    Podium light and texture tests
    28 Posts 10 Posters 3.3k Views 10 Watching
      @kwistenbiebel said:
      ...Off course Solos work is genuine. Please don't doubt that.
      Solo is a master in using a full spectrum of software packages in his workflow to guide his creativity...
      No doubt, man!
      • FrederikF Offline
        Frederik
        Solo,
        I don't doubt you... I said I have my doubts, which is quite different...
        Actually I didn't mean to doubt you in the way you interpret my posting... I didn't mean to "make the kitty mad"... I have NO reason to believe that you lie or anything, and I didn't accuse you for doing that... πŸ˜‰
        The fact that the hairy material is a texture where you've used clip-maps, makes a lot more sense... All I meant was/is that if the hair was meshes in a SU model, it would be impossible to deal with...
        @solo said:
        Does KT support bumps, scripts and alpha maps?
        Of course... What ever you can make with Podium, you can make in KT...
        Reason... It's a well known fact that KT is the engine behind Podium and TBD have made the interface integrating it with SU... Very smart and very good, I might add... But still the engine behind is KT, so whatever you're able to do with Podium, will also be available in KT... (Actually it's the other way around, but never mind.. πŸ˜†)
        In addition you have Fog, Bevel and Edge Outline mapping in the material editor in current version of KT, and some new material features will be available in next release together with many other new features - including a Mac port...
        It's actually a shame that we don't work closer together... Imagine how many resources we could share between KT and Podium... πŸ˜‰
        Cheers
        Kim Frederik
        Cheers
        Kim Frederik
        • soloS Offline
          solo
          Frederick
          Thank you for your reply, I honestly never knew that KT and Podium were the same engine, and I do believe they should work closer together if that is the case. I suppose it is no fluke that they are both undergoing some major upgrades at the same time too.
          I have seen some amazing images from KT and like I said before am looking forward to the new version in order to try my hand at it, unless there is a beta around that I can try.
          As soon as I find my way around the UI and can get a flow going I will attempt a few bump and alpha scenes, in hope of repeating the above.
          I have peeped into the KT forum and must say there are a lot of resources available to all users, I am impressed with the free texture library y'all have available.
          As far as TBD goes, I am amazed at his skills and involvement within the GC field, and his little tweaks and time saving Ruby's that he is always willing to help with. I have had a very happy experiance with Podium and hope that in future I can gain another valuble resourse in KT which will assist me in my workflow.
          I must say the Fog and bevel edges does sound very appealing, I have a tutorial for fog in our Tutorial section some place that is very involved, having an easy button will certainly smooth things over, and bevel edges will smooth low poly imports to the extent of them being an option in high detailed renders.
          I hope in future we can work together in the same way as I do with the brass at Podium, and use a combined knowledge to improve our skills together.
          cheers. πŸ‘
          http://www.solos-art.com
          • FrederikF Offline
            Frederik
            You're very welcome...! πŸ˜‰
            But they are... That's a fact... πŸ˜‰
            Take a look at the render solution inside SketchUp ... coming soon thread... It sure was easier with the good old SU Forum, but at least Google have preserved it in the new GGroups...
            Scroll down in the thread and you'll see...
            Here's a couple of quotes...
            some clarifications:
            • the name of the project is "Podium"
            • it is using a render engine licensed from Giannis
            • it doesn't interfere with Kerkythea development
            • you dont have to install anything else besides Podium to get the renders
            • "very promising - and FUN!!" - K.F. (beta-tester)
            and the integration with SU ... will be even better
            also it is a way to pay Giannis efforts ... and mine
            And for me being a member of the KT Team, I know it's a fact...
            Unfortunately we haven't got a public beta... Only an internal beta is available... 😐
            You should download the Getting Started tutorial and you'll be up running in 5-10 minutes, I'm sure...
            Could indeed be very interesting...
            Speak soon!
            Kim Frederik
            Cheers
            Kim Frederik
            • K Offline
              kwistenbiebel
              I thought the 'bevel' option didn't work in Kerkythea when using SU2KT exporter...?
              About the Podium vs. Kerkythea thing:
              Even though (current)Podiums and Kerkytheas engine are 'similar', I do think that both are totally different in their way of use and workflow.
              They both adress a different audience:
              Kerkythea adresses a more techy 'bells and whistles' audience , while Podium adresses people that love to focus more on the subject and less on the tool by using a '3 button' solution.
              I don't consider one better than the other, but I do consider them to be both very different in terms of workflow philosophy.
              • FrederikF Offline
                Frederik
                Hhhmmm... To be honest, I'm not sure... I don't use bevel mapping very often, and currently I have a new version of SU2KT, where it does work... But alternatively, you can export as an OBJ-file, and import it to KT and it will work... πŸ˜‰
                I agree with you regarding the workflow thing, Chris...
                TBD sure have made an excellent plug-in, and despite the simplicity, users are able to make really great looking renders, but fact is that this is not the plug-in, but the engine behind generating the nice and photo-realistic renders... πŸ˜‰
                Cheers
                Kim Frederik
                P.S. And sorry for hi-jacking Solo's thread... πŸ˜‰
                Cheers
                Kim Frederik
                  sepo
                  It is not as simple as that I am afraid Frederik. You are right about the engine under the hood but also Tavi has not created just a simple exporter. He has finetuned the means of getting the best out of the said engine. He has spend hours and hours with some help of the beta team to fine tune and get out the maximum of that engine. I would say It is pretty similar to cars. You can have 2 cars with same engine under the hood but one can perform way better under circumstances because of the finetuning.
                  Saying all of this I have to say I love Kerky and use it myself. However this kind of rethoric is not really helpfull to anyone.
                    sepo
                    Hi Bruce
                    Good to hear you are coming back home πŸ˜‰
                    • 2 / 2
