    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      cik dib
      cool
      • dereiD Offline
        derei
        Any tutorial or explanatory PDF, please?
        I can't understand all those parameters.
        What I understand (or I think I do):
        Type - the shape of the "fur"
        Density - how much fur on square meter
        Max number/ Face - overrides "Density" and limit the number of fur/face (not dependent of face area)
        Length - how long the fur is
        RootWidth - width at base (if not rectangular)
        Divide - segments-define curvature smoothness
        direction x,y,z - how the fur is oriented
        Units - what units to use (metriv / US)
        This is what I understand, with the explanation that I think it is... the other settings I have no idea what they do. Please explain them to me.
        I want to make a "furry carpet", but what I get is or all fur oriented in same direction, or many of them, pointing downwards, trough my floor. How to make randomly oriented fur?
        Thank you.
        Please help me.
        DESIGNER AND ARTIST DEREI.UK
        • massimoM Offline
          massimo Moderator
          http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html πŸ˜„
          • dereiD Offline
            derei
            Thanks one thousand times! β˜€
            • dereiD Offline
              derei
              There are also two buttons: Assign to Material and Get from Material. They seem to do nothing, but I'm sure that they do. I just don't know how to use them.
              How to apply texture on created faces? That buttons are related to this? Don't tell me that I must apply texture on every shape created 😲
              Thanks.
                boestin
                First of all i would like to say thanks to the person who is responsible for this magnificent peace of art.
                The tool works wonderful, but i'm facing some errors. Hopefully someone will be able to help me out.
                Problem 1:
                The grass or fur is always facing downwards, in other words: upside down. It doesnt matter what i do, its always this way.
                Problem 2:
                Somehow, the color is black and white. I was hoping to see the grass turning green.
                Thanks!!
                  Hi Boestin,
                  In case 1: is the surface you want to run the plugin on a back face or a front face?
                    boestin
                    Hello Gaieus,
                    Thank you for you reply.
                    I dont know how I can check that, I am almost sure that it is the top side because when I draw a rectangle, select it and generate fur on this I am in the Top view camera.
                      When you draw a rectangle on the red/green plane, its back face (blue colour) is showing up by default. Right click and reverse faces to change that and now the front face (white) will show upwards.
                      I am not sure this is the problem but I can imagine.
                        boestin
                        Thanks Gaieus!! That was the problem
                        You made my day!!
                          sectionaa
                          @fletch said:
                          JC,
                          Does THIS help at all?
                          http://twilightrender.com/phpBB3/download/file.php?id=3803
                          Very useful indeed.
                          There must be a variable not shown in settings dialog which controls rotation on a specified axis.
                          (The default effect is visible in the road signs image).
                          It would be a great benefit to have that variable available, and a "jitter" control.
                          But the author has done a fantastic job.
                            sectionaa
                            @gaieus said:
                            Yeah. Though already a minority of the countries, still "the sun never sets over the countries that drive on the left".
                            πŸ˜„
                            And of course the land of the rising sun drives on the left.
                            • brodieB Offline
                              brodie
                              I downloaded the plugin and extracted it to my plugins folder (SU 😎 and now get a runtime error anytime I open SU. Anyone else have this issue or have a solution?
                              -Brodie
                                Taavi K
                                I ran into small problem. What can I do to lose that ... problem?
                                  sesil5
                                  goodmorning!! i need your help!
                                  How can i download this plugin?
                                    Hi Sesil,
                                    It is posted as an attachment at the bottom of the first post.
                                      sesil5
                                      @gaieus said:
                                      Hi Sesil,
                                      Hi Gaieus, i found the zip file but it doesn't contains any runfile for installation. Sorry for my English,i'm from Greece.
                                      Nevertheless, thank you very much.
                                        SketchUp plugins are 8mostly) simple text files with an rb (for "ruby") extension. All you need to do is to extract all the content and then copy everything into the plugins folder of SketchUp which is by default (on a 32 bit windows) here:
                                        C:\Program Files\Google\Google SketchUp 8\Plugins\
                                        Also, here is a sticky post about the installation of zipped plugins:
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                          sesil5
                                          It's work!!! Thank you very very much. I use some other plugins like omnigrid plugin and it was necessary to make an installation. I think that i'm comfused about the programms and the plugins!!!!
                                            dirtypr
                                            This is great!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 32
                                            • 33
                                            • 21 / 33
