    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.3k Views 135 Watching
      Interesting. I do not have that "duh moment" reading this. πŸ˜†
      • jeff hammondJ Offline
        same here… more like an "uhhhhh πŸ˜• moment"
        πŸ˜†
        • kenK Offline
          ken
          I guess I could call this "The Well I'll be Darn Thread". I have used Sketchup since V 4. And I know that the text tool will give me info on geometry. Like length, area, but today, surprise, I used the text tool on the apex of an angle and I got the following, the degrees of the angle in the text box. Never saw that before, and I would have an illustration to show you if I could get the text tool to do it again.
          Ken
            I was reading a topic and realized that I did not understand a word.
            Then looked up and also realized I was in the Developers Forum. πŸ˜’
              0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
                Didn't you mean
                010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
                πŸ˜• πŸ˜‰
                  01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
                    It wasn't... but
                    0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
                      mrossk
                      I think I got geek all over me πŸ˜‰
                      https://www.mkaplanfinefurniture.com/
                        πŸ’š
                        	100001
                        	11000
                        	1110
                        	100011
                        	1100
                        	10001
                        	100100
                        	11110
                          Found a cool one today.
                          Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                          What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                          However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                          -Brodie
                          Duh!
                          That is sweet!
                          The manual doesn't even mention this!
                          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                          • H Offline
                            Heaps
                            It even works with circular arrays - just type in the angle in degrees
                            • brodieB Offline
                              brodie
                              However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                              -Brodie
                              • broomstickB Offline
                                broomstick
                                -Brodie
                                This, sir, just made my day!
                                • Bob JamesB Offline
                                  Bob James
                                  • jgbJ Offline
                                    jgb
                                    Found a cool one today. πŸ˜’
                                    -Brodie
                                    I just wish you found this last week, when I needed it. πŸ˜†
                                    jgb
                                      d12dozr
                                      -Brodie
                                      I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                                      http://goo.gl/f7ooYh
                                      • aarondietzenA Offline
                                        aarondietzen
                                        Shift + Eraser to smooth...
                                        I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                                        Ah... feels good to share my stupidity!
                                        "Imagination is more important than knowledge..."
                                        - Albert Einstein
                                        • massimoM Offline
                                          massimo Moderator
                                          Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                                            aarondietzen
                                            Stupidity x2! πŸ˜†
                                            - Albert Einstein
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
