<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Windowizer problem in groups]]></title><description><![CDATA[<p dir="auto">I am having a problem with windowizer when used in a group or a component. If I use it on a face in a group I get Z fighting. The same occurs in a component. Anyone else having this?</p>
<p dir="auto">small skp attached to demonstrate.</p>
<p dir="auto">Marianne</p>
<hr />
<p dir="auto"><a href="/uploads/imported_attachments/in6B_windowizertest.skp">windowizer test.skp</a></p>
]]></description><link>https://community.sketchucation.com/topic/104347/windowizer-problem-in-groups</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 17:59:05 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/104347.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Jun 2008 02:53:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Windowizer problem in groups on Tue, 03 Jun 2008 14:38:08 GMT]]></title><description><![CDATA[<p dir="auto">What version of Windowizer are you using?  If it isn't 3.0, <a href="http://www.smustard.com/script/Windowizer3" target="_blank" rel="noopener noreferrer nofollow ugc">get it from Smustard</a>.</p>
]]></description><link>https://community.sketchucation.com/post/1010066</link><guid isPermaLink="true">https://community.sketchucation.com/post/1010066</guid><dc:creator><![CDATA[RickW]]></dc:creator><pubDate>Tue, 03 Jun 2008 14:38:08 GMT</pubDate></item><item><title><![CDATA[Reply to Windowizer problem in groups on Tue, 03 Jun 2008 12:14:24 GMT]]></title><description><![CDATA[<p dir="auto">I think your problem is as I understand it.</p>
<p dir="auto">The Windowiser ruby changes a section of a face into a component window. When you create the window externally of a group/component the face is repeated and therefore causing the conflict. (I Think)</p>
<p dir="auto">If you create the window in the group/component then it should solve the problem</p>
<p dir="auto">(PS. I hope someone who knows more will correct my mistakes.)</p>
]]></description><link>https://community.sketchucation.com/post/1010012</link><guid isPermaLink="true">https://community.sketchucation.com/post/1010012</guid><dc:creator><![CDATA[Tobobo]]></dc:creator><pubDate>Tue, 03 Jun 2008 12:14:24 GMT</pubDate></item></channel></rss>
