    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      Davidekcek3347 Newcomers
      Does anybody knows how to crack Librfredo6 extensions?
      • V Offline
        Vander
        I don't recall this behavior when we last used this to flatten a DWG.
        Attached is the SKP file with the Original DWG Component on the Left and the Box Scaled DWG Component on the Right. When i click into the Scaled Component and try to enter the Trash Can Component (Circled in Red) the whole Component jumps to a different location as though the Axis is Changed. Also there is no Z axis shown in the scaled Component. Any Idea on why this happens? Our Workaround was to use Flatten to Plane from Eneroth. But this requires going into the individual Sub Components and Flattening. We don't want to Explode Everything and we want to keep the DWG Layers intact.
        Dropbox
        (www.dropbox.com)
        FYI: Here is the link to a post about different ways of flattening a Component via the Sketchup Forum.
        Looking for extension to create 2d projections
        SketchUp Community (forums.sketchup.com)
        John (Vander, Zvan2000)
          timbcarter
          Just bought Fredo Scale because I had a paneled design for a stair balustrade and I needed to
          skew it for the grade and then had to give it a radius on the upper section. Skewing worked well
          but the free bending doesn't seem to handle any ornamentation in the panel. It works on single plane
          flat panels but when there is a design ( 2D same as plane ) it pulls off part of the design while bending
          and then fails to complete the bend. I actually got it do do it once but all other attempts failed. I tried
          as a component and exploded and selected, still no luck. It also doesn't seem to work as shown in a
          tutorial I saw. Also the Box Plane shearing after using it I tried to make copies of the skewed panel
          and when I did it suddenly reverted back to the original shape. It did that several times and I finally got a
          copy that didn't revert. So things seeming pretty buggy to me at this point. Another comment about the
          bend, It would help if you could actuate a bend using a precise "bulge" distance like SU uses for arches.
          It's more usable for architectural purposes.
          I do love what it was trying to do
            dgannonennis
            Great plugin, thanks.
            When box stretching is it possible to input a measurement if you know the value rather than trying to stretch to the exact value?
            • fredo6F Offline
              You can show the dimension dialog by pressing TAB.
                betofg90
                I want to pay fredo pluggins bundle but im using a cracked sketchup, there's gonna be any problem or not?
                  Seb1986
                  Hi guys and girls is it possible to change the dimensions from Pixels to mm in the Fredoscale extensions??
                  I am trying to drag a cabinet from 900mm wide to 955mm the ideal way to do this I would just type in 55mm and it would move it the extra 55mm but this is in pixels and isn't as easy.
                    Show us a screenshot of what you are seeing. Sizing any geometry in pixels doesn't make any sense in SketchUp. Which tool are you using to change the dimensions of the cabinet? When I use Box Scaling I can just enter the desired final dimension.
                    Share the .skp file so we can see what you are working with.
                    Which version of SketchUp Pro are you using?
                      kostiaarh
                      Hello dear Fredo. Can I ask you to make a small edit to your plugin? Could we have more than 2 (3,4,5...N) scale planes in the plugin?
                        antonblam
                        Hello Fredo.
                        I don't know if it happens to anyone else.
                        I have an issue with the box scaling. I scale some geometry by a factor of 0 to make it flat - although it does the job of flattening, suddenly I can't select my geometry by cursor anymore, just by ctrl+A. I see the geometry where it should be, but for some reason I can't select it.
                        Is this a known problem? Is there a fix for that? I checked the version and I have the latest one (3.5a).
                        Thanks a lot in advance.
                        • fredo6F Offline
                          This is not really supported. By the way, you may get the issue with the native scaling.
                          • fredo6F Offline
                            NEW RELEASE: FredoScale v3.6a - 01 Apr 24
                            Requirements:
                            • LibFredo6 v14.3b.
                            • Sketchucation PluginStore v4.4.0.
                            FredoScale 3.5a includes changes for:
                            • Future compatibility
                            Home Page of FredoScale for information and Download.
                            Main post of this FredoScale thread.
                            S 1 Reply Last reply Reply Quote 0
                              seryaul @fredo6
                              @fredo6
                              Boa tarde, fiz a doação de $12, ainda não recebi o e-mail com a ativação do plugin.
                              Aguardo resposta.
                                rutpin
                                Hello, I installed the latest plugin but it does not appear in the menu list
                                TIGT R 2 Replies Last reply Reply Quote 0
                                  TIG Moderator @rutpin
                                  @rutpin
                                  After you downloaded the RBZ did you install it from the Extension Manager dialog ?
                                  Or are you using the SketchUcation Tools' ExtensionStore³ to auto-install it without an RBZ ?
                                  Do you have the latest LibFredo6 installed as well ?
                                  Do you also have the SketchUcation Tools installed [needed for any licensing] ?
                                  Have you restarted SketchUp after the installations to sync everything ??
                                    rutpin @rutpin
                                    TIG Yes
                                      Rich O Brien Moderator @rutpin
                                      @rutpin
                                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                        DomV12
                                        Hello, all the Fredo extensions work correctly for me but when I want to use FredoScale it tells me that the license has expired. Can someone give me a hand with this?
                                          Rich O Brien Moderator @DomV12
                                          @DomV12 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                          D 1 Reply Last reply Reply Quote 0
                                            DomV12 @Rich O Brien
                                            @Rich-O-Brien You mean this? :
                                            Fredo6 Plugins Information on 2024-07-16 09:33:05 -0400
                                            • Sketchup: 24.0.484
                                            • LibFredo6: v14.5c
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.1
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              FredoScale v3.6a
                                              FredoTools v4.5c
                                              Signature File: 2024-07-15 11:59:27 -0400
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 56
                                            • 57
                                            • 33 / 57
