    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 209.8k Views 76 Watching
      chango70
      @tig said:
      @aceshigh said:
      TIG, very nice plugin... can you improve it to add the option for another rail "edge", thus effectively transforming it into a SWEEP 2 RAILS plugin??
      It's on the list...
      Drool...
      • kerabeK Offline
        kerabe
        Wow, what a great plugin! Just downloaded it and have been playing around with it and I have had no real problems at all. Had to do some minor clean-up work but nothing unusual. Love it. ๐Ÿ˜„
        The CH124: If it isn't leaking, you're out of oil...
          Version 1.4 is now out... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
          1.4 20090707 Triangulation improved [as my recent triangulate.rb]. Rare intersect glitch fixed.
            Trivial problem ๐Ÿ˜„
            if the groups are on the full screen result is out of the screen an no possibity to see it before to reply all the box dialog!
            So will be cool that an automatic resize exist before process ๐Ÿ˜‰
            Sure I can zoom out but... ๐Ÿ˜‰
              mpowell1234567890
              Help, I cannot get it to work..
              Plugin seen not to work..
              Is there a way to fix it?
              @tig said:
              EDIT:
              1.1 20090625
              Speed improvements - face making time ~halved,
              typename >> kind_of?, triangulation glitch trapped
              and orientation improved.
              1.2 20090625
              Orientation speed optimised.
              Glitch on groups erase fixed.
              1.3 20090626
              Edges not facing in convoluted shapes trapped.
              1.4 20090707
              Triangulation improved. Rare intersect glitch fixed.
              This is extrudeEdgesByEdges.rb - it does what its name implies...
              [attachment=2:t7jruxbl]<!-- ia2 -->ExtrudeEdgesByEdgesExample.png<!-- ia2 -->[/attachment:t7jruxbl]
              [attachment=3:t7jruxbl]<!-- ia3 -->ExtrudeEdgesByEdgesEsamples.skp<!-- ia3 -->[/attachment:t7jruxbl]
              [attachment=1:t7jruxbl]<!-- ia1 -->extrudeEdgesByEdges.rb<!-- ia1 -->[/attachment:t7jruxbl]
                [attachment=0:1yi83ajh]<!-- ia0 -->Plugin error.JPG<!-- ia0 -->[/attachment:1yi83ajh]
                On the face of it, it looks like you aren't making a set of edges and grouping them as the 'profile', and also a set of edges and grouping them as the 'path'... Do this, then select the two groups and run the tool... The error message is telling you you haven't selected two groups...
                If you have other problems then please expand in your explanation...
                  Here's v1.5 - It now Zooms to show the new group [at Pilou's request]
                  • bazB Offline
                    baz
                    This is an astounding plugin, I've already found myself using it on lots of 'ordinary' tasks where usually I would have had to stuff around for ages with followme, copypaste, etc.
                    Thank you very much Tig.
                    Baz
                      THX! Very reactive! ๐Ÿ˜Ž ๐Ÿ‘
                      Edit ๐Ÿ˜„
                      Seems there is something wrong in the "Zoom" ๐Ÿ˜‰
                      That don't work ๐Ÿ˜ฎ
                      zoom out must be made before the first dialog box "Orient faces"
                      Without that zoom don't work even at the end ๐Ÿ˜„
                      (I have of course the 1.5)
                      zoom.skp
                        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                        It fixes a glitch with large mesh group results not zooming properly so that you can see them all...
                        The way it works is that it selects the group, 'zooms selected' and then removes group from selection - fine for modest sized meshes BUT if the group is too large SUp hasn't found the selection to 'zoom to' before the selection is cleared... so I've put the 'remove from selection' part after the first dialog so it has time !
                        • JClementsJ Offline
                          JClements
                          TIG:
                          Is the result you wanted when erasing coplanar edges?
                          John
                          P.S.
                          JSClements is a temp login until I can get JClements restored.
                          Is this the result you wanted when deleting coplanar edges.skp
                            cyan.archnet
                            really SUPERB plugin, THANKS A LOT!
                              Perfect zoom this time ๐Ÿ‘
                                Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                                Some rare coplanar edge erasure errors have now been trapped...
                                  TIG:
                                  John
                                  P.S.
                                  Obviously not ! ๐Ÿ˜
                                  I will check on why this might be happening... I thought such things had all got trapped... watch out for an update !!!
                                    Seems you will be quiet only when your true sweep 2 rails will be born ๐Ÿ˜„
                                    Because the "stay parallel orientation" of curves is sometimes annoying for real forms ๐Ÿ˜‰
                                      Pilou, patience ! ๐ŸŽ‰
                                        ๐Ÿ˜„
                                        It's soon holiday so September will be Christmas surprise ๐Ÿ’š
                                        • F Offline
                                          Fletch
                                          First, TIG, thank you so much for this awesome plugin! I've been begging Didier for years to write a Follow Me tool for Edges for a long time.
                                          The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
                                          Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example.
                                          if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                                          Fletch
                                          Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                            I have ask also Didier with his new Extrude along a vector for have the same fonction but...
                                            ๐Ÿ’š
                                            http://forums.sketchucation.com/download/file.php?id=29592&t=1
                                            • 3 / 10
