (now you will see "custom" again)
                            5. don't change it to anything now but start rendering.
                              Ray tracing is really for quick previews (say checking the viewport, directions of shadows, size of materials etc) but does not do light bouncing for instance just uses direct light (correct me, Kim, if I'm mistaken - I haven't touched Kerky for months 😳 ).
                            • FrederikF Offline
                              Frederik
                              You're absolutely right, Csaba..! πŸ‘
                              Cheers
                              Kim Frederik
                              • Roguer1R Offline
                                Roguer1
                                Thanks all for the advice. I am still mucking arround in Kerkythea and all the work I have done can be seen above and on my website. From what you can see its not a lot but it can only get better
                                  Jackson
                                  Wow, nice models! What sort of poly count are you achieving with these?
                                  Jackson
                                  • Roguer1R Offline
                                    Roguer1
                                    Thanks, I am currently making models with up to about 45,000 poly's. Most of the models above range from 15,000 to 30,000 but one or two, such as the M14 and Falcon Coupe, sit at about 45-55,000
                                      Jackson
                                      Wow, most of the low poly cars I use are around 5000 faces, but then they don't look as good as yours and the interiors are very minimal.
                                      Jackson
                                      • Roguer1R Offline
                                        Roguer1
                                        I have noticed when I started modeling my models were at about 2,000 to 7,000 but I have begun to add more and more detail resulting in much more poly's. I also model my own wheels, I use a circle with 100 sides so they, themselves, can reach about 5,000. I also model most of the running gear, engine and under body of the car too. Here are some quick images of these things:
                                          Jackson
                                          Ahhh, it's the wheels that are the killers- are you sure those little radii on the rims are necessary- they seem a bit extraneous unless you're doing extreme close-up renders. Not a criticism, I'm just a bit of a low-poly obsessive as I often have to put tons of trees, cars etc into large urban models, always looking for ways to keep my larger skp files workable. Beautiful models- are they worked up from elevations or just photographs?
                                          Jackson
                                          • Roguer1R Offline
                                            Roguer1
                                            I am a bit of a detail freak too but I'm the other way with it. If I can add more detail to make it more realistic, I will. Wheels are often a focal point of a car, if they look like c#@p then most people won't look twice at it but if they are clean and attractive it makes the car stand out that much more.
                                            Most of my models are built up from blueprints either done by me or from cars I really like. I have modeled one or two from just photos but I find it a lot more difficult. Although with many blueprints, they often are not in proportion and that can lead to a inaccurate model. I have also modeled a few from scratch, most of my older models are scratch built.
                                            Here are a hand full of WIP's:
                                            • 1 / 3
