    3D Truss Models
    1.5k Posts 31 Posters 977.4k Views 30 Watching
    • medeekM Offline
      medeek
      Plates applied to the top truss:
      http://design.medeek.com/resources/images/TIMBER_TRUSS3.jpg
      Specs:
      • Truss Type: King Post
      • 6x10 TC, 6x8 BC, 6x6 kingpost
      • Plate thickness = 0.25"
      • single row of bolts with two bolts per row.
      • connector plate width = 4.0"
      • Bolt Dia. 3/4"
      • Bolt Edge Distance (timber) = 4.0"
      • Bolt Edge Distance (plate) = 2.0"
      • Bolt Spacing = 4.0"
      • Bolts and Washers not shown.
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        This particular joint on a gambrel attic roof I am finding particularly difficult to plate:
        http://design.medeek.com/resources/images/truss_su170_800.jpg
        Luckily I have a few samples to use as guides. Given my web configurations at this joint this seems to be the most reasonable method to plate this joint. Note that the plate should touch the interior corner and the exterior of the lower top chord but at the same time not project past the lumber into the spaces. Also the plate is rotated so that it is parallel to the upper top chords pitch.
        The algorithm I devised to do this is quite clever I think but can be boiled down to a few concise lines of code:
          # Plate 2 (Gambrel Left)
        	x2 = @W2x2 - (mpcyy)/(sin(@Phi2))
        	y2 = @W2y2
        	m2 = tan(@Phi2)
        	x1 = @X2
        	y1 = @Y2
        	m1 = tan(@Phi1)
        	x0 = (y2 - y1 - m2*x2 + m1*x1)/(m1 - m2)
        	y0 = y1 + m1*(x0 - x1)
        	xoffset = (mpcxx/2.0)*(cos(@Phi2)) + (mpcyy/2.0)*(sin(@Phi2))
        	yoffset = (mpcxx/2.0)*(sin(@Phi2)) - (mpcyy/2.0)*(cos(@Phi2))
        	mpcx = x0 + xoffset
        	mpcy = y0 + yoffset
        	mpcrot = -@Phi2
        	MedeekMethods.metal_plate mpcx, mpcy, mpcxx, mpcyy, mpcrot, "PLGL"
        	# Plate 2 (Gambrel Right)
        	mpcx = @X5 - mpcx
        	mpcy = mpcy
        	mpcrot = @Phi2
        	MedeekMethods.metal_plate mpcx, mpcy, mpcxx, mpcyy, mpcrot, "PLGR"
        This joint has been the most difficult so far, everything else has been cake.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.7.4 - 12.20.2016
          • Enabled metal plate connectors for gambrel attic trusses.
          http://design.medeek.com/resources/images/truss_su171_800.jpg
          View model here:
          3D Warehouse
          design.medeek.com
          • FrederikF Offline
            Frederik
            Merry Christmas to you as well, Nathaniel! 👍
            http://www.kerkythea.net/users/Frederik/Anim-Icons/xmas.gif
            Cheers
            Kim Frederik
            • medeekM Offline
              medeek
              Version 1.7.5 - 12.24.2016
              • Enabled metal plate connectors for valley truss sets.
              • Enabled materials and custom layers for valley truss sets.
              http://design.medeek.com/resources/images/truss_su172_800.jpg
              View model here:
              3D Warehouse
              Merry Christmas to all.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.7.6 - 12.26.2016
                • Enabled metal plate connectors for monopitch trusses.
                • Enabled materials and custom layers for monopitch trusses.
                http://design.medeek.com/resources/images/truss_su173_800.jpg
                View model here:
                3D Warehouse
                I just realized that raised heel option does not work fully with the materials and connectors, I will work on a fix later today to sync that up.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.7.7 - 12.31.2016
                  • Enabled materials and custom layers for gable, hip, shed, TJI and dutch gable rafter roofs.
                  http://design.medeek.com/resources/images/truss_su174_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.7.8 - 01.02.2017
                    • Enabled materials and custom layers for gable dormers.
                    • Added advanced options for gable dormers, enabled exterior wall sheathing option.
                    http://design.medeek.com/resources/images/truss_su175_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Out of curiosity when you architects and designers add hardiplank siding or other types of siding to a building what do you typically do? One could go so far as modeling the sawtooth/washboard of the siding but this would become very heavy in the model. I'm assuming most just use a material/texture to simulate the effect.
                      On a slightly different note I am looking for a really good texture to use for concrete in my other plugins, any suggestions?
