    Rayscaper New Releases
    rayscaperrender
    170 Posts 9 Posters 1.2k Views 10 Watching
    • pixelcruncherP Offline
      pixelcruncher Extension Creator @pixelcruncher
      @nickchun can you also mail me the file for which it keeps crashing? thomas@rayscaper.com.
        Krass
        I previously attached images of Rayscaper with a very satisfactory upscale and I am now adding a character: So, Rayscaper rendering, adding a character with Flux dev basic (via my ComfyUI installation for those who know), and upscale with Magnific via the Xfigura site which gives a few free credits per month.
        pixelcruncherP 1 Reply Last reply Reply Quote 1
          @Krass Very cool, I didn't know about ComfyUI; I'm going to try that out. Thanks for sharing the workflow!
            Krass
            Be careful, Comfy UI requires a large graphics card and lots of free disk space, and a lot of patience.
              Hey, Rayscaper users!
              Another release!
              Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
              always, I recommend upgrading to the latest version.
              What Changed?
              • Fix weird artifacts in the interactive render viewport.
              • Fix the upside-down images when saving.
              • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
              • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp
                light component again.
              • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
              • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
              Help Me Build the Community 👍
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
              and helps me showcase its capabilities to new users.
              Follow me on Twitter.
              Happy Rendering!
                Krass
                thanks Pix, but no change for the lights component name with this version 9.64 If I rename the lights componant all lights go down
                pixelcruncherP 1 Reply Last reply Reply Quote 0
                  @Krass, just as a sanity check, you are not changing the name right, and not the component definition name?
                    Krass
                    ok, sorry, Indeed, I changed the component name and the instance name... thanks. Perfect, I'll test it.
                    However, I don't understand. I set the HDR definition to 8k, and it seems that it doesn't take this definition into account. I'll redo the rendering after downloading the map from the site.
                      Krass
                      This post is deleted!
                        Krass
                          Krass
                          before/after: rayscaper project/Nano banana+Magnific upscale
                          • 9 / 9