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        This is an example of custom layers and materials implemented in the Medeek Truss Plugin and Medeek Foundation Plugin and used in one model:
                        http://design.medeek.com/resources/images/truss_su176_800.jpg
                        View model here:
                        3D Warehouse
                        Turn off the sheathing layers first to reveal all of the structural framing etc...
                        Regular walls were created with the Housebuilder plugin.
                        The trim tool in the Truss Plugin was used quite successfully to manually trim back the dormer roof framing and sheathing.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Neck is doing pretty good these days, a little sore some mornings but nothing a little Ibuprofen can't fix.
                          On the flip side I came off of the Hydrocodone (for the neck and shoulder pain) about two weeks ago but still suffering from the withdrawal symptoms from this drug. My advice, don't ever use Hydrocodone unless it is absolutely life or death, its just not worth it.
                          I'm trying to figure out what to tackle next.
                          design.medeek.com
                          • pbacotP Offline
                            All looking great! Glad your neck is better. (I don't know what you've got or what you've been doing about it: I used exercises on mine which seemed good, along with general exercise. And I use a foam neck pillow. Just in case you're looking for ideas.)
                            • medeekM Offline
                              medeek
                              Tonight I spent some time trying to do some "real world" modeling and it quickly becomes apparent how limiting the plugins really are. Take a look at this model here:
                              3D Warehouse
                              I need the ability to cut holes in the floors and insert headers and double up joists etc...
                              There is a serious need for a good staircase plugin, but maybe that already exists, either way it would be handy to have that part of the truss plugin or wall plugin.
                              Where roofs merge into other walls requires some attention.
                              I really need to get to work on the wall plugin, I'm using Housebuilder but I have a lot of features I would like to see to make it more flexible and reliable.
                              The double glulam beam rafter roof would be a nice addition as well.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Fixed a small bug in the valley truss set, hence the revision 1.7.8b. Hopefully tonight I can attack the timber truss module, I think I have most of the pseudo code put together.
                                design.medeek.com
                                  Garry K
                                  My stair maker plugin creates straight and curved stairs. Also Spirals.
                                  I am intending on adding quarter and half landings and some other features.
                                  I have built more than 200 of these geometric stairs including elliptical, specialty winders etc.
                                  We also specialized in framed up curved stairs without the cost of stringers.
                                  Some of my stairs projects include providing the bending forms and flattened stringers.
                                  • medeekM Offline
                                    medeek
                                    Spent some time this morning traversing through the common truss code updating some of the truss types so that I can enable energy/raised heels for all common trusses as well as enable custom layers, materials and connector plates.
                                    As I've developed the plugin and added new features I used the fink truss as the cutting edge, so everything having to do with this truss type is pretty much up-to-date, however some of the other truss types are seriously lagging so a little house cleaning is in order.
                                    It may be a few days before I can release this latest version since there is a lot of tedious work ahead.
                                    design.medeek.com
                                    • pbacotP Offline
                                      Great work. I wish I had your dedication!
                                      • medeekM Offline
                                        medeek
                                        I will download your stair plugin and give it a go.
                                        That whole spiral staircase thing looks like a real challenge to code, don't even want to go there.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Raised/Energy heels add another level of complexity to the equation. Below you can see that various heights of a raised heel on a simple King Post truss requires different configurations and hence separate plating routines:
                                          http://design.medeek.com/resources/images/truss_su177_800.jpg
                                          This also affects the gable trusses as well, below is a fink truss with its gable counterpart:
                                          http://design.medeek.com/resources/images/truss_su178_800.jpg
                                          View models here:
                                          https://3dwarehouse.sketchup.com/model.html?id=91d8d78a-8e6c-4dab-9839-4d689c84c297
                                          https://3dwarehouse.sketchup.com/model.html?id=89739563-049f-4277-bfca-75663724967e
                                          I'm still house cleaning. I've now got the King Post, Fink and Howe truss fully cleaned up with connector plates enabled for all possible configurations (raised heel, non-raised heel, structural, non-structural). I've only got 9 more common truss types to work through, see list below:
                                          Queen Post
                                          Fan
                                          Mod Queen
                                          Double Fink
                                          Double Howe
                                          Mod Fan
                                          Triple Fink
                                          Triple Howe
                                          Quad Fink
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Raised Heel Howe Truss:
                                            http://design.medeek.com/resources/images/truss_su179_800.jpg
                                            design.medeek.com
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 75
                                            • 76
                                            • 28 / 76
